duanefamly(at)aol.com Guest
Posted: Thu May 02, 2019 2:00 pm Post subject: Europa-List: Throttle Lever Housing for Jabiru engine |
Good day, Tony,
I am flying my Europa XS with the Jabiru 3300A. I kept it simple and used a vernier throttle control from ACS. I placed it on the forward part of the center console. I placed the carb heat and choke controls next to it. Works great for me.
https://www.aircraftspruce.com/catalog/appages/a750.php?clickkey=131607
Ignore the dual finger brakes. This pix was a record showing to NOT use these type knobs because they can get stuck like this and cause an issue. I simply went to straight knobs.
Hope this helps.
Mike Duane
N377EA Europa XS
Las Vegas, NV
Sent from Windows Mail
Sent: ‎Thursday‎, ‎May‎ ‎2‎, ‎2019 ‎1‎:‎58‎ ‎PM
--> Europa-List message posted by: "tonyvaccarella" <tony(at)weimagine.com.au>
Greetings from Down Under,
I'm at the point where I need to construct my throttle lever housing for my Jabiru powered Europa XS with Classic Wings. As I am unable to find a specific reference for Jabiru equipped aircraft in the builders manual, I would like to know if the throttle lever housing shown in the builder's manuals for the Rotax engines will also serve its purpose for my aircraft? I hope that those of you flying with the Jabiru engine can offer some advice.
Best regards,
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
http://forums.matronics.com/viewtopic.php?p=489067#489067
_-============================================================
_-= - The Europa-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Europa-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
1.49 MB |
8908 Time(s) |
tonyvaccarella
Posted: Thu May 02, 2019 2:59 pm Post subject: Re: Europa-List: Throttle Lever Housing for Jabiru engine |
Thank you for that advice Mike,
I will explore the possibility of vernier throttle control.
Best regards,
Tony
_________________ Tony Vaccarella
Mascot NSW 2020
Sydney Australia |
AirEupora
Posted: Fri May 03, 2019 6:10 am Post subject: Re: Europa-List: Throttle Lever Housing for Jabiru engine |
Almost any control will work. Take a look at the McFarlane Aviation Catalog. https://www.mcfarlaneaviation.com
The Bing Carb is sprung loaded to full throttle. So the cable needs to pull the throttle plate towards the rear. I used a Tee bar type of throttle with Carb heat. I like the feel, but would not recommend it as it was difficult to move out of the way for brake bleeding. My picture is to large for this program, I can sent it off-line.
Rick Stockton
2 MB |
8875 Time(s) |
2 MB |
8875 Time(s) |
tonyvaccarella
Posted: Sun May 05, 2019 1:31 pm Post subject: Re: Europa-List: Throttle Lever Housing for Jabiru engine |
Hi Rick,
I see your images. Thank you for those and I will have a look at the McFarlane vernier throttles. I appreciate your help.
Best regards
Tony
Mascot NSW 2020
Sydney Australia |
tonyvaccarella
Posted: Sun May 05, 2019 1:32 pm Post subject: Re: Europa-List: Throttle Lever Housing for Jabiru engine |
Hi Rick,
Best regards
Tony
Mascot NSW 2020
Sydney Australia |
