Seeking DB15 breakout / tester box
art(at)zemon.name
PostPosted: Mon Aug 20, 2018 4:27 am    Post subject: Seeking DB15 breakout / tester box Reply with quote
Folks,
I have an RS232 problem between my EFIS and my nav/comm radios and I am looking for a DB15 breakout box / tester box. Something like this https://www.viewpointusa.com/product/breakout-boards/15-pin-breakout-interface/ but for a few dollars, not $95
There are cheap versions for DB25 but I'm having trouble finding a DB15 flavor. Any ideas?
    -- Art Z.
https://CheerfulCurmudgeon.com/"We do not see the world as it is. We see the world as we are."
BARRY CHECK 6
PostPosted: Mon Aug 20, 2018 4:49 am    Post subject: Seeking DB15 breakout / tester box Reply with quote
Art:
Don't go crazy with a One Time Use breakout box (B.O.B.).
Get a breadboard and build your own B.O.B..
You should be able to find all the parts for $35.
And...   Once you are done with that project you will have the ability to build more and different projects.
Good breadboards have a Power Strip so hookups are even easier.
https://www.domirobot.com/matsuhama-birlesik-breadboard-1700-pin-pmu392
Barry
On Mon, Aug 20, 2018 at 8:33 AM Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Folks,
    -- Art Z.
PostPosted: Mon Aug 20, 2018 6:13 am    Post subject: Re: Seeking DB15 breakout / tester box Reply with quote
Try searching eBay for "DB15 Y".
Joe Gores
Eric Page
PostPosted: Mon Aug 20, 2018 6:51 am    Post subject: Seeking DB15 breakout / tester box Reply with quote
Art,
I couldn’t find a U.S. seller so you may have to wait a few weeks for delivery, but I think this is what you’re looking for:
https://www.ebay.com/itm/371146139444
A terminal block isn’t the best connector for a logic probe, but short lengths of wire should make a workable interface.
Eric
On Aug 20, 2018, at 05:20, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Folks,
-- Art Z.
PostPosted: Mon Aug 20, 2018 2:19 pm    Post subject: Seeking DB15 breakout / tester box Reply with quote
I've built several over the years. Here's
one cheap-n-dirty approach
https://goo.gl/GBSRVo
If you're in a big hurry and have access
to solder cup connectors, you can hard-wire
one in about 20 minutes with a bit of 22aWG
wire and a soldering iron.
Let me dig around in the junk box . . . I may
have one already built up . . . which you
can have it it exists.
henador_titzoff(at)yahoo.
PostPosted: Mon Aug 20, 2018 2:51 pm    Post subject: Seeking DB15 breakout / tester box Reply with quote
Just out of curiosity, Art, what kind of problem are you having with the RS-232 link between the EFIS and radios? Is it a consistent failure or a glitch. If it's a glitch, can you tie it to an action or is it a random anomaly? What is the frequency of occurrence?
Henador Titzoff
On Monday, August 20, 2018, 8:44:06 AM EDT, Art Zemon <art(at)zemon.name> wrote:
Folks,
-- Art Z.
PostPosted: Mon Aug 20, 2018 5:49 pm    Post subject: Seeking DB15 breakout / tester box Reply with quote
Couldn't put my hands on it. Here's
the parts in state-side stock.
https://goo.gl/i31NnY
https://goo.gl/4k3MMi
I can send you a chunk of .05" pitch ribbon
cable if you don't have any.
art(at)zemon.name
PostPosted: Mon Aug 20, 2018 6:29 pm    Post subject: Seeking DB15 breakout / tester box Reply with quote
Thanks for checking, Bob. DB25 breakouts are like $4-6 and readily available. I was hoping to find a DB15 and save myself some time. I guess I'll have to make one Smile
    -- Art Z.
On Mon, Aug 20, 2018 at 9:05 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
donjohnston
PostPosted: Wed Aug 22, 2018 1:16 pm    Post subject: Re: Seeking DB15 breakout / tester box Reply with quote
Art,
I had a similar issue a little while back (mine was a DB-9). What I ended up doing is making a pair of DB-25 to DB-9 patch. Fortunately, I had the parts so it just took a little time and was all set.
Don
