air entering fuel system on suction side - or is my Pierburg
uuccio(at)gmail.com
PostPosted: Sat Jun 21, 2014 11:57 pm    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Hi Folks,
Yesterday was supposed to be my final fuel flow test before taking to the
air again. I have recently installed a fuel return line in my 912 system
and also a fuel pressure gauge. The a/c is a Kitfox tri-gear, so high-wing
with tanks in each wing and a header tank located behind the seats. The
fuel flow test was performed on the ground with the aircraft in "take-off"
attitude with tail on the ground (approx 17 degrees).
Previous tests showed 100 l/hr (26 gal/hr) at the exit of the electrical
fuel pump and before the mechanical pump. This time, to be more realistic,
I measured the fuel flow after the mechanical fuel pump, at the entry of the
4-way junction that goes the carbs and to the fuel return line. In 18
minutes, the pump put out 18 litres, so 60 l/hr (16 gal/hr), which is still
acceptable, though 40% lower than the first measurement. But then,
something strange happened: the fuel flow went down dramatically, to approx.
20 l/hr (just over 5 gal/hr). I checked the gascolator and found it to be
clean.
A further investigation revealed that the fuel that was being pushed out
contained some air bubbles, which to me means that air must be entering the
fuel circuit on the suction side of the electrical pump. Or else the
electrical fuel pump is somehow broken and is letting air in. A further
data point is that if I hook up all the hoses and run the electrical fuel
pump the fuel pressure gauge indicates lower than usual pressure (0.25 bar
instead of 0.45 bar).
So before I go and investigate the suction side of the fuel system I'd like
to ask any experts out there:
1) Is it possible that I damaged the electrical fuel pump by letting it run
continuously for 20 minutes?
2) Is anyone aware of such failure modes for the Pierburg electrical fuel
pump?
3) How would you go about investigating the suction side of the fuel
system? My idea was to disconnect the hose at the exit of the fuel pump
and clamp it closed and then pressurize the circuit between the header tank
and the exit of the electrical fuel pump with an airline and search for
bubbles using soap water.
Thanks in advance for any help... the weather is beautiful flying weather
but I'm grounded until I can sort this out SadSadSad
Sacha
williamtsullivan(at)att.n
PostPosted: Sun Jun 22, 2014 4:27 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Sacha- I can think of a couple of things to check before blaming the pump. First, are the tanks vented? Are the vents functioning? Second, make sure that there isn't something blocking the fuel intake. I had this problem once on a new piece of equipment with a diesel engine. It would sit and run at full throttle for hours, but if it went down the street it would suck air, and shut the engine down. It drove us nuts for a while, until we pulled the fuel tank and found a 1" square piece of masking tape drifting around in the fuel. When it sloshed over to the sucker tube, it blocked it and shut down the engine. Air in the fuel always makes me think of that. We found it by pulling the plug at the bottom and trying to drain it. The fuel would stop running. Poke a wire in there, and it would run again. It was invisible when soaked with fuel. We had to pull the tank to get it out. The tape had been used to cover all openings when shipped from one
factory to another, and a piece dropped in when the manufacturer pulled it off.
Bill Sullivan
On Sun, 6/22/14, Sacha <uuccio(at)gmail.com> wrote:
Subject: air entering fuel system on suction side - or is my Pierburg electrical pump broken?
To: rotaxengines-list(at)matronics.com
Date: Sunday, June 22, 2014, 3:56 AM
--> RotaxEngines-List message
posted by: "Sacha" <uuccio(at)gmail.com>
Hi Folks,
taking to the
seats. ----
being pushed out
be entering the
pump.
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
ptag.dev(at)talktalk.net
PostPosted: Sun Jun 22, 2014 9:52 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Hi! Sacha,
Have you checked the thimble filter in the Pierburg electrical pump? It
needs a very sharp needle or pointed hooked instrument but only apply it to
the plastic collar and be careful replacing it with a wooden very blunt
pencil pushed home in to place very carefully, do not damage the gauze
filter element because they will NOT supply a replacement .....it would need
an entirely new pump.
Bob Harrison Europa G-PTAG c/w 914 Rotax and two electric fuel pumps.
uuccio(at)gmail.com
PostPosted: Mon Jun 23, 2014 10:51 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
On Jun 22, 2014, at 14:26, william sullivan <williamtsullivan(at)att.net> wrote:
Thanks Bill. I've been away from the hangar (and email) for a few days but I will check it this week.
uuccio(at)gmail.com
PostPosted: Mon Jun 23, 2014 10:52 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Bob thank you. I will check it this week. Hopefully I don't need a new pump....
uuccio(at)gmail.com
PostPosted: Tue Jun 24, 2014 7:16 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Hi Bill,
I took the header tank off today, emptied and cleaned it. It had some
silicon gasket material left over from when I installed the fuel level
sender. Occasionally bits would float around and block the exit orifice and
cause fuel flow to slow down substantially, exactly as you described. I
expect things will go back to normal as soon as I re-mount the tank.
Thanks again for the help!
Sacha
PostPosted: Tue Jun 24, 2014 7:43 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Sacha- nice find. I have also had trouble with Teflon tape. If you overlap the end of a fitting, it will tear off and clog a filter. Good luck.
On Tue, 6/24/14, Sacha <uuccio(at)gmail.com> wrote:
Subject: RE: air entering fuel system on suction side - or is my Pierburg electrical pump broken?
Date: Tuesday, June 24, 2014, 11:16 AM
Hi Bill,
it.  It had some
fuel level
described.  I
the tank.
Sacha
PostPosted: Tue Jun 24, 2014 9:05 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Silicone seal/products don't get along well with gasoline.
They are not fuel resistant and will cause many fuel related
problems.
Rock House, Oregon
uuccio(at)gmail.com
PostPosted: Tue Jun 24, 2014 11:17 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Yes indeed. I should have just mounted the sender with the cork gasket that came with it.
problems.
PostPosted: Wed Jun 25, 2014 5:26 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Sacha- Never use any of the RTV sealants with a cork/rubber gasket. The RTV will cause the gasket to crumble later on. I think the solvent in the RTV dissolves the latex.
Bill Sullivan
Subject: Re: air entering fuel system on suction side - or is my Pierburg electrical pump broken?
To: "rotaxengines-list(at)matronics.com" <rotaxengines-list(at)matronics.com>
Date: Tuesday, June 24, 2014, 3:17 PM
posted by: Sacha <uuccio(at)gmail.com>
gasoline.
related
> problems.
              -Matt
Dralle, List Admin.
uuccio(at)gmail.com
PostPosted: Wed Jun 25, 2014 8:41 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Thank you. I'm not sure what RTV is. I used some red stuff which I thought was for engine gaskets. I think Motorsil was the brand. Anyway just to be sure I'll remove it as it serves no useful purpose.
Sacha
On Jun 25, 2014, at 15:26, william sullivan <williamtsullivan(at)att.net> wrote:
Bill Sullivan
gasoline.
related
> problems.
-Matt
Dralle, List Admin.
PostPosted: Thu Jun 26, 2014 5:43 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
RTV stands for "Room Temperature Vulcanizing". Comes in a tube, and has at least 3 colors- blue, red, and black, indicating useful temperature, and whether or not it cures in the presence of air, or the absence of it. It is designed to take the place of gaskets, or to skim coat paper ones. Works great, except on the cork gaskets. You can find it at an auto parts store.
Date: Wednesday, June 25, 2014, 12:40 PM
Sacha
            Bill Sullivan
broken?
the
> gasoline.
fuel
> related
>> problems.
   -Matt
> Dralle, List Admin.
              -Matt
Dralle, List Admin.
PostPosted: Thu Jun 26, 2014 6:11 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Bill S:
Are all RTV sealants fuel safe?
Are they to be confused with silicone seal?
Rock House, Oregon
PostPosted: Thu Jun 26, 2014 6:37 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
John- I know that one is fuel resistant- red, I think. Pretty sure it's silicone seal. My experience is very limited, so I only remember some of the cautions with the stuff. I had a friend who bought a used Cadillac with a freshly rebuilt motor. The cork oil pan gasket dissolved, and cost him an engine rebuild.
Date: Thursday, June 26, 2014, 10:10 AM
posted by: "John Hauck" <jhauck(at)elmore.rr.com>
Comes in a
paper
You can
Bill S:
Rock House, Oregon
              -Matt
Dralle, List Admin.
PostPosted: Thu Jun 26, 2014 7:28 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Bill S:
Back in 1987, silicone seal caused a low power situation
that put me into the Sebring High School football field.
Had used silicone seal to seal the vent hole in the Ken
Brock seat tank filler cap so I could convert to a vent that
exited the bottom of the aircraft and prevent fuel from
dumping inboard should I go upside down on the ground again.
Tiny balls of silicone seal effectively blocked the valves
in the squeeze bulbs we used to use back then.
Rock House, OR
PostPosted: Thu Jun 26, 2014 7:38 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
I seem to remember that silicone seal (RTV) was being used at automotive factories to replace a lot of gaskets, some time in the 1980's. Worked great for differential covers, etc. The biggest problem I ran into was that we weren't sure where, or what type, to use. Best bet is to bring your glasses to the auto parts store and read all that very tiny print on the packages. Where I worked, the most common type was blue- we called it "Blue Goo". Stunk like hell, and hardened in the tube if it sat around for a while. Maybe Roger or somebody with a lot more practical knowledge can chime in on this. I was in truck equipment, not automotive.
Date: Thursday, June 26, 2014, 11:28 AM
think.
a
dissolved,
Bill S:
that
again.
Rock House, OR
              -Matt
Dralle, List Admin.
uuccio(at)gmail.com
PostPosted: Sat Jun 28, 2014 1:38 pm    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
Ok so I got rid of all the silicone sealant and cleaned the cork gasket which seals the VDO sender (it's quite a big gasket with a 40mm diameter hole in the centre and five 5mm holes for the screws around the perimeter).
Well guess what? The cork seal leaks badly. So I'm back to square one, I need to find a way to seal the VDO sender on the top of my header tank. I have some silicone rubber which I thought of cutting to size and using. What do folks think?
Another solution would be to use the same red silicone sealant as I used before but only to apply it on the exterior of the tank. I'm concerned it might eat into the cork though as someone (John?) mentioned.
PostPosted: Sat Jun 28, 2014 2:11 pm    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
I would definitely keep silicon sealant away from any fuel
system.
Your silicone coated cork gasket is trash. Silicone seal
causes the gasket to squeeze out and leak.
You can get several fuel tank sealant cartridges from
Aircraft Spruce that work well. Also cut your own gasket.
Kolb MKIII
Boise, Idaho
Roger Lee
PostPosted: Sat Jun 28, 2014 4:03 pm    Post subject: Re: air entering fuel system on suction side - or is my Pier Reply with quote
Get a new gasket. The buy some Hylomar. This is meant to be used around fuel and will not leak. Do not over use it. I little thin film on each surface will seal just fine.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
ptag.dev(at)tiscali.co.uk
PostPosted: Sun Jun 29, 2014 6:05 am    Post subject: air entering fuel system on suction side - or is my Pierburg Reply with quote
I recommend you use HYLOMAR sealant made in the USA under licence and
developed by Rolls Royce Aero Engines for all fuel and oil related joints.
But use it very sparingly and especially as mentioned on the instructions.
I would never make any oil or fuel related joint without it.
Bob Harrison Rolls Royce Aero Engine trained .Europa G-PTAG Rotax 914
