Is a battery contactor really needed?
PostPosted: Wed Apr 26, 2017 2:20 pm    Post subject: Is a battery contactor really needed? Reply with quote
At 09:39 AM 4/26/2017, you wrote:
--> AeroElectric-List message posted by: "eschlanser" <eschlanser(at)yahoo.com>
It's been a couple of years since I designed my plane's electrical system with no battery contactor.
What brand or style battery contactor is preferred/acceptable for a OBAM airplane with a Z - (x) wiring system? I installed the barrel style starter contactor but replaced it with the flat style when Bob recommended that change. Now I'm wondering if there's a new style of battery contactor that has superseded the barrel style.
The 'whisky barrel' style contactors have
a track record that goes back nearly 100
years. Process and materials improvements
have been applied throughout that time . . .
they are of excellent value.
The recommended change for starter contactors
was based on the fact that even low duty-cycle
whisky-barrel devices featured large area, low
pressure contact surfaces compared to the
more modern devices designed specifically for
starter control. But assuming you've got a
Plan-B in place for managing a battery contactor
failure (or its wiring, switch, terminals, etc)
then the style is of little significance.
If it were my airplane, the battery contactor
would be one of these . . .
http://tinyurl.com/koq788n
. . . or its several cousins.
Contactor failure in the whisky-barrel styles
is rare and it usually announces an impending failure
with finicky starter performance. So the first time
you get an intermittent starter behavior accompanied
by a black panel or 'chattering' starter contactor,
then it's time to replace the critter (assuming your
battery satisfactorily passes cap and load tests).
One advantage to eliminating the battery contactor is keeping the voltage available for starting that would be lost to the battery contactor.
energy demands of a battery contactor
are trivial compared with that required
to energize the starter . . . hence
no energy conservation benefits there . . .
