RotaxEngines-List Digest: 6 Msgs - 09/01/17
krazydoc33(at)gmail.com
PostPosted: Mon Sep 04, 2017 8:24 pm    Post subject: RotaxEngines-List Digest: 6 Msgs - 09/01/17 Reply with quote
Hi Barry,
Thanks for your reply. I do have to clarify something though.
The sealant that I used is CS3204 a fuel resistant sealant for use on
integral fuel tanks and pressurized cabins as well as other areas subject
to contact with aircraft fuels, lubricants, oils, water and/or weathering. At
room temperature, this two-part polysulfide cures to a flexible, resilient
rubber.
Meets requirements of specifications AMS-S-8802 formerly MIL-S-8802,
CMNP021, Lockheed, Gulfstream, Hughes Aircraft, Fairchild SPS 6-1 & 6-2
This is the same sealant that has been used on over 500 Van's RV-12's as
well as most other Van's aircraft (about 10,000 of them over the years).
The prototype RV-12 is over 5 years old and has flown most of it's time
with auto-gas. No problems so far. The new tank that I built also used that
same sealant.​ I still do not know why the original fuel tank that I built
failed after being in service for three years. I am not aware of any other
similar failures.
Clearly, not all sealants are the same.
Henry
On Sat, Sep 2, 2017 at 1:03 AM, RotaxEngines-List Digest Server <
rotaxengines-list(at)matronics.com> wrote:
[quote] *
Today's complete RotaxEngines-List Digest can also be found in either of
the
of the RotaxEngines-List Digest and can be viewed with a generic text
editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=
82701&View=html&Chapter=2017-09-01&Archive=RotaxEngines
Text Version:
82701&View=txt&Chapter=2017-09-01&Archive=RotaxEngines
RotaxEngines-List Digest Archive
Total Messages Posted Fri 09/01/17: 6
Today's Message Index:
1. 07:44 AM - 912 fuel problems (Henry Roden)
2. 09:35 AM - Re: 912 fuel problems (FLYaDIVE)
3. 09:56 AM - Re: 912 fuel problems (FLYaDIVE)
4. 10:18 AM - Re: RotaxEngines-List Digest: 0 Msgs - 08/30/17
(Robert Toth)
5. 11:04 PM - Official RotaxEngines-List FAQ (Frequently Asked
Questions) (Matt Dralle)
6. 11:17 PM - Official RotaxEngines-List Usage Guidelines (Matt
Dralle)
________________________________ Message 1
_____________________________________
Time: 07:44:47 AM PST US
Subject: 912 fuel problems
I have a fuel problem that I would like your advice on. I have an RV-12
with the Rotax 912ULS that only has about 75 hours on it over the last
three or four years. I had some severe medical problems and my RV also had
some fuel problems. The fuel problems began with leakage from the tank. I
built the tank as per Van's manual and it sat for about a year before I put
any fuel into it. It was then OK for well over two years before there was a
leak. It began as a minor leakage and I removed the tank and sealed, from
the outside, one seam and a front corner. That did not stop the leak and it
got worse to the point that the tank lost about three gallons of auto fuel
over about four days. I removed the tank and could not find any sign of a
leak with the tank on the bench even with fuel in the tank. I put the tank
back in and filled it, again with auto fuel. It was OK for about five days
and then began to leak again, this time it lost about ~five gallons and
stripped the paint off the bottom of the plane, a real mess. I took a sheet
of newspaper and slid it under the tank, before I removed the fuel, and
found that it was leaking at the rear right corner. When I took the tank
out that time it did not leak on the bench until it had sat there for over
a week. The Pro-Seal softened up in places when it was wet with fuel but it
was OK when it dried out. While it was wet I could poke a Q-tip stick
through the corner, the Pro-Seal was quite soft. had no ideas why the
Pro-Seal broke down as it did but rather than risk another leak in flight I
made a new tank, this time without the side gauge and with a Moler
mechanical gauge on the top. There was a lot of trouble starting the engine
and when it did start, with full choke and no throttle, it ran rough. I had
to run the engine on full choke for at least five minutes before I could
even crack the throttle open. I cleaned both carbs and tried again. Before
the five minutes were up if I tried to open the throttle the engine would
die. Once it had really warmed up it seemed OK. I did the pre-flight check
with a run up at 4000 rpm. The ignition drop as less than 250 rpm and both
ignitions were the same. At full throttle I could not get more than 4400
rpm and it ran rough again. Back at the hangar I tried a few diagnostic
things. With the electric fuel pump on I see about 2.5-2.9 psi. With the
engine running and the electric pump off the fuel pressure drops to~0.5
psi. I took the fuel pump off the engine and operated it by hand, it seems
OK but needs the electric pump on to keep it primed. The throw of the pump
plunger is ~3/8"-7/16". Checking the pump cam with a rod and measuring the
amount of difference from high cam to low cam it is barely 3/16" which
seems very little. There is no sign of wear on the cam when looking at it
through the pump mounting hole. I had thought that the pump filter was
contaminated but the pump, when off the engine, seems OK.
The questions:
1) Is this a normal throw for this cam?
2) Why does it need so much choke when it did not do so before all the fuel
problems.
3) Is there something else I am missing that would cause these symptoms?
Since pulling off the fuel pump off another mechanic remarked that the
engine seemed very stiff to pull over with the prop, it had always been
that way since new and I had attributed it to the engine gearbox
combination. I removed the top plugs and the gearbox and the engine and the
gearbox are each quite smooth but not when the gearbox is mounted back on
the engine. It feels like the plugs are still in and there is compression
pressure causing resistance?
I apologize for the long description.
Henry
________________________________ Message 2
Time: 09:35:52 AM PST US
Subject: Re: 912 fuel problems
Henry:
I have been working with gas tank sealants for over 20 years. I do not
know what form of PRO SEAL you used, what type did you use, the 890 or the
1440? But, I can tell you that ALL the gas tank sealants available in the
USA will NOT work with AutoGas (MoGas) that contains ethanol. The gas will
soften and cause leaks to the sealant. They are good, not great, with
MoGas that does NOT contain ethanol. YET! The 'Aromatics' in gas will
also attack tank sealants. Just not as fast as ethanol!
Also - Many, Many people put one layer of tank sealant over the top of the
old sealant... Ya CAN'T do that! The sealants DO NOT stick to them selves
once cured and especially after gas has been in the tank. You MUST remove
all the old sealant - Get down to bare metal - And start again.
As for your rotax running rough... Don't know... Maybe a broken part of
the sealant has blocked some orifice. I would fix one problem at a time.
Gas tank sure sounds like it should be first.
Barry
On Fri, Sep 1, 2017 at 10:37 AM, Henry Roden <krazydoc33(at)gmail.com> wrote:
had
put
was a
it
fuel
tank
days
sheet
over
it
flight I
engine
had
Before
check
both
seems
pump
the
> The questions:
> fuel problems.
the
> Henry
________________________________ Message 3
Time: 09:56:52 AM PST US
Henry:
Barry
had
put
was a
it
fuel
tank
days
sheet
over
it
flight I
engine
had
Before
check
both
seems
pump
the
> The questions:
> fuel problems.
the
> Henry
________________________________ Message 4
Time: 10:18:55 AM PST US
Subject: Re: RotaxEngines-List Digest: 0 Msgs - 08/30/17
Please change my e-mail to *rtoth4310(at)gmail.com* Thanks Robert Toth
the
editor
> HTML Version:
82701&View=html&Chapter 17-08-30&Archive=RotaxEngines
> Text Version:
82701&View=txt&Chapter 17-08-30&Archive=RotaxEngines
> Total Messages Posted Wed 08/30/17: 0
________________________________ Message 5
Time: 11:04:54 PM PST US
Subject: Official RotaxEngines-List FAQ (Frequently
Asked Questions)
Dear Listers,
Please read over the RotaxEngines-List Frequently Asked Questions (FAQ)
below.
The
complete RotaxEngines-List FAQ including the Usage Guidelines can be found
at the
following URL:
http://www.matronics.com/FAQs/RotaxEngines-List.FAQ.html
Thank you,
[ Note: This FAQ was designed to be displayed with a fixed width font such
as
Courier. Proportional fonts will cause display formatting
errors. ]
This FAQ can also be viewed in HTML online at the following address:
http://www.matronics.com/FAQ/RotaxEngines-List.htm
******* LIST POLICIES AND FREQUENTLY ASKED QUESTIONS *******
PLEASE READ. This document contains RotaxEngines-List policies and
information
for new and old subscribers. Understanding the RotaxEngines-List policies
will
minimize problems for the Administrator, and will help keep the
RotaxEngines-List
running smoothly for all of us.
*** Quick Start Guide to List Features ***
There are many features available on the Matronics Email Lists and each
one is described in detailed below. However, using the List Navigator
you can quickly access the complete set of features available for this
List. The List Navigator can be found at the following URL:
*** How to Subscribe and Unsubscribe ***
Simply go to the Web Page shown below and enter your email address and
select the List(s) that you wish to subscribe or unsubscribed from. You
may also use the handy "Find" function to determine the exact syntax of
your email address as it is subscribed to the List. Please see the
complete instructions at the top of the Web Page for more information.
The Subscribe/Unsubscribe web page is:
http://www.matronics.com/subscribe
Note that you will receive TWO conformation emails regarding your
subsciption
process. The first verifies that your subscription/unsubsciption
request
was received, and the second confirms that the process has been
completed.
You should receive the first email within a few minutes of your request.
The second conformation will arrive in less than 24 hours. You cannot
post
until you receive the second conformation email message.
*** How to Post a Message ***
Send an email message to:
Your message will be redistributed to everyone currently subscribed
to the List.
*** SPAM Fighter - You Must be Subscribed to Post ***
When a new post is received by the system, the From: line of the message
is checked and compared against the current subscription list. If the
email address is found, the message is passed on to the List Processor
