Can You PLEASE help Me Find a CHINT NP4 Switch (or equiva
PostPosted: Sat Jul 28, 2018 7:28 pm    Post subject: Can You PLEASE help Me Find a CHINT NP4 Switch (or equiva Reply with quote
You might want to recheck that ebay link. When I click it, I get an emergency stop switch. The industrial E-stop switches I've worked with latch down, opening the safety interlock line and closing a pair of contacts used for monitoring the safety loop. They must be either pulled or rotated back to 'normal' position. The one pictured has circular arrows on the button, which indicates that it latches down and must be rotated to release. The text at the bottom of the listing says that, too. If he's replacing a momentary PB, things could get interesting if he doesn't notice how to release the button.
Charlie
Good catch Charlie. I missed that. Perhaps this
is a bettery options
https://goo.gl/R5rAdN
PostPosted: Sat Jul 28, 2018 7:29 pm    Post subject: Can You PLEASE help Me Find a CHINT NP4 Switch (or equiva Reply with quote
At 06:59 PM 7/28/2018, you wrote:
The same seller on eBay had the switch I needed so I will swap the emergency stop switch for this one
https://m.ebay.com/itm/NEW-TWO-2-Push-Button-Switch-Momentary-Press-Switch-Heavy-Duty/170614528296?hash=item27b96b1928%3Ag%3AOUQAAOxyjzNRF4x~&_pgn=1&rt=nc
Thanks again for all your help!
Bill Hunter
Sounds like you guys got it under control . . .
that's how this List rolls!
