Europa-List: FAA ID Data Plate
duanefamly(at)aol.com
PostPosted: Mon Feb 11, 2019 3:15 pm    Post subject: Europa-List: FAA ID Data Plate Reply with quote
Fred,   I would wait until you are â€ścompletely” finished with your build, you have completed your Appendix â€śE”, and have completed the official inspection. There may be something catastrophic found in either of the last two that could take you months to correct.
But, that’s just my opinion.
Mike Duane
N377EA Europa XS Conventional Gear
Las Vegas, NV
Sent from Windows Mail
Sent: â€ŽMonday‎, ‎February‎ ‎11‎, ‎2019 ‎12‎:‎54‎ ‎PM
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Builders in the US:
On the required “Experimental Amateur Built Aircraft” metal name plate, there is a line asking for the â€śDate of Mfg”.
Would that be the date of manufacture of the kit?…or the time frame of the â€śmanufacture" of the work I’ve done assembling and finishing the kit?…or is the FAA looking for a completion-of-build date…?…
thanks,
Fred
