Transponder antenna distance
Laz
PostPosted: Fri Jun 03, 2016 4:04 am    Post subject: Transponder antenna distance Reply with quote
Just when I think I have thought of everything in my G3X installation something else comes up.  I have a GTX23ES transponder that is a a remote mount.  I decided to mount it in the tail section where the rear battery mount is.  It worked well there because of weight and balance and I figured my cable run to the Antenna would be short and out of the way of everything else.  I missed a requirement in the Garmin Manual that says the Antenna should be 3 feet from the unit.  I plande to out eh antenna just behind unit on the belly.  I will also have a ADSB antenna on the rear belly and know that it needs to be 3' from the T-ponder antenna according to gamin.
Am I correct in assuming that the same RF problem will exist with the ADSB being to close to the transponder unit itself ?
I have found at least one Installer that has the transponder unit within a foot of the antenna and has had no problems.
Trying to keep all the antennas separated on the RV8 is not easy.
Any thoughts on this are appreciated.
rnewman(at)tcwtech.com
PostPosted: Fri Jun 03, 2016 5:09 am    Post subject: Transponder antenna distance Reply with quote
I have my navworx ads-b box about 12" from the antenna in my rv-10 located in the tail cone. No issues, works well for 4 years now. A full metal enclosure transceiver, properly terminated RG-400 cable, mounted inside an aluminum tailcone is just about as good as it gets.
Bob Newman
TCW Technologies, LLC
On Jun 3, 2016, at 8:02 AM, Michael Lazarowicz <tllaz330(at)gmail.com> wrote:
rene(at)felker.com
PostPosted: Fri Jun 03, 2016 6:01 am    Post subject: Transponder antenna distance Reply with quote
I wonder if that is a cable length requirement or a physical distance requirement.  In my past reading I remember minimum cable length requirements for GPS antennas.  Just an opinion, I really do not know anything.  Maybe Stein knows?
Rene'
801-721-6080
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael Lazarowicz
Sent: Friday, June 03, 2016 6:03 AM
Subject: Transponder antenna distance
ceengland7(at)gmail.com
PostPosted: Fri Jun 03, 2016 6:08 am    Post subject: Transponder antenna distance Reply with quote
It's worth asking Garmin, but I'd bet what they really mean is 3' of
coax minimum; easy to do with a 'U' shaped run.
I'd hope that boxes intended to emit and/or receive RF energy would
contain and isolate it to the center of the coax connector. Otherwise,
you'd have issues with a lot of other 'stuff' in the plane.
Charlie
Bob Newman
Laz
PostPosted: Fri Jun 03, 2016 6:31 am    Post subject: Transponder antenna distance Reply with quote
Well I asked Garmin. and they indicated that in a mental airplane is was probably ot going to be an issue.  The manual says distance from Unit , not cable length.  The guy I talked with said this is really a bigger issue on composite AC than on mental ones.  He also noted that I could switch the ADSB antenna with the Transponder Antenna locations since the ADSB is in only.  Fortunately I have enough Coax to do that.  I will have close to 3 feet and the Coax will be at least 3 feet long from the transponder to the antenna.
On Fri, Jun 3, 2016 at 10:10 AM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
It's worth asking Garmin, but I'd bet what they really mean is 3' of coax minimum; easy to do with a 'U' shaped run.
I'd hope that boxes intended to emit and/or receive RF energy would contain and isolate it to the center of the coax connector. Otherwise, you'd have issues with a lot of other 'stuff' in the plane.
Charlie
--> AeroElectric-List message posted by: Tcwtech <rnewman(at)tcwtech.com (rnewman(at)tcwtech.com)>
Bob Newman
On Jun 3, 2016, at 8:02 AM, Michael Lazarowicz <tllaz330(at)gmail.com (tllaz330(at)gmail.com)> wrote:
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
