WIFI Repeater/Booster Options For My Remote Steel Hangar??
PostPosted: Fri May 25, 2018 6:07 am    Post subject: WIFI Repeater/Booster Options For My Remote Steel Hangar?? Reply with quote
My steel hangar is about 50 feet away and there is cement and asphalt over the ground between the house and the hangar so to dig down and install a CAT 5 cable run out to the hangar is not a fun option.
Are there any WIFI extender options available to get WIFI out to the hangar?
I presume you have AC power in the hangar. I'm also
hoping that the feeder comes off a breaker in your
house. If so, you might consider a product like
this:
https://goo.gl/srUq55
Asoka is not the only supplier of such devices.
These are power line connected cat5 transceivers.
Put one in the house with a jumper to your
router and the second in the hangar.
I've been using these things around here
for several years . . . saved me a lot
of time/effort stringing wire. I've got
a couple of surplus devices I could
send you to experiment with.
But if your hangar doesn't get ac power from
the house distribution panel . . . all bets
are off.
