Generator to Alt on Cessna210
ronburnett(at)charter.net
PostPosted: Wed Nov 15, 2017 10:37 am    Post subject: Generator to Alt on Cessna210 Reply with quote
A friend is replacing his generator with a certified Plane Power Alternator and PP regulator. We are wondering if the noise filter is built in the FAA/PMA alternator?
If so, the fat wires from the alternator could be bolted to the fat wire from the noise filter that runs to the panel.
This is a PMA approved part and will be signed off and inspected. My friend is trying to do the hook up beforehand.
Thanks for any help
Ron Burnett
May you have the Lord's blessings today!
Sent from my iPad
PostPosted: Wed Nov 15, 2017 11:31 am    Post subject: Generator to Alt on Cessna210 Reply with quote
At 12:15 PM 11/15/2017, you wrote:
--> AeroElectric-List message posted by: Ron Burnett <ronburnett(at)charter.net>
If no noise filter is supplied, then it's
presumed not necessary unless demonstrated
in subsequent flight testing.
Install per instructions which are part
of the STC/PMA . . . if no noise filter is
included then it's not necessary.
