Simplest way for a go/no-go 2-Stroke Engine Temperature Ind
ceengland7(at)gmail.com
PostPosted: Tue Jan 02, 2018 6:34 pm    Post subject: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind Reply with quote
On 1/2/2018 12:26 PM, user9253 wrote:
Perhaps some kind of temperature switch would work?
https://www.omega.com/pptst/TSW-TT.html
Joe Gores
I like Joe's find. Still have to watch the max temp, though.
email(at)jaredyates.com
PostPosted: Tue Jan 02, 2018 7:18 pm    Post subject: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind Reply with quote
I like the temperature switch very much, thanks! Now I just need a little trial and error to sort out the right temperature range.
On Tue, Jan 2, 2018 at 9:39 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
Joe Gores
bob.verwey(at)gmail.com
PostPosted: Wed Jan 03, 2018 2:42 am    Post subject: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind Reply with quote
Joe is the operating voltage not an issue?
On 02 Jan 2018 8:33 PM, "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=477017#477017
PostPosted: Wed Jan 03, 2018 7:26 am    Post subject: Re: Simplest way for a go/no-go 2-Stroke Engine Temperature Reply with quote
No, the operating voltage is not a concern. The switch is rated for 2 amps at 24 VDC. That probably equates to 3 or 4 amps at 12 volts. If an indicator lamp is chosen that uses less than 1 amp, it should be fine. The switch is available as either normally open or normally closed. There is a 50-50 chance of getting it right. The original poster probably wants the normally closed switch. Another concern is selecting the correct operating temperature. And there is the life expectancy issue when subject to the vibration of a 2 cycle engine.
Joe Gores
yellowduckduo(at)gmail.co
PostPosted: Wed Jan 03, 2018 7:48 am    Post subject: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind Reply with quote
A tiny keychain size infra red thermometers for $12. might be more
useful and less trouble to set up.
No calibration issues and fairly vibration resistant.
Remote mounting of the display might be possible.
https://www.ebay.com/itm/Mini-Digital-Non-Contact-IR-Infrared-LCD-Thermometer-DT-300-Black-UD6-LD/161818543747?hash=item25ad230683:g:SbkAAOSw0JpV7YxU
Ken
PostPosted: Wed Jan 03, 2018 8:47 am    Post subject: Re: Simplest way for a go/no-go 2-Stroke Engine Temperature Reply with quote
Is it feasible to mount the infrared red thermometer, suggested by YellowDuck, inside of the cockpit and use a fiber optic cable to transmit the engine heat through the firewall to the thermometer?
Joe Gores
