What Causes Battery to Go Bad
billhuntersemail(at)gmail
PostPosted: Fri Oct 28, 2016 3:56 pm    Post subject: What Causes Battery to Go Bad Reply with quote
My car battery died after 9 months. In the last 20 years I seem to have very bad luck with batteries in various vehicles. These vehicles are classic cars used rarely (I disconnect the negative terminal when not in use) and some are often used daily drivers (stock cars with stock electric systems).
It seems back in the day "maintenance free" batteries seemed to last longer.
Is there something different now a days?
Bill Hunter
chaskuss(at)yahoo.com
PostPosted: Sat Oct 29, 2016 12:42 am    Post subject: What Causes Battery to Go Bad Reply with quote
Bill,
Simply disconnecting the batteries does not prevent them from discharging while sitting. It merely slows down the rate of discharge [not having to supply power to those electrical circuits which run even with the ignition switch off] It's best to keep a "trickle" charger on batteries that sit, unused for long periods of time.
I would suggest that you have your alternator(s) tested for shorted diode(s) in the rectifier bridge. A diode is the electrical equivalent to a check valve in a hydraulic system. It allows current to flow in one direction only. The rectifier's purpose is to change the AC current the alternator makes into DC current that your car's battery needs. Diodes can fail two ways. Fail Open [most common] - the diode no longer allows any current to pass. This causes the alternator to lose a portion of it's output capacity. Fail Shorted - this allows the alternator to pass a portion of it's output as AC current. No drop in the alternator's capacity will be noted. However, pumping AC current into a DC battery will kill the battery in a matter of months, hence the premature battery failures. Why do alternator diodes fail? Generally, because the battery is low and when the engine starts, the alternator has to generate a LOT of current to charge the battery. You can NOT test for shorted diodes with an ammeter. You need proper testing equipment to find this condition. So, if you find that you have shorted alternator diodes, repair the alternator(s). Then make sure that each battery is fully charged BEFORE you start each engine. That way, you don't over tax the alternator right after start up.
Charlie
On Fri, 10/28/16, William Hunter <billhuntersemail(at)gmail.com> wrote:
Subject: What Causes Battery to Go Bad
Date: Friday, October 28, 2016, 7:54 PM
My car battery died
Bill Hunter
PostPosted: Sat Oct 29, 2016 2:22 am    Post subject: What Causes Battery to Go Bad Reply with quote
The 'classics' did not load the battery in the normal 'parked' condition. Disconnecting the battery in such vehicles for long term storage was seldom, if ever, a useful thing to do. I think the electric clock was the biggest load with very small energy requirements.
Modern vehicles MAY have small battery demands while parked. I think my wife's Saturn has a battery load on the order of 0.02 amps when parked. This is greater than the normal and expected self-discharge current characteristic of flooded batteries. If her car is not driven for a long period of time, the battery will be discharged. Further, a battery stored in a discharged condition self-destructs.
I don't think so. Modern cars may have some very small persistent loads even when parked . . . the older cars will not. Batteries that sit for long periods of time will benefit from use of a 'maintainer' . . . not a 'trickle charger' the maintainer simply holds a battery's terminal voltage just above that at which self-discharging takes place. A maintainer holds a nominally 12.9v battery up to about 13.2 to 13.5 volts. Not high enough to do any charging but higher than normal open circuit volts. Hence, the ac mains become a source of energy to offset self-discharging. I used to have a stable of laboratory batteries that were stored on a single maintainer all connected in parallel. Some of them were service-ready after more than ten years.
A 'trickle charger' puts a small but constant charge into a battery . . . which can be greater than the self-discharge current . . . and is ultimately deleterious to a battery on long term storage. I still have a couple of Battery Tenders I keep attached to my battery inventory. There's a host of products out there.
http://tinyurl.com/zzjhalk
The Battery Tender and the Schumacher SEM1562 are used in my shop. Walmart stocks the Schumacher product for about $
25. =================
Generally true . . . with additions. The lead-acid battery also has a self-discharge characteristic that is a function of dissolved oxygen in the electrolyte. Flooded batteries of bygone times would run down in 90-120 days just sitting unload. Maintenance free batteries were a step up for controlling self discharge with the sealed battery being the present king of long term storage. An SVLA battery should retain 70-80% of capacity after a year of storage as long as the temperatures are not really high. I would suggest that you have your alternator(s) tested for shorted diode(s) in the rectifier bridge.
<snip>
I've never encountered such a failure. The power diodes used in alternators are exceedingly robust devices and their reverse leakage at battery voltage is measured in nanoamps. Unlike generators (with brushes and commutators that carry output current), the alternator has no such weak-link. Alternators are inherently current limited. Normal operations . . . even starting an engine with jumpers with the alternator grunting the load of a fully discharge battery does no 'over tax' an alternator in any serious way. I've seen that admonition for making sure your battery is fully charged before firing up the engine with a new alternator . . and I'm mystified by it.
These things are explained in more detail in The AeroElectric Connection. You can download a copy here
http://www.aeroelectric.com/Book/AEC_R12A.pdf
or acquire a paper-copy here
http://tinyurl.com/cgr42l5
Your unexplained short term failure may be a one-of event. But as a general observation, today's battery products are as good as they ever have been. Persistent failures have an explanation that should and can be identified.
PostPosted: Sat Oct 29, 2016 6:12 am    Post subject: What Causes Battery to Go Bad Reply with quote
Thanks All!!!
This is very good information. My 87 year old father and I have had this conversation numerous times over the decades and I will share this email thread with him.
BTW…the most recent victim was a Saturn.
Cheers!!!
Bill Hunter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Saturday, October 29, 2016 3:21 AM
Subject: Re: What Causes Battery to Go Bad
product for about $25.
<snip>
mystified by it.
a copy here
PostPosted: Sat Oct 29, 2016 6:27 am    Post subject: What Causes Battery to Go Bad Reply with quote
At 09:11 AM 10/29/2016, you wrote:
Thanks All!!!
I will suggest an experiment. . .
Acquire a multimeter . . . nothing
fancy. One of those $5 Harbor Freight
things will work.
Put it into the current measurement
mode. Remove one wire from the
Saturn's battery and put the multi-
meter in the gap.
I'll do the same on my wife's car . . .
it was about 15 years ago that
I made the discovery and my memory
of exact value is fuzzy . . .
but tomorrow.
Right now I'm packing up our Cotton
Candy concession into another 'classic'.
My father willed his '87 GMC Sierra
Classic 1500 to Dr. Dee . . . with
only 37K miles on it.
I've been honing my mechanics skills
re-furbing the things that succumb to
age and use. But it's very road-worthy and
we're participating in a fund raiser for
my grandchildren's grade school in
Wichita this evening.
Hmmm . . . the Sierra has TBI and
some other 'electro whizzies . . .
I'll check all the cars for parasitic
parked loads and report back. If
anyone else on the List is so inclined,
it would be interesting to get some
data on a variety of vehicles.
PostPosted: Sat Oct 29, 2016 6:39 am    Post subject: What Causes Battery to Go Bad Reply with quote
Good idea Bob... I'm on a trip right now but will participate in this clinical study when I get home. I'll see if my dad will join in on the fun and contribute as well.
I hope your skills at setting the digital clock have not deteriated...
Bill Hunter
On Oct 29, 2016 9:33 AM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Thanks All!!!
  things will work.
  meter in the gap.
  but tomorrow.
yellowduckduo(at)gmail.co
PostPosted: Sat Oct 29, 2016 8:01 am    Post subject: What Causes Battery to Go Bad Reply with quote
Won't matter too much on an 87 but especially for newer vehicles I'd
suggest putting the ammeter in the circuit before disconnecting the
battery so that you don't lose momentary power with resultant loss of
accumulated "learning" in the ecu as well as things like radio settings.
I understand that it can even require a return to the dealer to
re-instate radios that have anti-theft security features. Even better
might be a 9 volt battery temporarily plugged into a cigarette lighter
which should also keep the memories intact.
Ken
> Thanks All!!!
things will work.
meter in the gap.
but tomorrow.
ashleysc(at)broadstripe.n
PostPosted: Sat Oct 29, 2016 8:52 am    Post subject: What Causes Battery to Go Bad Reply with quote
Hi Bob;
Hi All;
Further to the SLVA battery success stories:
When we were living 7 months in Anchorage and 5 months in Costa Rica each year, we had a 1982 Nissan King Cab pickup that sat outdoors in Alaska's winter, Every April first we would arrive back in Alaska, shovel the snow away from the pickup, turn the switch, and it never failed to start up. The sealed lead acid battery never let us dawn, even though we abused it unmercifully.
Cheers! Stu.
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Sent: Saturday, October 29, 2016 3:21:26 AM
The Battery Tender and the Schumacher SEM1562 are used in my shop. Walmart stocks the Schumacher product for about $25. =================
<snip>
skywagon
PostPosted: Sat Oct 29, 2016 11:27 am    Post subject: What Causes Battery to Go Bad Reply with quote
Just some suggestions about auto battery failure. . . .
From a simplified view point, batteries usually fail because. . .
1. Being over-charged in the vehicle or on a charger or both. .
2. Being constantly under-charged in vehicle or charger or both. .
3. Bad environment; vibration, etc.
My personal opinion is your problem is #2.
Just disconnecting the negative lead is not enough for a lead-acid based battery. It will self discharge thru a variety of "paths"; internally and externally.
Hooking up a small (low amperage) charger also leads mostly to a disaster as it eventually goes to an over-voltage state, thus gassing the cells dry.
A good solution is to connect a "Battery Maintainer" to the battery and leave it connected. If it is set to the correct float voltage, it will charge essentially to that voltage and then "sit" adding a little bit as is needed. These units are cheap. Even Harbor Freight has models that on sale or under $10.
However, many of the units may come out of the box not calibrated exactly correct for float voltage. The float voltage should be in the region of 13.2 - 13.4 volts in my opinion.
One can buy a fairly good DVM, digital volt meter, for under $20. I suggest buying a Maintainer from a close by local store. Also pick up the DVM. Hook it up to one of your batteries that is "good" and let it run for a couple of days until it is stabilized and check the battery voltage; this will be the stabilized float voltage. If it is too high or low, box it up and return it for another unit. The factory QC in many cases is not very good at final V settings of these units.
Personally, I take mine apart, carefully, locate the adjustment "pot", drill a small hole for a tiny screwdriver in the case and reassemble it.
And, carefully, adjust the voltage control pot over several days until I like the final float voltage.......
Dave
PS; be careful of using a small solar panel to maintain charge. Many "12 volt" types can go to 18v or higher in bright sun.  The panel must have a voltage control within it. Low amp units can be controlled simply with a Zener type diode. . ..
Tundra10
PostPosted: Sun Oct 30, 2016 4:40 am    Post subject: What Causes Battery to Go Bad Reply with quote
I used
Beware putting multiple batteries in parallel on a single maintainer.
I had a cell die in one battery. The maintainer was unable to hold
the float voltage.
After a month or two the other batteries had sat completely discharged
for a while
and none were serviceable. Now I use a separate maintainer for each.
Perhaps a low voltage alarm would suffice instead.
Jeff Page
Dream Aircraft Tundra #10
PostPosted: Sun Oct 30, 2016 6:26 am    Post subject: What Causes Battery to Go Bad Reply with quote
the float voltage.
for a while
My maintainers have lights on the front that
annunciate status of battery(ies). While
a shorted cell in one battery would indeed
upset the universe of batteries on storage,
it's a very rare event in the SVLA world . . .
occurring mostly in batteries that probably
shouldn't be on the maintainer in the first
place . . . capacity badly compromised.
Active and obnoxious notification of
low voltage would be helpful in this situation.
A 5 cell battery's open terminal voltage drops
to (12.8/6)*5 = 10.7 volts. The same battery's
'charge voltage' drops to (14.2/6)*5 = 11.8
volts which would indeed draw down the remaining
batteries as they 'charged' the compromised
battery.
I think it prudent to know that all batteries
in an array of 'maintained' batteries are
worthy of being maintained . . . i.e. not
less than 75% of nameplate capacity. A substantial
drop in capacity precedes cell degradation
which precedes mechanical compromise
of insulators that produces the shorted
cell.
My instrument batteries were used as stand
alone power for data acquisition equipment,
portable power for hand tools and occasionally
as cranking batteries for vehicles. They
were periodically cap-checked (you don't want
the DAS to go down in the middle of a flight
test!).
Keeping an eye on your maintainer(s) annunciator
lights is a useful thing to do . . . and yes, separate
maintainers is the ultimate firewall against suffering
a similar inconvenience.
