Tim Olson
Posted: Tue Aug 14, 2018 9:59 am Post subject: Elevator Pushrod Rod End |
Hey all,
I know I've heard of this happening with at least 1 other builder (I
think 2) that I know of. There's a thread on VAF where Scott
says it's the "first time" as we generally hear.
http://www.vansairforce.com/community/showthread.php?p=1280755#post1280755
I'd like to remember who it was that all reported this issue
where the elevator rod end unscrewed after the safety wire
broke.
Anyone?
Bob Turner
Joined: 03 Jan 2009 Posts: 881 Location: Castro Valley, CA
Posted: Tue Aug 14, 2018 4:08 pm Post subject: Re: Elevator Pushrod Rod End |
Tim,
I think the title is a bit misleading. It’s a pushrod in the elevator control system, but the rod end bearing in question is at the front, near the stick, not near the elevator.
_________________ Bob Turner
RV-10 QB |
davehead
Posted: Wed Aug 15, 2018 1:23 pm Post subject: Re: Elevator Pushrod Rod End |
My elevator rod end (forward end) did not unscrew, but I did find the safety wire broke after about 2 years of flying. The jam nut was still tight so the bearing did not unscrew from the pushrod. I concluded that I had installed the safety wire too tight ….. I’m not saying it was twisted too many turns per inch, but I suspect that I had stretched it too tight from where it attaches to the end of the pushrod, to the AN4 bolt that captures it at the rod-end bearing. The wire might have become pinched or chafed between the bearing and the Control Column clevis. Or movement of the pushrod and Control Column might impose some extra stretch at certain extreme positions. So I reinstalled the safety wire with a little slack, and it’s been OK for about 4 years now.
--Dave
RV10
Bob Turner
Posted: Wed Aug 15, 2018 2:57 pm Post subject: Re: Elevator Pushrod Rod End |
davehead wrote: | The wire might have become pinched or chafed between the bearing and the Control Column clevis. Or movement of the pushrod and Control Column might impose some extra stretch at certain extreme positions.
RV10 |
Hi Dave!
I think that if you think about this very carefully, you'll see that if the safety wire was installed properly (not pinched by the clevis and rod end) then it does not stretch with control movement. But if it was pinned between the clevis and rod end, then it is possible for it to stretch and also flex with control movement. The wire should not go over the AN bolt; it should go completely around the inner part of the rod end, up against the outer bearing race. In this position there should be no force on the wire, despite control movement, unless the jam nuts fail to do their job.
Do you recall where your wire originally broke? And were you able to pull the wire out of the clevis/rod end with minimal force, or was it pinched in there?
I'm wondering if, next time I'm in there, I should back off the jam nuts and re-install with locktite?
Bob
RV-10 QB |
