AeroElectric-List Digest: 12 Msgs - 01/03/18
sneekg(at)hotmail.com
PostPosted: Sat Jan 06, 2018 3:22 pm    Post subject: AeroElectric-List Digest: 12 Msgs - 01/03/18 Reply with quote
Please remove me from your email list.thank you.
Get Outlook for Android
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> on behalf of AeroElectric-List Digest Server <aeroelectric-list(at)matronics.com>
Sent: Thursday, January 4, 2018 1:30:38 AM
To: AeroElectric-List Digest List
Subject: AeroElectric-List Digest: 12 Msgs - 01/03/18
Today's complete AeroElectric-List Digest can also be found in either of the
of the AeroElectric-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2018-01-03&Archive=AeroElectric
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2018-01-03&Archive=AeroElectric
  AeroElectric-List Digest Archive
  Total Messages Posted Wed 01/03/18: 12
Today's Message Index:
1. 02:42 AM - Re: Re: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind (Bob Verwey)
2. 07:27 AM - Re: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind (user9253)
3. 07:48 AM - Re: Re: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind (C&K)
4. 08:47 AM - Re: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind (user9253)
5. 08:56 AM - Re: Tech Edge "MODA" Fuel Level Probe (Robert L. Nuckolls, III)
6. 09:38 AM - Re: Re: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind (Robert L. Nuckolls, III)
7. 09:38 AM - Re: Tech Edge "MODA" Fuel Level Probe (addendum) (Robert L. Nuckolls, III)
8. 10:58 AM - Re: Tech Edge "MODA" Fuel Level Probe ()
9. 11:49 AM - Re: Tech Edge "MODA" Fuel Level Probe (Rene)
10. 12:13 PM - Re: Tech Edge "MODA" Fuel Level Probe (addendum) (Christopher Cee Stone)
11. 06:05 PM - Re: Tech Edge "MODA" Fuel Level Probe (addendum) (William Hunter)
12. 07:18 PM - Re: Tech Edge "MODA" Fuel Level Probe (addendum) (Bill Maxwell)
Time: 02:42:53 AM PST US
Subject: Re: Re: Simplest way for a go/no-go 2-Stroke  Engine
Temperature Ind
Joe is the operating voltage not an issue?
On 02 Jan 2018 8:33 PM, "user9253" <fransew(at)gmail.com> wrote:
> Perhaps some kind of temperature switch would work?
> https://www.omega.com/pptst/TSW-TT.html
> Joe Gores
> http://forums.matronics.com/viewtopic.php?p=477017#477017
Time: 07:27:33 AM PST US
Subject: Re: Simplest way for a go/no-go 2-Stroke Engine Temperature
Ind
No, the operating voltage is not a concern. The switch is rated for 2 amps at
24 VDC. That probably equates to 3 or 4 amps at 12 volts. If an indicator lamp
is chosen that uses less than 1 amp, it should be fine. The switch is available
as either normally open or normally closed. There is a 50-50 chance of
getting it right. The original poster probably wants the normally closed switch.
Another concern is selecting the correct operating temperature. And there
is the life expectancy issue when subject to the vibration of a 2 cycle engine.
Joe Gores
http://forums.matronics.com/viewtopic.php?p=477046#477046
Time: 07:48:51 AM PST US
Temperature Ind
A tiny keychain size infra red thermometers for $12. might be more
useful and less trouble to set up.
No calibration issues and fairly vibration resistant.
Remote mounting of the display might be possible.
https://www.ebay.com/itm/Mini-Digital-Non-Contact-IR-Infrared-LCD-Thermometer-DT-300-Black-UD6-LD/161818543747?hash=item25ad230683:g:SbkAAOSw0JpV7YxU
Ken
________________________________ Message 4 _____________________________________
Time: 08:47:46 AM PST US
Ind
Is it feasible to mount the infrared red thermometer, suggested by YellowDuck,
inside of the cockpit and use a fiber optic cable to transmit the engine heat
through the firewall to the thermometer?
Joe Gores
http://forums.matronics.com/viewtopic.php?p=477049#477049
________________________________ Message 5 _____________________________________
Time: 08:56:28 AM PST US
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Subject: Re: Tech Edge "MODA" Fuel Level Probe
At 11:01 AM 1/2/2018, you wrote:
><billhuntersemail(at)gmail.com>
>Hi All,
>I've been working like crazy on my project and am getting ready to fly soon!!!
>One obstacle (among many) is a solution to my header tank fuel level
>sensor. I have a 5 gallon fiberglass header tank that the two wing
>tanks gravity flow into and then the engine uses this header tank as
>its sole source of fuel so it is good to know if this header tank is
>full. It had an ON/OFF float switch however that switch is no
>longer working and I tried to unscrew the float switch to replace it
>however it is so tight that I am worried the plastic body/hex nut
>will break off so it is best at this point to just leave it
>installed as a "plug" and pursue another solution.
>Has anyone used a MODA tank sensor kit from tankedge.com ?
>https://tankedge.com/accessories.html
>It is a sensor that attaches to the outside of a fiberglass tank
>with dual parallel strips of aluminum and copper tape. Somehow it
>measures the resistance between the two strips and determines the
>fuel quantity on the other side of the tank wall.
This is probably an adaptation of the 'capacity
sensor' widely used on touch pads for manual controll
inputs. It senses a change in capacity. The two
electrodes attached to the outside of the tank form
a capacitor in which the dielectric is composed of
tank material and air.
When fuel fills up the air space, the capacitance
goes up sharply and the electronics senses this. For
metal tanks, they need to penetrate the tank wall
to get at the change in air-to-fuel capacitance.
________________________________ Message 6 _____________________________________
Time: 09:38:58 AM PST US
Temperature Ind
At 08:39 PM 1/2/2018, you wrote:
><ceengland7(at)gmail.com>
>>Joe Gores
>I like Joe's find. Still have to watch the max temp, though.
Another option uses the Analog Devices thermocouple
conditioners in a on-off switching mode.
https://goo.gl/7ufeaL
Here's a simplified schematic . . .
Emacs!
Instead of driving a heater control relay, one could
drive an LED indicator light directly from the
signal conditioner's output . . .
This would let you connect directly to the cylinder
head with appropriate thermocouple material.
________________________________ Message 7 _____________________________________
Time: 09:38:59 AM PST US
Subject: Re: Tech Edge "MODA" Fuel Level Probe (addendum)
Okay, looking closer reveals that this is a
capacity fuel gaging system, not just a level
sensor. There is a whole new class of liquid level
capacity transducer products out there.
Recent developments in resolving capacity has
spawned a variety of low cost instruments that
will measure capacitance with good accuracy
down into the picoFarads territory.
There's a pretty simple methodology for using
pic/arduino DIY processors to implement your own
capacity liquid level measurement system wherein
the sensor is nothing more than a twisted pair of
wires with insulation impervious to the liquid being
sensed.
For the product cited above, the sensor is either
copper foil electrodes on the outside of the plastic
tank . . . or some analog built into the
probe.
This could be paired with a comparator that drives
a 'tank full' indicator light.
________________________________ Message 8 _____________________________________
Time: 10:58:46 AM PST US
Subject: RE: Tech Edge "MODA" Fuel Level Probe
How about using this:
http://www.beliteaircraftstore.com/bingo-liquid-detector/
It was designed for this exact purchase, and Jim Wiebe (designer/owner)
created it to indicate when a specific "bingo" (low fuel) level occurred
in header tanks and in-wing fuel tanks, as a backup to the fuel gauges.
(He has some pretty terrific fuel level sensors, as well for the
experimental crowd.)
You install this detector at whatever level in the fuel tank you choose,
and it alerts you when the liquid level drops below that point. The LED
indicator is normally green when the level is above the "bingo" level,
and if/when it drops below that point, it flashes red for 10 seconds,
then goes solid red.
Installation seems dirt simple, and it seems to work with just about any
liquid. There's a video demonstrating it on that page also. Currently
on sale for $69.95.
Jim Parker
________________________________ Message 9 _____________________________________
Time: 11:49:30 AM PST US
I have a system similar to that in my RV-10. 1 in each tank at the 3 gallon level.
Only really use it when I want to run a tank dry. If the tank sloshes,
then I do get some false alarms when it is bumpy. I use my float gages to alarm
at 5 gallons left.
Rene'
801-721-6080
