billvh@ca.rr.com
Posted: Sun Sep 27, 2015 3:04 pm Post subject: Stuck wheel |
Trying to get the wheels off a 50 I'm working on. No amount of pounding on the tire will get either wheel to budge. (Yes I took off the nuts and washer.)
The backing plate is too thin to pry against. Anyone got a trick or special technique or tool to get the bearing to let go of the axle? BTW it took a 24 inch Johnson bar to get the nuts off.
Posted: Sun Sep 27, 2015 4:13 pm Post subject: Stuck wheel |
Sounds like someone seriously over torqued the wheel nut and very possibly damaged/crushed the bearings. Was there a washer behind the nut and in front of the cup? If not, that is probably why the wheel nut was over torqued; to take up the space because of the missing washer.
Try spraying the bearing with freezing type spray. You may try an electronics freezing spray or you could even try a can of the cheapest freon available at the auto supply store.
Dennis
| Quote: | On Sep 27, 2015, at 6:04 PM, "billvh(at)ca.rr.com" <billvh(at)ca.rr.com> wrote:
http://forums.matronics.com/viewtopic.php?p=447489#447489
dougsappllc(at)gmail.com Guest
Posted: Sun Sep 27, 2015 4:23 pm Post subject: Stuck wheel |
I have but a short moment here but if the wheel and axle is the same as a CJ I have a tool for removing it.
Please do not call me until Tuesday.
oug
On Sun, Sep 27, 2015 at 5:10 PM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
[quote]--> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Dennis
> On Sep 27, 2015, at 6:04 PM, "billvh(at)ca.rr.com (billvh(at)ca.rr.com)" <billvh(at)ca.rr.com (billvh(at)ca.rr.com)> wrote:
> --> Yak-List message posted by: "billvh(at)ca.rr.com (billvh(at)ca.rr.com)" <billvh(at)ca.rr.com (billvh(at)ca.rr.com)>
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
b Site -
     -Matt Dralle, List Admin.
pfstelwagon(at)earthlink. Guest
Posted: Sun Sep 27, 2015 6:03 pm Post subject: Stuck wheel |
Go to a Parker hose dealer they can fix you up.
wlannon(at)shaw.ca Guest
Posted: Sun Sep 27, 2015 6:50 pm Post subject: Stuck wheel |
Keith;
Seems to be two subjects here.
1. Yes, unless Doug has another tool for pulling the wheel, the puller is
for the outer (large) bearing only - after the wheel is off.
2. Pipe thread is pipe thread, same everywhere as far as I know. From
ancient British steam days. All you need is the correct size AN12 fitting.
Believe it is a 1" pipe but just a guess. Could check it out at the hangar
tomorrow and call you with the P/N if you give me a phone number.
Walt
jackpot
Joined: 13 Jul 2010 Posts: 65 Location: Las Vegas, Nevada
Posted: Sun Sep 27, 2015 8:31 pm Post subject: Stuck wheel |
Gary here. LAS. PIPE THREADS ARE THE SAME THE WORLD OVER. NO SUCH THING AS A METRIC PIPE THREAD.
CJ. N22YK.
[quote] On Sep 27, 2015, at 19:47, Walter Lannon <wlannon(at)shaw.ca> wrote:
Keith;
1. Yes, unless Doug has another tool for pulling the wheel, the puller is for the outer (large) bearing only - after the wheel is off.
2. Pipe thread is pipe thread, same everywhere as far as I know. From ancient British steam days. All you need is the correct size AN12 fitting. Believe it is a 1" pipe but just a guess. Could check it out at the hangar tomorrow and call you with the P/N if you give me a phone number.
Walt
jackpot
Posted: Sun Sep 27, 2015 10:25 pm Post subject: Stuck wheel |
If you can pack the inside of the axel, the hollow portion with dry ice and keep it packed for about 2 hrs it may shrink the axel enough to allow you to pull the bearing off. I have had success using this procedure on quite a few things.
Gary. CJ N22YK
On Sep 27, 2015, at 17:20, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
[quote]I have but a short moment here but if the wheel and axle is the same as a CJ I have a tool for removing it.
oug
| Quote: | --> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Dennis
FORUMS -
b Site -
ist"">http://www.matronics.com/Navigator?Yak-List
billvh@ca.rr.com
Posted: Mon Sep 28, 2015 7:08 am Post subject: Re: Stuck wheel |
Thanks Dennis. CRC makes a product called freeze and lube or something like that which I tried but was unable to get the axle cold enough to do the trick. And there was a double tang thick washer under the wheel nut. I have no idea why the folks at Termikas would tighten the nut to that extreme. My next move is what Gary CJ N22YK suggested. It was going to be my next try but I thought I might get something off the list first.
Bill
| dsavarese0812(at)bellsout wrote: | Sounds like someone seriously over torqued the wheel nut and very possibly damaged/crushed the bearings. Was there a washer behind the nut and in front of the cup? If not, that is probably why the wheel nut was over torqued; to take up the space because of the missing washer.
Dennis
| Quote: | On Sep 27, 2015, at 6:04 PM, "billvh(at)ca.rr.com" <billvh> wrote:
Posted: Mon Sep 28, 2015 7:20 am Post subject: Stuck wheel |
You may try freezing the bearing too.
Dennis
To: yak-list(at)matronics.com
Sent: Monday, September 28, 2015 10:08 AM
Subject: Re: Stuck wheel
Bill
| Quote: | Sounds like someone seriously over torqued the wheel nut and very possibly damaged/crushed the bearings. Was there a washer behind the nut and in front of the cup? If not, that is probably why the wheel nut was over torqued; to take up the space because of the missing washer.
Dennis
> On Sep 27, 2015, at 6:04 PM, "billvh(at)ca.rr.com (billvh(at)ca.rr.com)" wrote:
http://forums.matronics.com/viewtopic.php?p=447504#447504k-List" target="_blank">http://www.matronics.com/Navigator?Yak-Listhttp://forums.mat &nbs//www.matronics.com/contribution" target="_blank">http://www.matronics.co==================
