rick(at)beebe.org Guest
Posted: Fri Nov 15, 2019 1:37 pm Post subject: Speaking of LEDs |
The baggage compartment LED discussion reminded me...I'm putting in a B&C backup alternator. The voltage regulator comes with an incandescent low voltage light and they recommend keeping it. For aesthetic reason in my new panel (part of the project), I would like to use an LED to match the other indicators. I believe they want an incandescent because the VR puts out a trickle current that will keep the LED slightly lit. Anyone know if that's true and if there's a workaround? Or is there a more serious functional reason it needs to stay incandescent?
--Rick
Joined: 28 Mar 2008 Posts: 1908 Location: Riley TWP Michigan
Posted: Fri Nov 15, 2019 3:50 pm Post subject: Re: Speaking of LEDs |
A resistor is parallel with the LED will prevent the dim LED glow when it should be off.
_________________ Joe Gores |
Posted: Sat Nov 16, 2019 6:48 am Post subject: Speaking of LEDs |
At 03:35 PM 11/15/2019, you wrote:
Quote: | The baggage compartment LED discussion reminded me...I'm putting in a B&C backup alternator. The voltage regulator comes with an incandescent low voltage light and they recommend keeping it. For aesthetic reason in my new panel (part of the project), I would like to use an LED to match the other indicators. I believe they want an incandescent because the VR puts out a trickle current that will keep the LED slightly lit. Anyone know if that's true and if there's a workaround? Or is there a more serious functional reason it needs to stay incandescent? |
You can replace the incandescent lamp with
LED by proper application of some resistors:
http://aeroelectric.com/Pictures/Schematics/LR3_LV_Led_1.jpg
