blues750
Posted: Fri Jul 20, 2018 7:38 pm Post subject: MANL's (current limiters) |
Are MANLs standard size, standard specs other than Amp rating? I have one and would like to have one or two on hand, but really don't know how to source without some sort of spec -- Thanks!
P.S. 'Lectric Bob if you read this, I am trying to match the one I received from you in the care package recently. There are no markings other than amp rating...how do I spec it other than Amps?
Cheers! Dave
Posted: Sat Jul 21, 2018 11:47 am Post subject: MANL's (current limiters) |
At 10:38 PM 7/20/2018, you wrote:
Quote: | --> AeroElectric-List message posted by: "blues750" <den_beaulieu(at)yahoo.com>
Are MANL standard size, standard specs other than Amp rating? I have one and would like to have one or two on hand, but really don't know how to source without some sort of spec -- Thanks!
P.S. 'Lectric Bob if you read this, I am trying to match the one I received from you in the care package recently. How do I spec it othe than Amps?
The MANL series of limiters are commercial-off-the-shelf
products. They are made by virtually every top tier
line of suppliers but with different part/model numbers.
Here's a MIDI spec sheet from Littlefuse . . .
https://goo.gl/hiUBir
Bottom line is that unlike 'fuses' that are more
carefully crafted for thermal dynamics, these
critters are more like "fusible links" . . . they
are expected to clear hard faults (hundreds to
thousands of amps of fault current).
For our purposes, anything you can find with
an appropriate rating and 30MM hole spacing
will do fine. Most automotive applications call
for really fat rascals . . . 60 amps or more.
So Smiley Jack's Car Parts Emporium is problematic,
try these.
https://goo.gl/dXkrH4
blues750
Posted: Tue Jul 24, 2018 5:41 pm Post subject: Re: MANL's (current limiters) |
Thanks for the reply Bob!
johnbright
Joined: 14 Dec 2011 Posts: 165 Location: Newport News, VA
Posted: Thu May 07, 2020 8:51 am Post subject: Re: MANL's (current limiters) |
FYI MIDIs from Littlefuse... formerly smallest was 30A... now smallest is 23A.
https://www.littelfuse.com/~/media/automotive/datasheets/fuses/passenger-car-and-commercial-vehicle/bolt-down-fuses/littelfuse_midi_datasheet.pdf
_________________ John Bright, RV-6A, at FWF, O-360
Z-101 single batt dual alt SDS EM-5-F.
john_s_bright@yahoo.com, Newport News, Va
N1921R links |
