Lycoming engine designations
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
CardinalNSB(at)aol.com
PostPosted: Tue Jun 27, 2006 9:57 am    Post subject: Lycoming engine designations Reply with quote
How do I tell the difference between a wide deck and a narrow deck O-360?
Which is preferable?
Is an O-360 A1A interchangeable with other "A1A" or is there more that I need to know?
Thank you, Skip
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
BPA(at)bpaengines.com
PostPosted: Tue Jun 27, 2006 10:30 am    Post subject: Lycoming engine designations Reply with quote
Skip,
A narrow deck engine will have ‘internal’ splined nuts, or nuts that will require a wrench that allows you to torque the nut from the inside versus a standard hex nut configuration. Another way to tell is the narrow deck engine will have retainer plates, 2 per cylinder. This is to allow for a thicker torque surface. The wide deck engine does not have these plates. The narrow deck engine has not been produced NEW for several years now and are getting difficult to find.
Personally speaking, I prefer the narrow deck cases over wide decks mainly because the ‘thru’ studs screw into the case halves versus ‘body fit’ thu bolts as on the wide decks.
An 0-360 A1A is a parallel head carbureted engine whereas the IO-360 A1A is a angle head. This being said, yes it is possible to convert one to or from the other, but it’s not very cost effective. There are several parts that will need to be changed such as cylinders, push rods, push rod tubes, rockers, baffles.
Allen Barrett
Barrett Precision Engines, Inc.
www.barrettprecisionengines.com
klwerner(at)comcast.net
PostPosted: Tue Jun 27, 2006 10:37 am    Post subject: Lycoming engine designations Reply with quote
The narrow deck has some type if clamps under the nuts on the base of the cylinder.
The wide deck is beefy enough not to require them (i.e. the nuts hold down the cyl. directly!)
dlawhon(at)yahoo.com
PostPosted: Tue Jun 27, 2006 11:52 am    Post subject: Lycoming engine designations Reply with quote
Allen, one question, I have a narrow deck engine
that is low compression , 7.4 to 1 0320 that doesn't
have the plates , and the info I got (older engines)
was that only the upgraded (ie: 160hp) engines
needed the plates.. can you tell me if some of them
didn't have the plates ?
Danny..
--- BPA <BPA(at)BPAENGINES.COM> wrote:
[quote] Skip,
A narrow deck engine will have 'internal' splined
nuts, or nuts that
nut from the inside
to tell is the
produced NEW for
over wide decks
mainly because the 'thru' studs screw into the case
halves versus 'body
fit' thu bolts as on the wide decks.
to convert one to
or from the other, but it's not very cost effective.
There are several
Allen Barrett
<http://www.barrettprecisionengines.com/>
PostPosted: Tue Jun 27, 2006 12:37 pm    Post subject: Lycoming engine designations Reply with quote
Danny,
Boy! You have an old style narrow deck engine. First series 140-150 HP
engines did not have the plates. Second series, or phase 2 narrow decks
did. These require longer deck studs to incorporate the plates. If I'm
not mistaken this is a Service Instruction and most crankcase repair
shops will upgrade the cases when they do the overhaul on your cases. If
they didn't and you want the upgrade, call them and ask for the longer
deck studs. I recommend the upgrade.
There was another short lived case series that no longer is in
production as well called the 'mid deck' but this is for another
discussion.
Allen Barrett
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
