Simple temperature controlled switch
PostPosted: Thu Jan 04, 2018 7:58 am    Post subject: Simple temperature controlled switch Reply with quote
At 07:37 AM 1/4/2018, you wrote:
To: <aeroelectric-list(at)matronics.com>
Subject: Simple temperature controlled switch
Hi there
Speaking of temperature control, can someone please point me out to a simple & cheap temperature controlled switch?
The idea is just to turn on and off a pair of cooling fans I have in the dashboard, depending on the air temperature behind the avionics.
Carlos
There are many options for thermo-mechanical switches
(thermostats) like these on eBay.
https://goo.gl/5XP2ed
Then, for just a few dollars more, there are adjustable,
thermostats that can be set up for either close on rise,
or close on fall. Further, they can be tweaked for the
operating set point.
https://goo.gl/mfmzo7
trigo(at)mail.telepac.pt
PostPosted: Thu Jan 04, 2018 10:04 am    Post subject: Simple temperature controlled switch Reply with quote
Thanks Bob
Exactly what I need.
(With the profusion of things on sale on eBay and the such, it is not easy to find the most appropriate)
Cheers
Carlos
Enviado do meu iPhone
No dia 04/01/2018, às 15:58, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> escreveu:
From: "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)>
To: <aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)>
Hi there
Carlos
