FAA: Remove NavWorx UATs
recapen(at)earthlink.net
PostPosted: Fri Oct 21, 2016 8:38 am    Post subject: FAA: Remove NavWorx UATs Reply with quote
Cross posted from the Canardians…:
The FAA proposed an airworthiness directive (AD) on Oct. 20 that would require removing certain NavWorx Inc. model ADS600-B remote-mounted universal access transceivers (UATs) from the aircraft in which they have been installed, and would prohibit their installation on any aircraft. The products provide Automatic Dependent Surveillance-Broadcast (ADS-B) Out and In on the 978-MHz frequency. The FAA estimates that approximately 800 U.S.-registered aircraft would be affected by the proposed AD.
https://www.aopa.org/news-and-media/all-news/2016/october/20/faa-seeks-removal-of-navworx-uats?utm_source=ePilot&utm_medium=Content&utm_content=gear&utm_campaign=161020epilot
Let Navworx know of your concerns (they have a note on their website) and comment on the AD.
Gary.A.Sobek
PostPosted: Fri Oct 21, 2016 2:41 pm    Post subject: FAA: Remove NavWorx UATs Reply with quote
NavWorks response is located at:  http://www.navworx.com/documents/UPN%20Statement.pdf
There are links in the document to contact FAA Administrator and your Congressman.
Stuff like this is why I have no intention of adding ADS-B till the last minute IF I add it at all.
Gary A. Sobek
Built and Flying
RV-6, N157GS O-320 Hartzell
3,200+ Hobbs hours last 19+ Years.
Building RV-8
On 10-21-2016 12:38 PM, Ralph E. Capen wrote:
<![endif]--> <![endif]-->
