Switch layout idea for z-13
Av8rrob
PostPosted: Wed Jan 16, 2019 8:37 pm    Post subject: Switch layout idea for z-13 Reply with quote
How does this switch layout look to you guys for a z-13 system. Two 3 position locking switches next to each other. The first one is labeled Battery with the position of OFF/ESS/MAIN. The second switch is labeled Alternator with positions 1/OFF/2. I like the idea of the simplicity of this. Any other thoughts?
ceengland7(at)gmail.com
PostPosted: Wed Jan 16, 2019 9:39 pm    Post subject: Switch layout idea for z-13 Reply with quote
Break something in the design and then figure out what you'll lose when it fails, and determine whether your backup plan can still function. For example, one of the switches comes apart. Will enough of the system still work to get you safely on the ground?
Charlie
On Jan 16, 2019, at 10:42 PM, Av8rrob <av8rrob(at)gmail.com (av8rrob(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: "Av8rrob" <av8rrob(at)gmail.com>How does this switch layout look to you guys for a z-13 system. Two 3 position locking switches next to each other. The first one is labeled Battery with the position of OFF/ESS/MAIN. The second switch is labeled Alternator with positions 1/OFF/2. I like the idea of the simplicity of this. Any other thoughts?Read this topic online here:http://forums.matronics.com/viewtopic.php?p=487042#487042http://www.matronics.com/Navigator?AeroElectric-Li= --> http://forums.ma --> http://wiki.matronics.matronics.com/contribution">http://www.matronics.com/contribution
