hgmckay
Posted: Sat Jan 14, 2017 7:23 am Post subject: Rotax Cylinder Head temperature gauge |
I recently had a sudden loss of coolant on my 912 UL engine which required cylinder head replacement (new style heads). During the loss of coolant incident my Rotax CHT gauge was “pegged” for about 8 to 10 minutes before I safely landed the plane. My question is since the gauge was “pegged” during this time has it been damaged, or can I just re-label it and use it with the new cylinder heads that measure the actual coolant temperature?
Hugh G. McKay III
Allegro 2000
Rotax 912 UL
email hgmckay(at)bellsouth.net
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Description: |
Download |
Filename: |
Hugh.vcf |
Filesize: |
79 Bytes |
Downloaded: |
405 Time(s) |
jetguy(at)att.net Guest
Posted: Sat Jan 14, 2017 9:54 am Post subject: Rotax Cylinder Head temperature gauge |
Hi Hugh, I would run the fixed engine with the original gauges and look for normal indications. If all appears normal then continue with normal operations. If non-normal indications are noted then replace the gauge.
On Saturday, January 14, 2017 9:24 AM, Hugh McKay <hgmckay(at)bellsouth.net> wrote:
Hugh G. McKay III
Allegro 2000
Rotax 912 UL
Roger Lee
Posted: Mon Jan 16, 2017 5:40 am Post subject: Re: Rotax Cylinder Head temperature gauge |
I'm with Jetguy. Try them and see what they read.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
h&jeuropa
Posted: Tue Jan 17, 2017 5:50 am Post subject: Re: Rotax Cylinder Head temperature gauge |
Hugh,
You can check your temp gauge by testing it in boiling water.
Jim Butcher
hgmckay
Posted: Tue Jan 17, 2017 6:21 am Post subject: Rotax Cylinder Head temperature gauge |
Jim,
How do I do that?
Hugh G. McKay III, P.E. Fellow, L.M. ASCE
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
http://www.wwegeo.com
blumax008(at)aol.com Guest
Posted: Tue Jan 17, 2017 6:30 am Post subject: Rotax Cylinder Head temperature gauge |
I don't know but a sure fire way to find out is to blow your fan belt then watch your CHT soar to 550. That way you'll know its working correctly.
Motorkote kept it running at that temp & got me back to base. Got so hot it melted the spark plug rubber. The engine was smoking like a forest fire. It should've seized within 1 minute. I flew it that hot for 15+ minutes.
I bought my first u/l in '78. If you guys aren't using Motorkote in your 2-cycle fuel, I highly recommend it. It saved my ass. I use 2 oz to 6 gallons.
Sent from my Verizon, Samsung Galaxy Tablet
-------- Original message --------
Date: 1/17/17 8:50 AM (GMT-05:00)
To: rotaxengines-list(at)matronics.com
Subject: RotaxEngines-List: Re: Rotax Cylinder Head temperature gauge
--> RotaxEngines-List message posted by: "h&jeuropa" <butcher43(at)att.net>
Hugh,
Jim Butcher
http://forums.matronics.com/viewtopic.php?p=465154#465154
_-============================================================
_-= - The RotaxEngines-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?RotaxEngines-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
purple_hemi_426(at)hotmai Guest
Posted: Tue Jan 17, 2017 8:55 am Post subject: Rotax Cylinder Head temperature gauge |
Hi.
Just my way of "benchtesting any water probe"
I tested mine by.Removing the inside instrument cluster gauge from the craft (note the wiring for that gauge setup ) removed the probe from the engine block with care.. . (1) using a electronic digital home/kitchen thermometer and a (2) you will need 12 volt battery for wiring hookup (i used my motorcycle battery) (3) hook up the wiring to the gauge and to the probe and the battery as per schematic diagram for that type of gauge. Remeber to ground your gauge by using a Small alligator clip type. get it all set up "BEFORE " heating the water.(4) Use a 12 inch diameter dipper with about 2 inches of regular tap water in it. turn the electric stove on "low" temperature first. ( possibly,use oven mitts to prevent hot steam while doing testing) use a piece of string to just put the engine probe into about 1/2 inch in the water, again make sure that just the lower part ONLY of the probe just touch the water (remember these probes operate on electric resistance measurement) also put your electronic cooking gauge in the water (tie the cooking electronic gauge to the handle of the dipper to prevent it from falling into the water,if this happens you will most likely ruin your cooking thermometer). as the water continue to heat up slowlyyyyyyy from cooler to hotter it will show precisely on the cooking thermometer. At the same time watch VISUALALLY and compare it to the Craft instrument gauge thst you are testing,this will tell you if the sensor and also if the gauge is working properly, this will do 2 tests for you,it will show if it is both working accuracy.
Fr
From: owner-rotaxengines-list-server(at)matronics.com <owner-rotaxengines-list-server(at)matronics.com> on behalf of Hugh McKay <hgmckay(at)bellsouth.net>
Sent: January 17, 2017 2:20 PM
Subject: Re: Re: Rotax Cylinder Head temperature gauge
--> RotaxEngines-List message posted by: "Hugh McKay" <hgmckay(at)bellsouth.net>
Jim,
How do I do that?
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
