LOM Magneto and Shower of Sparks on Z-18
mike(at)vision499.com
PostPosted: Wed Oct 25, 2017 4:11 pm    Post subject: LOM Magneto and Shower of Sparks on Z-18 Reply with quote
I have LOM engine and have a few questions regarding Z-18
What purpose does the filter F526.910-03 serve, is there anything else available that will serve the same purpose if it is an essential item?
The Magneto’s that are on my engine do not have a retard terminal as shown in the Shower of sparks article, is the LOM magneto different?
I have the starting vibrator LUN 2231 as described on Z-18, should I wire it into the single terminal on the Magneto?
Mike
PostPosted: Thu Oct 26, 2017 7:20 am    Post subject: LOM Magneto and Shower of Sparks on Z-18 Reply with quote
Those are probably a 'generic' magneto p-lead filter. Leave
these off until you know you need them. They're easy to add
if you discover magneto noise in the radios.
Single point magnetos can use vibrator-enhanced
cranking performance if they are fitted with
IMPULSE couplers . . . which have the same effect
as a set of delayed points.
Yes, wire as as shown in Z18.[url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
