Run-Away Trim
fdavis101454(at)gmail.com
PostPosted: Sat Jun 23, 2018 4:35 pm    Post subject: Run-Away Trim Reply with quote
I've had run-away trim. I was on downwind in a Piper Arrow when the nose started to pitch downward. I looked and saw the trim wheel spinning away. I grabbed it, which is the response in a piper, while the CFI with me pulled the breaker. Retrimmed and landed normally.
Jim Combs
PostPosted: Sat Jun 23, 2018 4:44 pm    Post subject: Run-Away Trim Reply with quote
Glad you had a good outcome.  Bad timing on the approach.
On Sat, Jun 23, 2018 at 8:32 PM, Frank Davis <fdavis101454(at)gmail.com (fdavis101454(at)gmail.com)> wrote:
RV-10 -> N312F - Flying as of 12/2008
