rob(at)robsglass.com Guest
Posted: Sun Jan 01, 2006 6:03 pm Post subject: Bulb and connector source. |
Harley <harley(at)AgelessWings.com> wrote with the answer to the "Eyeball Light
Question" So maybe he or one of the other cognoscenti on the list can help
with my query.
I have an (older) Airpath compass with MS17983-2 on the front. It has a
flip up hood at the top of the front which looks to be where a cylindrical
bulb should be inserted. It states that it is for 28v but I can see no
reason why 12v won't work. Is this a correct assumption and does anyone
know of a source/ part number for a 12v version of this which might work?
The back of the compass has a co-axial push on connection for the electrical
supply. Can anyone suggest a source / part number for this too?
Rob
Rob W M Shipley
N919RV (res) Fuselage .....still!
La Mesa, CA. (next to San Diego)
I am using the free version of SPAMfighter for private users.
It has removed 10539 spam emails to date.
Paying users do not have this message in their emails.
Try www.SPAMfighter.com for free now!
harley(at)AgelessWings.co Guest
Posted: Mon Jan 02, 2006 7:23 am Post subject: Bulb and connector source. |
Morning, Rob...
That's me!
And, I'm in the same position you are...an airpath compass with no bulb
(to check the number of, so I can cross it's specs to find a compatible
12-14 volt version). And, at the moment, it's stored on a shelf down in
my hangar...about 25 miles from here, and freezing rain predicted for
today!
So, I ain't going nowhere.
So...a bit of time with Google (searching for Airpath compasses, then
repair parts) found the following:
330 - 14V Light Bulb <http://www.gyrohouse.com/catalog/items/item602.html>
14V Light Bulb - T 1-3/4 Midget Flange Base. .08 Amps
Cat No: 330 $3.00
334 - 28V Light Bulb <http://www.gyrohouse.com/catalog/items/item604.html>
28V Light Bulb - T 1-3/4 Midget Groove Base. .04 Amps
Cat No: 334
Now we both know!
Harley Dixon
with my query.
Rob
Rob W M Shipley
nuckollsr(at)cox.net Guest
Posted: Mon Jan 02, 2006 8:11 am Post subject: Bulb and connector source. |
At 10:24 AM 1/2/2006 -0500, you wrote:
Morning, Rob...
That's me!
today!
Cat No: 330 $3.00
Cat No: 334
here are the data sheets on these lamps:
http://www.aeroelectric.com/Mfgr Data/Lamps/T1p75 lamps.pdf
You can purchase from Allied at:
http://www.alliedelec.com/catalog/pf.asp?FN=1531.pdf
Posted: Mon Jan 02, 2006 8:52 am Post subject: Bulb and connector source. |
lm4(at)juno.com Guest
Posted: Mon Jan 02, 2006 9:08 am Post subject: Bulb and connector source. |
Guy's
My Airpath ( pilots standby compass ) is placarded
as a 28 volt system. The lamp in it is a 6e327.
then repair parts) found the following:
Cat No: 330 $3.00
Cat No: 334
Now we both know! |
Harley Dixon
Quote: | >I have an (older) Airpath compass with MS17983-2 on the front. It
has a
cylindricalbulb should be inserted. It states that it is for 28v but I
can |
Quote: | see noreason why 12v won't work. Is this a correct assumption and does
Quote: | anyoneknow of a source/ part number for a 12v version of this which
might |
Quote: | work?The back of the compass has a co-axial push on connection for the
electricalsupply. Can anyone suggest a source / part number for this
too? |
Posted: Mon Jan 02, 2006 10:05 am Post subject: Bulb and connector source. |
Larry...
It appears you may have hit on something here.
After your post, I rechecked, "GyroHouse" and they do indeed list the
334 as the 28 volt bulb for the Airpath Compass. But, on checking the
configuration of the 334, it is a grooved base bulb...the 327 (which is
what you have) and the 330 are flanged bases.
Looks like GyroHouse may be selling the wrong bulb for a 28 volt system.
Harley
Larry Mac Donald wrote:
Guy's
Posted: Mon Jan 02, 2006 2:35 pm Post subject: Bulb and connector source. |
Harley,
I don't know what to say. I have two such
compasses and both have the same type of lamp.
One has no markings and one is marked GE327.
Both are "miniature". Both are "flange based".
I was unable to get to "lamps" in Gyrohouse so
I cannot look them up or go any furthur.
Larry Mac Donald
lm4(at)juno.com
Rochester N.Y.
Do not achcive
On Mon, 02 Jan 2006 13:05:56 -0500 Harley <harley(at)AgelessWings.com>
writes:
<harley(at)agelesswings.com>
kayce33(at)earthlink.net Guest
Posted: Mon Jan 02, 2006 3:20 pm Post subject: Bulb and connector source. |
I just checked the Grainger catalog and try 1C904.
It's aT1 3/4 SC mid flg, 14 V Aircraft, .08A (at) $1.30
Harold
Posted: Mon Jan 02, 2006 3:35 pm Post subject: Bulb and connector source. |
Hi, Larry...
I agree with you. I think Gyrohouse made an error in their listing of
the one. They do list the 334 (grooved base) as the 28 volt bulb for the
airpath compass!
After it warmed up a bit today, I took a trip down to the hangar and
took a look at mine...it is indeed a flanged base socket...a grooved
base bulb MIGHT work, but it would probably not have dependable contact.
Of course, Airpath may have used one like that in another of their
models, but I doubt it. Looks like the flanged base bulb is the one to
use. 327 for 28 volt, and 330 for 14 volt.
A little off topic, but points out the printed errors that can occur is
in a book that my son gave me for Christmas. The Encyclopedia of Civil
Aircraft. Covers everything from DaVinci to Rutan....lists Rutan's
Voyager as having a range of 9,600 miles! It really was a miracle non
stop around-the-world flight! <G>
>>I was unable to get to "lamps" in Gyrohouse so I cannot look them up
or go any furthur.<<
Here's where they list it...with the light socket.
www.gyrohouse.com/catalog/items/item807.html
Harley
Harley,
Larry Mac Donald
lm4(at)juno.com
Rochester N.Y.
Do not achcive
writes:
Posted: Mon Jan 02, 2006 4:47 pm Post subject: Bulb and connector source. |
Harley,
Agreed. I just found the Grainger site and went
thru 9 pages of lamps. What I have is what the picture
shows. It looks like you "we" could use either the
GE382-14V-.08A-.3C (at)$1.26 or the
GE330-(aircraft)-14V-.08A-.5C (at) $1.30. .2 more candeles
for only 4 cents more, AND it says aircraft on it.
Larry Mac Donald
lm4(at)juno.com
Rochester N.Y.
Do not achcive
On Mon, 02 Jan 2006 18:35:16 -0500 Harley <harley(at)AgelessWings.com>
writes:
Hi, Larry... |
Quote: | of the one. They do list the 334 (grooved base) as the 28 volt bulb for
Quote: | the airpath compass! After it warmed up a bit today, I took a trip
down to the hangar and took a look at mine...it is indeed a flanged |
base socket...a grooved base bulb MIGHT work, but it would
Quote: | models, but I doubt it. Looks like the flanged base bulb is the one
to use. 327 for 28 volt, and 330 for 14 volt.
A little off topic, but points out the printed errors that can occur |
Quote: | is in a book that my son gave me for Christmas. The Encyclopedia of
Civil Aircraft. Covers everything from DaVinci to Rutan....lists
Rutan's |
Quote: | Voyager as having a range of 9,600 miles! It really was a miracle non
stop around-the-world flight! <G>I was unable to get to "lamps"
in Gyrohouse so I cannot look them up or go any furthur.<< |
Quote: | Harley
Larry Mac Donald wrote: |
>Larry Mac Donald
>lm4(at)juno.com
>Rochester N.Y.
LarryIt appears you may have hit on something here. |
do indeed list the 334 as the 28 volt bulb for the Airpath
Compass. But, on checking the configuration of the 334,
it is a grooved base bulb...the 327 (which is what you have)
and the 330 are flanged bases.Looks like GyroHouse may
Harley
>>>Guy's
>>>>bulb
Posted: Mon Jan 02, 2006 6:16 pm Post subject: Bulb and connector source. |
>>GE382<<
I like this one better for an additional reason....it has a life of
15,000 hours vs 4,000 for the 327!
Harley
Harley,
Larry Mac Donald
lm4(at)juno.com
Rochester N.Y.
Do not achcive
writes:
