Dual Power Inputs, Dual Buss Electrical System
mikeeasley(at)aol.com
PostPosted: Wed Oct 11, 2017 5:39 am    Post subject: Dual Power Inputs, Dual Buss Electrical System Reply with quote
I’m redoing my panel in my aircraft which I built 15 years ago with a Z-14 electrical system. I’m installing a Garmin G3X panel and all the associated boxes. Most of them have the capability to wire for 2 separate power sources. With dual buss with crossfeed, I’m wondering if there is any significant benefit to having two CBs and two power feeds. I can think of a couple failure modes, but they seem remote. There is also a configuration using a backup battery on the second power feed, maybe that’s a better choice. Thanks in advance for the feedback.
Mauledriver(at)nc.rr.com
PostPosted: Thu Oct 12, 2017 7:54 am    Post subject: Dual Power Inputs, Dual Buss Electrical System Reply with quote
On 10/11/2017 11:09 AM, Robert L. Nuckolls, III wrote:
  With two batteries, two alternators and crossfeed,
  there is no value in exploiting the redundancy
  features you cited. Z14 has all that stuff built
  in.
I have a Z-14 and agree.  There are even some potential disadvantages.
I originally connected my (3) GRT EFISs to one bus and not incidentally, the engine starter circuit to the other bus.  That configuration combined with an inadequate light weight starter originally supplied with the 6 cylinder IO-540 on the RV-10, meant that cross fed starts would sometimes reboot the GRTs.  And starting with just 1 battery was marginal  in cold weather.  Given that I had no on/off switch for the GRTs, this was inconvenient given the boot time required.  And it turned out that early versions of the GRT code did not like to have their boot sequence interrupted though that problem was fixed in later releases of the code.
Ideally as Bob has explained, one wants to start with the batteries cross-fed to keep stress on the batteries to a minimum.  Then to do normal flight operations with 2 separate buses which makes any failure identification easier and would keep any damaging component isolated.
The other capability I wanted from my Z-14 was to be able to run my panel for an extended period of time on occasion without concern for having enough juice for a subsequent engine start.  this is where the main disadvantage might lie.  The GRTs are capable of connecting to up to 3 power supplies.  At one point I used 2 of those inputs to connect them to both buses.  That was a mistake because I found that my ability to run the panel for an extended period was diminished.  That created several problematic scenarios that I just shouldn't have had to deal with.
In other words, the Z-14 gave me a lot of flexibility as long as I connect individual components to one bus or the other.  It allows one to identify and isolate problem components and  flexibly manage one's batteries if desired.  If you crossfeed individual components at the component, you give some of that capability away with little if anything gained.
Post Script: Replacing the starter eliminated all problems with cross fed and single battery starts.  Returning to a single power supply on a single bus for each GRT gave me back the battery management flexibility.
Bill "I love my Z-14" Watson
PostPosted: Fri Oct 13, 2017 9:38 am    Post subject: Dual Power Inputs, Dual Buss Electrical System Reply with quote
  Bill mentions a starter replacement . . . what
  kind of starter was removed and what was
  the replacement?
The starter that was removed was the Sky-Tec 149-12LS Flyweight Starter.
I replaced it with the Sky-Tec 149NL.
The LS came as the standard configuration of the  Lycoming IO-540 for the RV10 one could order through Vans back around 2009.  People in the RV10 community quickly determined this was not a good combination.  Even with 2 fully charged 680s, the starter would not consistently turn through the first compression stroke when cold - one had to learn to 'bounce it' through the first compression stroke.  This was SOP on cold days but it never actually failed to start the engine.  And it routinely caused my (3) unswitched EFISs to reboot if I had both buses crossfed, even if it did pull through the first compression stroke.
Lycoming and Sky-Tech came to the same conclusion at the time and specifically recommended that the LS is not a good starter for this application.  For a period of time both companies were taking exchanges of the the LS for the NL at no charge.  (Sky Tec now offers an XLT model as an updated replacement for the LS.  Some RV10 builders used the HT model but reported similar problems.)
When I replaced it with the NL, it was immediately apparent that the NL turned slower but with much greater 'authority'.  Even starting on one battery, switched so that it ran on the same bus as the (3) EFISs, the EFISs didn't reboot.  Starts are now a no-brainer.
