Retrofit door latch
Albert Gardner
PostPosted: Mon Apr 22, 2019 5:13 pm    Post subject: Retrofit door latch Reply with quote
Somebody makes a replacement door handle/latch that incorporates a cam style latch at the bottom of the door to pull it closed. I can't think of the names of supplier that make RV-10 door latches. Any help?
Albert Gardner
RV-10 N991RV
Yuma, Arizona
RV-9A N872RV
RV-10 N991RV
Tim Olson
PostPosted: Mon Apr 22, 2019 5:28 pm    Post subject: Retrofit door latch Reply with quote
Planearound.com is what you’re thinking of, I believe.
https://planearound.com/
On Apr 22, 2019, at 8:00 PM, Albert <ibspud(at)roadrunner.com (ibspud(at)roadrunner.com)> wrote:
<![endif]--> <![endif]-->
Albert Gardner
RV-10 N991RV
Yuma, Arizona
bill.peyton
PostPosted: Mon Apr 22, 2019 5:30 pm    Post subject: Re: Retrofit door latch Reply with quote
Shawn at planearound.com
Bill
WA0SYV
Aviation Partners, LLC
flysrv10(at)gmail.com
PostPosted: Tue Apr 23, 2019 3:30 am    Post subject: Retrofit door latch Reply with quote
Aerosport also make a beautiful door latch.
http://www.aerosportproducts.com/product/rv-10-low-profile-door-handle/
On Apr 22, 2019, at 9:27 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
Albert Gardner
RV-10 N991RV
Yuma, Arizona
Kellym
PostPosted: Tue Apr 23, 2019 4:14 am    Post subject: Retrofit door latch Reply with quote
Best solution, use both Planearound safety latch and Aerosport handle.
<mailto:Tim(at)myrv10.com>> wrote:
> Planearound.com <http://Planearound.com> is what you’re thinking of, I
> believe.
> Tim
>> latches. Any help?
>> Albert Gardner
>> RV-10 N991RV
>> Yuma, Arizona
Kelly McMullen
KCHD
Albert Gardner
PostPosted: Tue Apr 23, 2019 6:18 am    Post subject: Retrofit door latch Reply with quote
Thanks all for the information. Albert
RV-9A N872RV
RV-10 N991RV
