kenryan
Posted: Mon Jan 28, 2019 2:18 pm Post subject: Battery |
Keep in mind that output is highly dependent upon sun angle (time of year, time of day) and cloud cover.
On Mon, Jan 28, 2019 at 12:37 PM Ernest Christley <echristley(at)att.net (echristley(at)att.net)> wrote:
Quote: |
Consider the following in conjunction with the charge controller. I'm limited to day-VFR, and my bladder keeps my flying legs down to 2 hours. My running current draw is somewhere down around 10 amps. With a couple of these plastered to the top of my wings, and a battery appropriately sized for a couple hours of runtime, would I EVER run out of electrons before fuel? At around $110, these would definitely be cheaper than a mechanical electron pusher. Without relays and crowbars, et. al., I would expect the wiring to be MUCH simpler. The weight is quoted as "less than 5 lbs", so lighter than all but the smallest of generators (?).
This would be a major departure from years of lessons learned in the aircraft community, but. . .
WindyNation 100 Watt 12V Flexible Solar Panel with Monocrystalline Solar Cells | eBay
$114.99
WindyNation 100 Watt 12V Flexible Solar Panel with Monocrystalline Solar...
WindyNation 1 00Watt (12 volt) Flexible Monocyrstalline Solar Panel with Monocrystalline Solar Cells. WindyNatio...
On Monday, January 28, 2019, 3:05:17 PM EST, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Quote: |
eBay thing 183558004137
It would appear that this specific one works with a sun-based contribution of 6 to 18
volts. There are unquestionably some shabby reasonable choices accessible for the
Do-It-Yourselfer.� Much more are accessible for Lithium batteries. |
These do look intereseting . . . I've got
some on order.
echristley(at)att.net Guest
Posted: Tue Jan 29, 2019 8:28 am Post subject: Battery |
Like I said, our current systems are built on a lifetime of experience. This is new technology that was not even thought of when many of the systems we take for granted were designed. Taking advantage of them safely will require extensive analysis of all costs vs benefits.
One question that comes to mind is, "Is it acceptable to manage battery life in the same way we manage fuel in the tank?"
On Monday, January 28, 2019, 5:19:33 PM EST, Ken Ryan <keninalaska(at)gmail.com> wrote:
$114.99
Quote: | eBay thing 183558004137 It would appear that this specific one works with a sun-based contribution of 6 to 18 volts. There are unquestionably some shabby reasonable choices accessible for the Do-It-Yourselfer.� Much more are accessible for Lithium batteries. | These do look intereseting . . . I've got some on order.
skywagon185(at)gmail.com Guest
Posted: Wed Feb 06, 2019 12:58 pm Post subject: Battery |
If. . . the solar panel is a low current variety, say 1 amp or less, I believe a simple zener diode across the output, at the right voltage, will just clip the voltage at what ever it chosen...Thus, no over charging of a full charged battery.
On Tue, Jan 22, 2019 at 6:12 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Quote: | At 07:44 PM 1/21/2019, you wrote:
Quote: | I learned today from EarthX that they are ok with using a small solar charger to charge their batteries, as long as it will NEVER exceed 14.6 volts. Their emphasis, not mine.They also stated that many solar units commonly are 15 volts or more and therefore not to be used with their batteries. |
Virtually ALL solar arrays offered to charge
12v batteries will have a full-sun, open-circuit
voltage in excess of 16 volts.
The 'small' arrays also have a rather large
internal impedance . . . meaning that the
output voltage falls off as load is increased.
But as any battery being charged with a 'barefoot'
solar array achieves full charge, flow of current
into the battery is not moderated.
The short story is that any solar array
being considered needs to have a significant
current capability . . . the wall-wart maintainers
are good for about 0.8A and WILL eventually
top off a rather large battery.
But to deliver 0.8A under marginal sun-light
conditions, the full-sun capability needs to
be 2x to 3x that amount . . . say 2.5A at
14 volts or about 35 watts.
Those cute little solar panels with cigar
lighter plugs are good for about 1-2 watts
and will MAINTAIN a fully charged battery.
But it takes a more robust device to serve
as replacement for the ship's engine driven
power source . . . i.e. top off a partially
discharged battery while hangared.
The more robust arrays need some form of
electronics to keep their full-sun performance
from beating up an already full-charge battery.
Posted: Wed Feb 06, 2019 4:37 pm Post subject: Battery |
At 02:57 PM 2/6/2019, you wrote:
Quote: | If. . . the solar panel is a low current variety, say 1 amp or less, I believe a simple zener diode across the output, at the right voltage, will just clip the voltage at what ever it chosen...Thus, no over charging of a full charged battery. |
Possibly . . . but what target votlage?
If you're asking the solar array to mainatain
a fully charged battery, then indeed a 13.0
volt zener would proably do.
But this thread started as an exploration of
using solar power sources to CHARGE the
battery in an airplane with no engine driven
power source. In this case, you need to clamp
off at 14.5 for a top-off interval and the
drop to the 13.0 sustaining voltage.
Further, charging a battery probably calls
for something larger than a 100mA solar
array . . .
Presumably, the solar battery smart charger
module cited earlier will hat-dance to the
right tune. Got on on order.
