Richard Pike
Posted: Fri Jul 01, 2016 12:25 pm Post subject: Firestar cage |
A friend & I have just purchased a Firestar basket case, and I will be fabricating a fuselage cage from scratch. (!?!? yes, I know I am in over my head)
If anyone has pictures of their Firestar cage prior to covering, I would really appreciate it if you would send them to me; thegreybaron(at)charter.net.
Thanks!
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Fri Jul 01, 2016 12:34 pm Post subject: Firestar cage |
Firestar, or Firestar II? I built the front half of an original Firestar, but I had all of the original parts (bent!) to go off of.
Bill Sullivan
On Fri, 7/1/16, Richard Pike <thegreybaron(at)charter.net> wrote:
Subject: Firestar cage
Date: Friday, July 1, 2016, 4:25 PM
"Richard Pike" <thegreybaron(at)charter.net>
Thanks!
Richard Pike
Kingsport, TN 3TN0
Would you consider yourself to be a good person?
https://www.youtube.com/watch?v=VWcDXT6pH7A
http://forums.matronics.com/viewtopic.php?p=457607#457607
Forum -
- MATRONICS WEB FORUMS -
MATRONICS LIST WIKI -
List Contribution Web Site -
-Matt
Dralle, List Admin.
Richard Pike
Posted: Sat Jul 02, 2016 6:10 am Post subject: Re: Firestar cage |
Original Firestar, 5 rib wing. The only usable cage parts are the rear verticals from the 1/2" bolt cluster up to the motor mount tube, the tube including the front and rear spar carry throughs. Also have the front tube ring with the landing gear leg sockets, it is reusable. Every other tube is severely bent, but they are there, and can probably be used for measurements.
So we will be fabricating a new cage based on the rear verticals, the top tube, and the gear leg sockets. Just hoping for some photos to keep around the workshop to help visualize better what it needs to look like, and make sure nothing gets overlooked.
It's good to be retired...
Kingsport, TN 3TN0
Posted: Sat Jul 02, 2016 6:16 am Post subject: Firestar cage |
Can't remember if Bryan Melborn still has the jigs for the original FS or
not.
severely bent.
Richard Pike
Kingsport, TN 3TN0
_________________ John Hauck
Titus, Alabama |
Richard Pike
Posted: Sat Jul 02, 2016 6:39 am Post subject: Re: Firestar cage |
I don't think so. I asked Travis about that over a year ago when I first got interested in this wreck, and it seems I would have had to furnish the specs for spar pickup points, as they did not have those any more.
However, looking at various pictures online this morning, it occurs to me - why not fashion the new cage after a Firefly cage? Simpler and probably lighter.
So - if anyone has any pictures of your naked Firefly cage you would like to contribute, I would be happy to have them. Failing that, I can wait until Bryan is making one, and ride up to the factory and get some there.
Kingsport, TN 3TN0
Posted: Sat Jul 02, 2016 7:12 am Post subject: Firestar cage |
Firefly fuselage was based on the original FS fuselage.
lighter.
Richard Pike
Kingsport, TN 3TN0
Titus, Alabama |
Richard Pike
Posted: Sat Jul 02, 2016 7:23 am Post subject: Re: Firestar cage |
Good, then they ought to be compatible. And I have found a source of all the pictures I need,
http://harnerfarm.net/serenity/serenity.html
so thanks to all you guys anyway, we can suspend this thread, I am good to go here.
Kingsport, TN 3TN0
Herbgh(at)nctc.com Guest
Posted: Sat Jul 02, 2016 8:01 am Post subject: Firestar cage |
Sorry that I did not reduce the pics....!!
forgot to mention that I have a damaged nose cone ..that can be had
for free.. Herb
On 07/02/2016 10:23 AM, Richard Pike wrote:
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny."
Aristotle
stuart(at)harnerfarm.net Guest
Posted: Sat Jul 02, 2016 10:10 am Post subject: Firestar cage |
Richard,
Let me know if you need any dimensions from Serenity and I will get them for
you.
Since I have no place to fly from this summer she is resting comfortably in
the camper parked in the driveway.
Stuart
Richard Pike
Posted: Sat Jul 02, 2016 11:42 am Post subject: Re: Firestar cage |
Herb; thank you so much. With what we now have to work with, it suddenly looks possible that we might actually have this thing flying by fall.
Stuart; once we start to jig things up, I will likely be pestering you.
John, thanks for all your experience.
The folks on this list are great. I am thankful to be a part of this group of people.
Kingsport, TN 3TN0
Posted: Sat Jul 02, 2016 12:00 pm Post subject: Firestar cage |
I also have a Firefly builders manual ...around here somewhere...yep
just found it....yours too....
by the way...my not have been apparent..but spar carry through is
bent... Herb
On 07/02/2016 02:42 PM, Richard Pike wrote:
Richard Pike
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=457656#457656
Aristotle
Richard Pike
Posted: Sat Jul 02, 2016 12:36 pm Post subject: Re: Firestar cage |
[quote="Herbgh(at)nctc.com"]<snip> by the way...may not have been apparent..but spar carry through is
bent... Herb <snip> [quote]
Beggars can't be choosers. Besides, if you get steel hot enough, it will bend back.
Kingsport, TN 3TN0
west1m
Joined: 19 Apr 2014 Posts: 155 Location: Hastings, MN
Posted: Sun Jul 03, 2016 4:20 am Post subject: Re: Firestar cage |
I am a long way from TN but I also have a slightly bent cage, wings, tail feathers , nose (not too bad shape) and a 5 pound roll of blueprints.
129.38 KB |
15806 Time(s) |
_________________ West1m
Hastings, MN |
Richard Pike
Posted: Sun Jul 03, 2016 12:05 pm Post subject: Re: Firestar cage |
| west1m wrote: | | I am a long way from TN but I also have a slightly bent cage, wings, tail feathers , nose (not too bad shape) and a 5 pound roll of blueprints. |
Thanks. Let me see what we have to work with after I go collect what Herb has.
Kingsport, TN 3TN0
