Posted: Thu Jun 15, 2017 4:53 am Post subject: Question about Z19RB and OVP/Beaker and size wire |
At 10:17 AM 6/14/2017, you wrote:
Quote: | --> AeroElectric-List message posted by: "Achille" <mickael.t(at)live.fr>
Thank you Bob for your response.
How could I check if my alternator is compatible with en external OVP before wiring it ? (it is not wired anymore)
It was wired like the picture attached in this message. (drawn by constructeur)
Thank you.
Mickaël |
The last drawing is the 'magic' data. It shows that
your alternator is externally regulated -AND- that
the alternator control switch does indeed carry field
excitation current. Here's an exemplar application of
the crowbar ov module to your project.
[img]cid:7.1.0.9.0.20170615075025.0209e7b0(at)aeroelectric.com.0[/img]
Description: |
Filesize: |
110.06 KB |
Viewed: |
4031 Time(s) |
Achille
Posted: Sat Jun 17, 2017 4:40 am Post subject: Re: Question about Z19RB and OVP/Beaker and size wire |
Many thanks !
Mickaël
Achille
Posted: Fri Jun 23, 2017 6:11 am Post subject: Re: Question about Z19RB and OVP/Beaker and size wire |
Hello again,
Just to ask a question about this OVP wiring.
I have a filter with it (b&c complet OVP system) for the relay I didn't put it to wire it like the diagram, but the filter have to be add or not in my system ?
What is his fonction ?
Mickaël
Posted: Fri Jun 23, 2017 8:45 am Post subject: Question about Z19RB and OVP/Beaker and size wire |
Hello again,
What is his fonction ? |
The OVP system was configured for use with
a permanent magnet alternator. The filter
is only used with these machines. Your
internally regulated alternator only needs
the OV protection module.
