601 down in WI
lwhitlow
PostPosted: Mon Jul 27, 2015 1:59 pm    Post subject: 601 down in WI Reply with quote
Sad News
A 601 crashed near Kenosha WI on the way to EAA Sunday I believe. the aircraft departed Bowman Field in Louisville KY on Sunday
The two on board were found in the aircraft when it was located. they did not survive. Please keep their loved ones in your thoughts.
The plane was located by the pilots cellphone signal.
Form the video the airframe looks intact with the wing and horizontal stab pretty much in the correct positions. The video shows a close up of the side of the fuselage and you can see that the T doubler is there, indicating the wing mod had been done. and since the wings are both where they are supposed to be it doesn't look like a structural failure.
Engine looks to be a Jabiru 3300 from the vid.
Story Here
http://www.waow.com/story/29635868/2015/07/26/2-men-die-in-plane-crash-in-se-wisconsin
Larry
N69102
601-XLB with Jabiru 3300A
65 hours on the clock
ggower_99(at)yahoo.com
PostPosted: Tue Jul 28, 2015 8:25 am    Post subject: 601 down in WI Reply with quote
Looks like the pilot flaired too high...  everything looks bent downward...  Whenever we have an emergency landing, Please fly the plane all the way down to touch down, even if we dont like the ground below.  Our planes are designed spin resistant, but they do stall if pulled too high
