billhuntersemail(at)gmail Guest
Posted: Thu Sep 13, 2018 5:52 pm Post subject: 240 VAC Motor Question |
Greetings,
This is a (slightly) off topic but I am reaching out to the smartest guys I
know regarding this stuff.
I am FINALLY getting around to wiring up the switch you all helped me find a
couple of months ago on my 2 post car lift (it is in an airplane hangar so
it is legal to post on this forum).
The car lift has an electric motor that drives a hydraulic pump. The
Normally Open switch when pushed starts the motor and the hydraulic pump
moves the car up. To lower the car there is a hydraulic pressure relief
valve meaning the motor/pump only operates one direction.
The black and white wires from my 2 pole circuit breaker panel and the green
bond wire are easy for me to figure out.
Inside the wiring box of the lift is a bit more complicated. Attached is a
picture of the schematic label on the side of the wiring box and a picture
of the relay unit housed inside the box.
Inside the wiring box there are the following wires:
-Green + yellow stripe wire that has a ground lug on the motor case and a
the other end is a loose end.
-Green wire that has a lug on one end and the other end enters the internals
of the relay box
-Blue wire that is loose on one end and the other end enters the internals
of the relay box.
-Brown wire that goes to the 5/L3 lug of the relay unit and the other end is
a loose end.
-Brown wire that has a lug on one end and the other end is a loose end
Can someone please help me "remember" what wires go to what on this
contraption???
I would GREATLY APPRECIATE your help on this!!!
BARRY CHECK 6
Posted: Thu Sep 13, 2018 6:31 pm Post subject: 240 VAC Motor Question |
Bill:
It is a lot easier with the units in front of me, but...
Here is a link that supports the colors you mention.
Oh, there are two standards in wiring motors:
1 - Wire Color Code - Which is not used very much and
2 - Wire Numbering - Much easier to understand.
This link shows the color code you are seeing:
https://www.doityourself.com/forum/electrical-ac-dc/396012-bodine-electric-motor-wiring.html
For a 220 AC Line:
T1 goes to L1
T4 & T5 go to L2
ALL the other wires get tied together and wire nutted and electrical tape wrapped.
I need better pictures or schematic of the relay.
But, Since as you say the Motor is ONLY powered and in one direction the relay is used to control that applied power as stated above.
Just tie the lines together through the relay so :
1 - A switch energizes the relay.
2 - L1 and L2 Go to each 110 V lines (110 + 110 = 220)
Hope this helps.
Barry
On Thu, Sep 13, 2018 at 9:58 PM <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
Quote: |
Greetings,
This is a (slightly) off topic but I am reaching out to the smartest guys I know regarding this stuff…
I am FINALLY getting around to wiring up the switch you all helped me find a couple of months ago on my 2 post car lift (it is in an airplane hangar so it is legal to post on this forum).
The car lift has an electric motor that drives a hydraulic pump. The Normally Open switch when pushed starts the motor and the hydraulic pump moves the car up. To lower the car there is a hydraulic pressure relief valve meaning the motor/pump only operates one direction.
The black and white wires from my 2 pole circuit breaker panel and the green bond wire are easy for me to figure out.
Inside the wiring box of the lift is a bit more complicated. Attached is a picture of the schematic label on the side of the wiring box and a picture of the relay unit housed inside the box.
-Green + yellow stripe wire that has a ground lug on the motor case and a the other end is a loose end.
-Green wire that has a lug on one end and the other end enters the internals of the relay box
-Blue wire that is loose on one end and the other end enters the internals of the relay box.
-Brown wire that goes to the 5/L3 lug of the relay unit and the other end is a loose end.
Can someone please help me “remember” what wires go to what on this contraption???
Bill Hunter
Joined: 28 Mar 2008 Posts: 1910 Location: Riley TWP Michigan
Posted: Thu Sep 13, 2018 6:35 pm Post subject: Re: 240 VAC Motor Question |
Bill,
There are no pictures attached to your post.
_________________ Joe Gores |
Posted: Fri Sep 14, 2018 7:42 am Post subject: 240 VAC Motor Question |
Quote: | There are no pictures attached to your post.
Hmmm...perhaps due to file size I should send them one at a time (sorry for
the spam)>
Posted: Fri Sep 14, 2018 7:43 am Post subject: 240 VAC Motor Question |
Here is the inside of the box
Posted: Fri Sep 14, 2018 7:45 am Post subject: 240 VAC Motor Question |
Here is a closer view of the relay itself.
Again...THANKS for your help on this (as always)!!!
harleydixon
Joined: 17 Sep 2016 Posts: 18 Location: Henrietta, NY
Posted: Fri Sep 14, 2018 7:48 am Post subject: 240 VAC Motor Question |
Just an FYI Bill, I did have the pictures along with your first message...using Thunderbird if that makes any difference.
Harley
On 9/14/2018 11:42 AM, billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com) wrote:
[quote] [quote]Here is the inside of the box
_________________ Harley Dixon
Long EZ N28EZ
Canandaigua Airport (D38)
Canandaigua, NY |
Bob McC
Posted: Fri Sep 14, 2018 8:08 am Post subject: 240 VAC Motor Question |
Both pictures were attached to the original post that I received.
Bob McC [quote]
_________________ Bob McC
Falco #908
(just starting) |
ceengland7(at)gmail.com Guest
Posted: Fri Sep 14, 2018 9:18 am Post subject: 240 VAC Motor Question |
On 9/14/2018 10:48 AM, Harley Dixon wrote:
Quote: | Just an FYI Bill, I did have the pictures along with your first message...using Thunderbird if that makes any difference.
Harley
| Same here, on both counts.
donjohnston
Posted: Sun Sep 16, 2018 2:28 am Post subject: Re: 240 VAC Motor Question |
I'm reading these on the website and there are no pictures.
