FAA ID Data Plate
freddythek10(at)gmail.com
PostPosted: Mon Feb 11, 2019 12:55 pm    Post subject: FAA ID Data Plate Reply with quote
Builders in the US:
On the required “Experimental Amateur Built Aircraft” metal name plate, there is a line asking for the “Date of Mfg”.
Would that be the date of manufacture of the kit?…or the time frame of the “manufacture" of the work I’ve done assembling and finishing the kit?…or is the FAA looking for a completion-of-build date…?…
thanks,
Fred
bill mcclellan
PostPosted: Mon Feb 11, 2019 2:00 pm    Post subject: Re: FAA ID Data Plate Reply with quote
Fred, My FAA person said to use the date I completed. The FAA can be inconsistent so best to check what you FAA person wants before engraving. Bill
PostPosted: Mon Feb 11, 2019 3:22 pm    Post subject: FAA ID Data Plate Reply with quote
Thanks Bill…I’m guessing belated congratulations are in order for your first flight…if so…Great Work !! Fred
