lithium facts
Goto page Previous  1, 2, 3, 4
ronaldcox
PostPosted: Fri Nov 14, 2014 8:59 am    Post subject: Lithium facts Reply with quote
I, for one, haven't seen a boring thread here in a loooong time.  I'm learning a lot, and I think the activity indicates the same from others.  Doesn't have a direct application at the moment, but this is how NW ideas get developed within our community, and I hope no one is intimidated into killing off the discussion.
I'd suggest the complainer switch to the Digest, and then he can easily scroll to whatever he is interested in.
Ron
Ron Cox
Glasair Super II F/T
Under Construction at C77 - Still just about to fly!
jan_de_jong(at)casema.nl
PostPosted: Fri Nov 14, 2014 12:02 pm    Post subject: lithium facts Reply with quote
LiFePO4 or LFP, not Lipo (= LiCoO2 or LCO ). There is a big difference in safety:
http://batteryuniversity.com/learn/article/types_of_lithium_ion
Jan de Jong
On 11/14/2014 5:41 PM, Jeff Luckey wrote:
[quote] Jan,
I don't think I'm being pessimistic; cautious is a better word.
I have witnessed several lipo fires or their aftermath in R/C aircraft. I even remember a Toyota Corolla that burned to the tires because of a Lipo that was being charged in the back seat.
In addition, we all know about the Boeing issues. How many dollars did they spend on R&D?
I think it would be unwise to ignore the possibility of a Lipo fire.
Based on my experience over the past 10 years with Lipos, I would not even consider flying behind one - it is simply not worth it to me to save a few pounds.
Having said that - Lipos are great for driving around in your Tesla - if there's problem, you can get out and walk - but I don't want to be at 7500 ft when that happens.
-Jeff
On Friday, November 14, 2014 8:08 AM, Jan de Jong <jan_de_jong(at)casema.nl> (jan_de_jong(at)casema.nl) wrote:
On 11/14/2014 4:27 AM, Jeff Luckey wrote:
Suggest updating the weight calculations to include a steel battery box to contain a lipo fire.
Is this a little pessimistic?
Some old LiFePO4 on youtube, for those who have not looked there yet -
vandalism committed upon a Headway 38120 10Ah LiFePO4 cell:
http://www.youtube.com/watch?v=8IBapfB0Imo
http://www.youtube.com/watch?v=52h8IK0IdqI
http://www.youtube.com/watch?v=wkJM8MZkFKU
Are the results valid for A123 ANR26650M1-B cells?
- on the one hand the Headway cell has a lower maximum discharge rate (10C vs. 30C)
- and is slightly (8% or so) heavier per Ah
- on the other hand the state of charge ranges from fully charged to very much overcharged
It does not appear as if a fire must be expected in the course of reasonable or even unreasonable use.
Jan de Jong
BobsV35B(at)aol.com
PostPosted: Fri Nov 14, 2014 12:35 pm    Post subject: lithium facts Reply with quote
Good Afternoon Jeff,
And, if we stopped talking about lithium batteries, where would you post your reservations?
Personally. I think the more written about them, the better. You will notice that Boeing is still using the units as are most cell phones and other small electronic devices.
Happy Skies,
Old Bob
In a message dated 11/14/2014 2:26:19 P.M. Central Standard Time, jluckey(at)pacbell.net writes:
Jan,
-Jeff
PostPosted: Fri Nov 14, 2014 1:34 pm    Post subject: lithium facts Reply with quote
-Jeff
Haven't really prayed over the fire issue much. We
know that the True Blue enclosure was designed, tested
and qualified to contain the worst that a
catastrophic energy release can offer. At same
time, we know that to test the enclosure, the BMS
has to be bypassed and the battery abused with
a 42 volt charger and only after some considerable
time do cells begin to fail. Then they exude a mixture
of flammable gasses . . . which do not 'burn' for lack
of oxygen. The mixture is vented harmlessly over-board
while surface temperatures on the battery enclosure
remain quite modest.
In this case, the energetic mayhem going on within
the battery box isn't really a fire but simply an
array of cells in self-destruction . . . after one or
more cells is abused to failure thus triggering
a cascade.
This kind of testing is the sort of thing the
Navy's Battery labs in Crane, IN used to do.
I suspect they still do. Assume the worst even
if you have to trigger the event yourself . . .
then mitigate the outcome.
Obviously, many segments of the battery market
are embracing lithium products not the least of
which is motorcycles. There are many more
lithium batteries in service outside OBAM
aviation than inside it. The marketplace is
a huge laboratory for testing the general
robustness of available products. I've seen
anecdotal references to 'fires' with
lithium batteries on motorcycles. A couple were
attributed failure of a "mechanical" voltage
regulator to properly charge the battery.
Another spoke a wiring issue (it may have
be the battery wires burning . . . not the
battery).
Given the legacy aviation philosophy for
watching bus voltage and automatically
reacting to overvoltage conditions - combined
design limits that automatically 'soft-charge'
to 50% of chemical capacity, it seems
that the likelihood of an electrically
induced battery event is very low.
I think it unlikely that flame-proof battery
boxes will ever get a warm reception
in light aviation . . . at least not until
the "market laboratory" raises perceptions of
risk to higher levels of apprehension.
The really cool thing is that there are few
imperatives for making the lead->lithium
switch. Our airplanes will continue to fly
as they have for over 100 years. There is
both time and increasing opportunity to build
a well deserved confidence in the new
technology.
argoldman(at)aol.com
PostPosted: Fri Nov 14, 2014 5:08 pm    Post subject: lithium facts Reply with quote
Again, remember that there are several types of Li batteries each with it's own safety record. If we are talking safety of Li batteries and are only consideringt LIFePo4 then it is only appropriate that we refer only to the safety record of this type of battery.
Except for Cessna and Boeing, both of which, I believe used the cobalt variety, I am unaware of any type other than LiFePo4 as suggested for our aircraft. What the auto makers and computer/cell phone makers are using is probably different.
Rich
PostPosted: Sat Nov 15, 2014 11:49 am    Post subject: lithium facts Reply with quote
In case you are starting to consider EarthX for our airplanes.....
I had some interaction with Reg Nicoson, lead product engineer at
EarthX, a little over a year ago concerning unwanted buit-in OV cut-off
which ended with the following last and second-to-last message:
Tricky - there is voltage level, but there is also risetime.
Alternator OV relay is slow at say 15.0 V.
Battery OV mosfets are fast at say 16.0 V.
A fast step from 14.5 to 18 volts would give a 50 ms dropout or so.
Which can possibly be covered with a large capacitor across the bus.
It does get somewhat involved though.
Jan
On 10/1/2013 6:58 AM, Sales wrote:
You are correct, a BMS is required for safe and reliable operation. The
lithium cell high voltage cutoff has to be below 4volt per cell, or 16V for
the battery. Our high voltage cutoff is set to 15.5 volt, which is where
the mosfets start to turn off, but they don't completely turn off until
16.5V at the battery terminal (15.8volt at the lithium cells).
Is it possible to adjust your aircrafts OV protection setting to 15 -
15.5V?
If so I believe it would work.
Reg
I wonder if you would want to try and induce EartX to make an aviation
version of their batteries that don't have the buit-in OV cutoff,
replacing it with a stern warning that an external reliable fast OV
switch is mandatory. They could even sell one.
Jan de Jong
davevon
PostPosted: Mon Jan 05, 2015 8:07 am    Post subject: Re: lithium facts Reply with quote
Hi All,
Hope I'm not too late to join in on the discussion, I wish I would have seen this sooner. Greg over at B&C pointed me in this direction.
I'm in process of redoing the complete electrical system in a Laser 230 aerobatic airplane. The system had evolved into something that was very heavy, unsafe and just plain wrong in so many ways...
To save weight I bought an Aerovoltz/Ballistic LiFePo4 EVO2-16 battery. I'm using a B&C SD-8 with their external regulator and OV protection.
Researching charging voltages for the LiFePo4 chemistry I'm finding a large variation in recommendations.
The EV (Electric Vehicle) guys claim 3.33v/cell is 100% charged and shouldn't be taken beyond that. http://www.diyelectriccar.com/forums/showthread.php/you-all-destroying-your-lifepo4-cells-65336.html
Then I've seen a couple of places saying 3.65v/cell is 100% charged with a max voltage of 4.2v. http://www.powerstream.com/LLLF.htm
The stock B&C system charges at 14.4v and the OV protection is set 16v. Ballistic batteries is telling me to charge at 14.4v but don't go over or "bad things will happen". I'm sure that the OV protection has to be set more than even a .1v higher that the regulated voltage to prevent nuance trips.
I'm guessing that there's some variation between cell manufactures and their voltage specs and add to that the battery manufactures/assemblers add their safety margin which leads to a case like the Aerovoltz/Ballistic having no leeway between the charging voltage and do not go over voltage...
So is there a definitive answer???
Thank you for your time,
Dave
richard.beebe(at)yale.edu
PostPosted: Mon Jan 05, 2015 10:29 am    Post subject: lithium facts Reply with quote
On 01/05/2015 11:07 AM, davevon wrote:
<davevon(at)bellsouth.net>
I have an EV that I converted with LiFePo4 cells. While charging I
charge until the voltage hits 3.5v per cell (and I've heard that 3.65 is
the highest safe range but there's little added beyond 3.5v). I then
hold the voltage until the current drops to 0.05C.
After I stop charging the voltage will drop to somewhere around
3.2-3.3v. So maybe that's what the first voltage is about.
Since they're building batteries to replace lead-acid cells, its pretty
silly of them not to protect their batteries from "normal" lead-acid
voltages. If they have 4 cells, 14.4v is 3.6 per cell which should be
fine. The maximum of 4.2 x 4 = 16.8 so bad things shouldn't happen with
an occasional foray above 14.4 except perhaps shortening the life of the
battery.
I've found that there's quite a variation in knowledge about LiFePo4
cells among the people who are selling them and even among those
building them.
--Rick
PostPosted: Mon Jan 05, 2015 3:46 pm    Post subject: lithium facts Reply with quote
I've found that there's quite a variation in knowledge about LiFePo4 cells among the people who are selling them and even among those building them.
Gee . . . what was your first clue?
I've been sifting the lithium pile of sand for about 4 months.
I'll be writing an article for KitPlanes on some of my findings.
In brief, I believe I am on solid ground with the following
assertions:
LiFePo4 IS the chemistry of choice
The MAX charge voltage for LiFePo4 is 4.2 volts per
cell.
Sift through the spec sheets for commercial offerings
of LiFePo4 and you'll find MOST cells "rated" at 3.7V
charge, 3.3V nominal delivery point.
Here are some exemplar performance curves one particular
cell
[img]cid:.0[/img]
Note that charging at 4.2 volts nearly DOUBLES the cell's contained
energy. Stack 4 cells in series to perform in a 14v system and
you would have to charge the battery at 16.8 volts. A tad high for
many 14V bus operated devices . . . and perhaps out of reach for
many voltage regulators.
It's a little different ball game for consumer products that discharge
lithium cells with switchmode power supplies. You can order chargers
rated for EITHER 3.7 or 4.2 volts per cell. There are no caveats
offered for the use of these chargers with any of the COTS lithium
products . . .hence, no big risk . . . but a substantial difference
in cell performance.
3.7 x 4 is 14.8 volts . . . right in the ball park for plug-n-play
replacement of SLVA with Lithium. Yes, STORED energy is 1/2 but service
life gets a real boost . . . and risk for electrically induced damage
to the battery goes way down. The AeroVoltz 3x4 array I tested clocked
in at just over 7AH capacity when charged on a 14.5V bus.
Cells promoted in the wild are burdened with some outrageous
claims for capacity . . . John Q. Public has few tools or skills
to determine if his purchase was righteous or not . . . so the flim-flammers
get away with it. MOST of the cells I've sampled off eBay were not
worth the postage to get them onto my workbench . . . however,
some are quite good.
Balancing chargers are another story . . . but the bottom line is
that the COTS offerings of lithium drop-ins for SVLA battery
boxes don't come with a lot of hazard to anything but your
pocketbook. As the lithium market matures, we may well be
speaking of 16 volt systems for future airplanes.
 Filesize:  94.65 KB
 Viewed:  17920 Time(s)
davevon
PostPosted: Tue Jan 06, 2015 8:21 am    Post subject: Re: lithium facts Reply with quote
Thanks to those who responded! I'm going to carry on with a plug-n-play setup.
Does anyone have more of a back story of what took place with this fire? I'm assuming poor voltage regulation or a short? It took place a while back and there hasn't been much discussion on it.
http://www.heavenboundaviation.com/documents/AerovoltzbatteryfirePDF.pdf
Dave
rlborger(at)mac.com
PostPosted: Tue Jan 06, 2015 9:15 am    Post subject: lithium facts Reply with quote
Dave,
That’s an interesting LiFePo story, because that chemistry is supposed to be fire safe.
Maybe poor voltage regulation, but probably a short inside or outside the battery.
Ugly result that could have been a heck of a lot uglier if he hadn’t put it on the ground when he did.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
Dave
PostPosted: Tue Jan 06, 2015 9:59 am    Post subject: lithium facts Reply with quote
plug-n-play setup.
Thanks for the heads-up on this . . . you guys offer a wider
spectrum of eyes-n-ears than I can muster on my own. I'll
see if I can find out more about this incident.
PostPosted: Tue Jan 06, 2015 10:07 am    Post subject: lithium facts Reply with quote
At 11:13 2015-01-06, you wrote:
Dave,
That's an interesting LiFePo story, because that chemistry is
Ugly result that could have been a heck of a lot uglier if he hadn't
Unfortunately, the carcass will probably not be
closely examined. The actual burning may have been
limited to plastic in the case but initiated by
a catastrophic fault within the battery.
Unless the 'event' involves a TC aircraft, personal
injury or serious loss of airframe, the NTSB won't have
much interest in spending $thousands$ to deduce root
cause . . . and AeroVoltz is probably not going to
pursue a microscopic examination either.
This happened a long time ago. I'll write AeroVoltz
to see what they have to contribute to understanding.
Given the smaller/lighter characteristics of the
LiPo batteries, it's probably not a serious weight
hit to consider stainless boxes with fire-resistant
linings or some such . . . it may be that some approach
similar to the True Blue Power packaging improves
the FMEA.
PostPosted: Tue Jan 06, 2015 12:02 pm    Post subject: lithium facts Reply with quote
Fire-safer but not fire safe. The older Lithium Cobalt will start to
break down--and perhaps enter thermal runaway--at around 160C. These are
the ones that gave lithium its bad rep. LiFoPo4 doesn't start to break
down until around 300C. That said I don't think these cells entered
thermal runaway. I suspect maybe one of the cells developed an internal
short and either it got hot or--because they were receiving too much
voltage without that one cell in play--the others did. Then the plastic
case melted and caught on fire. If the cells were actually on fire it's
not likely that him dribbling his water bottle on it would have put the
fire out.
So my question to AeroVoltz would be what the case is made of and are
they using the same plastic now?
--Rick
On 01/06/2015 12:13 PM, Robert Borger wrote:
<rlborger(at)mac.com>
Dave,
the battery.
Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914,
Airmaster C/S Prop (75 hrs). Little Toot Sport Biplane, Lycoming
Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331
Cel: 817-992-1117 rlborger(at)mac.com
plug-n-play setup.
PostPosted: Tue Jan 06, 2015 1:47 pm    Post subject: lithium facts Reply with quote
are they using the same plastic now?
Agreed . . . good put . . .
davevon
PostPosted: Tue Jan 06, 2015 3:41 pm    Post subject: Re: lithium facts Reply with quote
I think the Aerovoltz and Ballistic batteries may be the same with different covers (different logo is all).
Ballistic:
http://www.ballisticparts.com/product_info.php?cPath=141&products_id=428
Aerovoltz:
http://www.aerovoltz.com/av16.html
Dave
PostPosted: Thu Jan 08, 2015 8:27 am    Post subject: lithium facts Reply with quote
Ballistic:
Aerovoltz:
Dave
Seems probable . . . I've read somewhere that AeroVoltz
is housed in ABS plastic . . . not exactly renowned for
a resistance to combustion.
Page 4 of 4
