Klixon Circuit Breakers
billhuntersemail(at)gmail
PostPosted: Fri Mar 29, 2019 9:17 am    Post subject: Klixon Circuit Breakers Reply with quote
I am needing to replace a klixon 7277 circuit breaker and I see that they come in two varieties.
Does anybody know what the difference between the 7277 - 1 and the 7277 - 2 circuit breakers is?
Bill Hunter
jsajpf
PostPosted: Fri Mar 29, 2019 9:53 am    Post subject: Re: Klixon Circuit Breakers Reply with quote
Bill,
The -2 is a military spec grade device (tighter calibration limits) per the device data sheet found here: https://www.sensata.com/products/electrical-protection/7277-aircraft-circuit-breaker.
PostPosted: Fri Mar 29, 2019 10:03 am    Post subject: Klixon Circuit Breakers Reply with quote
I guess another way to explain is "the - 2 is more expensive"
John thanks for the quick reply in your help!
Bill Hunter
On Fri, Mar 29, 2019, 11:00 jsajpf <john.friday_adis(at)sbcglobal.net (john.friday_adis(at)sbcglobal.net)> wrote:
--> AeroElectric-List message posted by: "jsajpf" <john.friday_adis(at)sbcglobal.net (john.friday_adis(at)sbcglobal.net)>
Bill,
http://forums.matronics.com/viewtopic.php?p=488350#488350
harleydixon
PostPosted: Fri Mar 29, 2019 10:06 am    Post subject: Klixon Circuit Breakers Reply with quote
From Sensata (https://www.sensata.com/);
The military grade version of this circuit breaker is the Klixon® 7274- 2 series. The 7277 and 7274-2 series circuit breakers are physically and electrically identical, with the exception that the 7277 has wider calibration limits.
Harley
Bill Hunter
Harley Dixon
Long EZ N28EZ
Canandaigua Airport (D38)
Canandaigua, NY
PostPosted: Fri Mar 29, 2019 10:20 am    Post subject: Klixon Circuit Breakers Reply with quote
Looking at the Aircraft Spruce website the Klixon circuit breaker 7277-1-10 is $36 and the Klixon circuit breaker 7277-2-10 is only $21 so it seems to me that the - 2 would be lower quality and therefore lower cost.
Bill Hunter
On Fri, Mar 29, 2019, 11:11 Harley Dixon <harley(at)agelesswings.com (harley(at)agelesswings.com)> wrote:
Harley
Bill Hunter
jsajpf
PostPosted: Fri Mar 29, 2019 4:47 pm    Post subject: Re: Klixon Circuit Breakers Reply with quote
Bill,
I owe you an apology. The info I posted was incorrect due to my mis-reading of the web site info.
The 7277-1 contains an auxiliary circuit that closes when the CB trips. Ref. the drawings available on the Sensata site for the 7277 series breakers (https://www.sensata.com/sites/default/files/media/documents/ourproducts_AircraftCircuitBreaker_7277Series_7277-1-R_drawing_pdf.pdf) and (https://www.sensata.com/sites/default/files/media/documents/ourproducts_AircraftCircuitBreaker_7277Series_7277-2-P_drawing_pdf..pdf).
The aux circuit would be suitable for a CB monitoring system (i.e. Airbus a/c display cb status to the crew and annunciate a trip for critical systems).
Sorry for the confusion,
PostPosted: Fri Mar 29, 2019 6:02 pm    Post subject: Klixon Circuit Breakers Reply with quote
Not a problem... I was able to figure out that the - 2 was the cheaper so that is what I got... thanks again!!!
Bill Hunter
On Fri, Mar 29, 2019, 17:53 jsajpf <john.friday_adis(at)sbcglobal.net (john.friday_adis(at)sbcglobal.net)> wrote:
Bill,
http://forums.matronics.com/viewtopic.php?p=488359#488359
