engine won't rotate
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
schwartzcompany(at)att.ne
PostPosted: Sat Jul 09, 2016 12:11 pm    Post subject: engine won't rotate Reply with quote
Looking for some ideas. My R model engine won't rotate when I hit start button. Nothing happens . No blade movement whatsoever.
Do not start light out. Three switches at engine all in up position. Removed connector at start box and cleaned it. Nothing. Starter frozen up. Everything else in cockpit works
Any ideas
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
PostPosted: Sat Jul 09, 2016 12:14 pm    Post subject: engine won't rotate Reply with quote
Also new batteries fully charged
Sent from Yahoo Mail on Android
On Sat, Jul 9, 2016 at 15:11, Robert Schwartz
Any ideas
ershire
PostPosted: Sat Jul 09, 2016 12:34 pm    Post subject: engine won't rotate Reply with quote
Try and rotate the motor with a broom handle. On Jul 9, 2016 4:15 PM, "Robert Schwartz" <schwartzcompany(at)att.net (schwartzcompany(at)att.net)> wrote:
Any ideas
L29delfin(at)yahoo.com
PostPosted: Sat Jul 09, 2016 12:48 pm    Post subject: engine won't rotate Reply with quote
Blades will turn I tried with a stick
Any ideas
delfin29(at)me.com
PostPosted: Sat Jul 09, 2016 1:53 pm    Post subject: engine won't rotate Reply with quote
Starting box ?Starter ?
Jean de Roubin
Le 9 juil. 2016 à 20:34, Jon <jonairway(at)gmail.com (jonairway(at)gmail.com)> a écrit :
Also new batteries fully chargedSent from Yahoo Mail on Android
Any ideas
PostPosted: Sat Jul 09, 2016 2:04 pm    Post subject: engine won't rotate Reply with quote
I'm going to check voltage to start box next. Starter is worst possible problem. Pull engine to look at it
On Sat, Jul 9, 2016 at 16:53, delfin29(at)me.com
Jean de Roubin
Le 9 juil. 2016 à 20:34, Jon <[url=javascript:return]jonairway(at)gmail.com[/url]> a écrit :
Try and rotate the motor with a broom handle. On Jul 9, 2016 4:15 PM, "Robert Schwartz" <[url=javascript:return]schwartzcompany(at)att.net[/url]> wrote:
Any ideas
delfin29(at)me.com
PostPosted: Sat Jul 09, 2016 2:15 pm    Post subject: engine won't rotate Reply with quote
Jean de Roubin
Any ideas
sd737(at)aol.com
PostPosted: Sat Jul 09, 2016 2:37 pm    Post subject: engine won't rotate Reply with quote
Probably start button in cockpit panel. Cleaning cannon plug won't do much.
Or.....
Pull tail and remove power cable from start box and momentarily put power directly to starter cable lead and see if you get rotation.
Dawg
PostPosted: Sat Jul 09, 2016 5:07 pm    Post subject: engine won't rotate Reply with quote
I agree with Scott. If the starter is bad you would still hear something. Start box is pretty reliable.
Or.....
Pull tail and remove power cable from start box and momentarily put power directly to starter cable lead and see if you get rotation.--
Dawg
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
