donjohnston
Posted: Sun Aug 06, 2017 12:35 pm Post subject: Aircraft theft prevention? |
So with the understanding that most aircraft security is only good enough to keep honest folks from running off with your airplane...
But does anyone have any ideas on ways to prevent the engine from starting? Other that the big chain prop locks.
Early on, I was considering second, hidden mag switches. But I'm wondering if there's an alternative.
Note: I do not have a keyed ignition switch. Just a toggle switch for each mag and a push button starter switch.
Bob McC
Posted: Sun Aug 06, 2017 1:19 pm Post subject: Aircraft theft prevention? |
If you have mags, anyone can cut the "P" leads, hand prop the engine and fly away, regardless of anything you've done short of the prop chain idea so long as fuel is available. Maybe a hidden locking fuel valve. Be careful, as this may not prevent the engine starting and there might be just enough residual fuel in the lines to get airborne before the engine quits. The prop chain has the added benefit of being a visible deterrent so they won't even try, but rather go to an easier target.
Bob McC [quote]
_________________ Bob McC
Falco #908
(just starting) |
rnewman(at)tcwtech.com Guest
Posted: Sun Aug 06, 2017 1:22 pm Post subject: Aircraft theft prevention? |
You may want to check out a product we sell called SmartStart. It allows for a hidden arming switch that when pressed gives you 1 minute to crank the engine. It works with the standard start contactor, can interface to a push button switch or standard key switch. It also listens to interlock switches that must be closed before arming can occur
Www.tcwtech.com
Bob Newman
TCW Technologies, LLC
610-928-3420
Quote: | On Aug 6, 2017, at 4:35 PM, donjohnston <don(at)velocity-xl.com> wrote:
http://forums.matronics.com/viewtopic.php?p=471552#471552
stuart(at)stuarthutchison Guest
Posted: Sun Aug 06, 2017 1:38 pm Post subject: Aircraft theft prevention? |
Take a look at the TCM Smart Start Don.
Kind Regards, Stu
On 7 Aug 2017, at 07:18, Robert McCallum <robert.mccallum2(at)sympatico.ca (robert.mccallum2(at)sympatico.ca)> wrote:
Bob McC
john(at)johnkeen.com.au Guest
Posted: Sun Aug 06, 2017 4:35 pm Post subject: Aircraft theft prevention? |
I have a keyed master, and the starter button won't work without the master. But I guess the aircraft could be hand propped as the mags are both on toggle switches.
John Keen
0412 141 833
Quote: | On 7 Aug 2017, at 06:35, donjohnston <don(at)velocity-xl.com> wrote:
donjohnston
Posted: Sun Aug 06, 2017 5:06 pm Post subject: Re: Aircraft theft prevention? |
Not an option for me as I have a 24v electrical system.
rnewman(at)tcwtech.com wrote: | You may want to check out a product we sell called SmartStart. It allows for a hidden arming switch that when pressed gives you 1 minute to crank the engine. It works with the standard start contactor, can interface to a push button switch or standard key switch. It also listens to interlock switches that must be closed before arming can occur
Www.tcwtech.com
Bob Newman
610-928-3420
Dave Saylor
Posted: Sun Aug 06, 2017 5:25 pm Post subject: Aircraft theft prevention? |
With the understanding that additional layers add complexity and reduce reliability, you could wire your master switch in series with another ubiquitous toggle far from the master, and label it something like "Safety/Normal".
Speaking of extra switches, I had a customer with several planes who put a landing gear switch in his Glasair FT. Just so he didn't get out of the habit!
--Dave
On Sun, Aug 6, 2017 at 1:35 PM, donjohnston <don(at)velocity-xl.com (don(at)velocity-xl.com)> wrote:
Quote: | --> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>
_________________ --Dave
KWVI |
ashleysc(at)broadstripe.n Guest
Posted: Sun Aug 06, 2017 6:26 pm Post subject: Aircraft theft prevention? |
Hi Don;
How about a second switch (toggle or rocker) in series with your start button, on the panel or elsewhere, whose function is not called out?
Cheers! Stu.
PS: I only have a start button, but my canopy locks.
arrow54t(at)yahoo.com Guest
Posted: Tue Aug 08, 2017 3:17 pm Post subject: Aircraft theft prevention? |
I have a towbar switch that is in series with the starter circuit. If the towbar is not in place, then the starter will not engage. When I leave my airplane on the ramp, I do not install the towbar in its holder, thus rendering the start circuit inoperable.
Lancair ES
On Sunday, August 6, 2017, 1:56:00 PM PDT, donjohnston <don(at)velocity-xl.com> wrote:
