Garmin 430W error message on startup
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
recapen(at)earthlink.net
PostPosted: Sat Sep 29, 2018 6:05 am    Post subject: Garmin 430W error message on startup Reply with quote
Folks,
Every time I start my Garmin 430W, I get an error message that reads “FPL waypoint is locked” – after reading the message, it goes away. This recently started showing up so I think I may have changed a configuration or entered something that causes this.
Any ideas?
Thanks in advance,
Ralph Capen
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
daberti(at)sbcglobal.net
PostPosted: Sat Sep 29, 2018 7:45 am    Post subject: Garmin 430W error message on startup Reply with quote
It appears this message is generated when you have a saved flight plan with a waypoint that is no longer in the navigation database. This could also be a “user” waypoint.
Dave Alberti414-699-9312
On Sep 29, 2018, at 6:25 AM, Ralph E. Capen <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:
<![endif]--> <![endif]-->
Folks,
Any ideas?
Thanks in advance,
Ralph Capen
skywagon185(at)gmail.com
PostPosted: Sat Sep 29, 2018 8:11 am    Post subject: Garmin 430W error message on startup Reply with quote
Dave,
I have never seen this problem in the 430W.  However, you offered a great tip if I ever do as I have generated 100's of "User" waypoints that I use in some flight plans... Good Tip.
Dave
On Sat, Sep 29, 2018 at 8:44 AM Dave <daberti(at)sbcglobal.net (daberti(at)sbcglobal.net)> wrote:
Folks,
Any ideas?
Thanks in advance,
Ralph Capen
PostPosted: Sat Sep 29, 2018 10:07 am    Post subject: Garmin 430W error message on startup Reply with quote
OK – same answer from two places…
Gonna go through my FPL and look for LOKD
From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Dave
Sent: Saturday, September 29, 2018 11:44 AM
To: avionics-list(at)matronics.com
Subject: Re: Garmin 430W error message on startup
Dave Alberti
414-699-9312
Folks,
Any ideas?
Thanks in advance,
Ralph Capen
PostPosted: Mon Oct 01, 2018 9:47 am    Post subject: Garmin 430W error message on startup Reply with quote
That was the answer – I found a waypoint in two of my FPLs that were no longer in the Jeppesen database.
They were not user waypoints.
Thanks!
Dave Alberti
414-699-9312
Folks,
Any ideas?
Thanks in advance,
Ralph Capen
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
