Fwd: Top mod 65A
graemeh
PostPosted: Sat Dec 23, 2017 12:53 pm    Post subject: Fwd: Top mod 65A Reply with quote
The reply below was meant to go to the list.
---------- Forwarded message ---------
From: Graeme Hart <graeme.hart(at)onecoolkat.com (graeme.hart(at)onecoolkat.com)>
Date: Sun, 24 Dec 2017, 09:22
Subject: Re: Top mod 65A
To: Rick Stockton <aireupora(at)sbcglobal.net (aireupora(at)sbcglobal.net)>
Thank you so much Rick for sending through this set of pictures and the other three sets.  The job looks a lot less daunting than I thought.
I was not planning on doing Mod 67 but once I'm ready to join the two fuselage parts I will review that decision.
The advice on the screen is very helpful, I'm in NZ so getting one from Europa is an expensive option.  Fortunately I can have one made locally so I will have them make it to a template.  Unfortunately they are not quite local enough that I can just take them the plane!
I see from your pictures you had a piece of plywood at the tail end to support the fuselage.  How else did you support it on the bench?  I was planning to build an elaborate structure similar to the fuselage cradle but I see from your pictures that this is not necessary.
Graeme
On Sat, Dec 23, 2017 at 2:54 AM, Rick Stockton <aireupora(at)sbcglobal.net (aireupora(at)sbcglobal.net)> wrote:
 I did the high top MOD 64A, and am glad I did.  I also did MOD 67
I have a number of pictures and will attach some to this e-mail.
Rick Stockton
Europa N120EJ
Jabiru 3300 185 hours
JuliaScott
PostPosted: Sat Sep 14, 2019 7:36 am    Post subject: Re: Fwd: Top mod 65A Reply with quote
A forum of matrons is providing all the technical solutions for the citizens. The transfer of the skilled persons and sameday essay is upheld for the matronics in view of the true picture for the proponents. The change is welcomed for the authorities of the email for the matronics.
pjeffers(at)talktalk.net
PostPosted: Sun Sep 15, 2019 10:16 am    Post subject: Fwd: Top mod 65A Reply with quote
Hi,
Can anyone diagnose this e mail which I have now received about three times.
I think it may be wrongly addressed??
Pete
kingsnjan(at)westnet.com.
PostPosted: Mon Sep 16, 2019 12:21 am    Post subject: Fwd: Top mod 65A Reply with quote
Pete,
I suspect it is a good example of spam.  Me thinks the best way to
diagnose it is by pressing the 'DELETE KEY'!
Unfortunately there have been a couple of these sorts of postings of late.
Kingsley in Oz
On 15.09.19 10:57 pm, Pete Jeffers wrote:
Hi,
Pete
PostPosted: Mon Sep 16, 2019 7:52 am    Post subject: Fwd: Top mod 65A Reply with quote
Thanks Kingsley,
I think you may be right and I have already deleted it.
Pete
