RotaxEngines-List Digest: 3 Msgs - 05/24/14
goodings(at)yorku.ca
PostPosted: Sun May 25, 2014 11:47 am    Post subject: RotaxEngines-List Digest: 3 Msgs - 05/24/14 Reply with quote
Subject: Re: Blue coolant tubing for Rotax 912S
We need to replace the large thin-walled blue coolant tubing on our Rotax
912S. I should be grateful if someone can tell me (a) the diameter; (b)
the length we need, (c) possible suppliers, and (d) a Canadian supplier if
that is possible. Our CH601HD is in Ottawa (Carp), and I have to order
the tubing from Toronto. All I can recall is that this tubing has a
rather special diameter, and is rather hard to find. Thanks for your
help.
John Goodings, C-FGPJ, CH601HD with R912S, Toronto/Ottawa/Carp
rickofudall
PostPosted: Mon May 26, 2014 6:08 am    Post subject: RotaxEngines-List Digest: 3 Msgs - 05/24/14 Reply with quote
John, All the info regarding lengths of tubing and the part no. are in the IPC. You can use the part no. to get the ID of the tubing. Pegasus Racing has metric silicon radiator hose. Pricey, but less than Rotax, and lasts longer.
Rick Girard
On Sun, May 25, 2014 at 2:46 PM, John Goodings <goodings(at)yorku.ca (goodings(at)yorku.ca)> wrote:
--> RotaxEngines-List message posted by: John Goodings <goodings(at)yorku.ca (goodings(at)yorku.ca)>
From: John Goodings <goodings(at)yorku.ca (goodings(at)yorku.ca)>
We need to replace the large thin-walled blue coolant tubing on our Rotax 912S.  I should be grateful if someone can tell me (a) the diameter; (b) the length we need, (c) possible suppliers, and (d) a Canadian supplier if that is possible.  Our CH601HD is in Ottawa (Carp), and I have to order the tubing from Toronto.  All I can recall is that this tubing has a rather special diameter, and is rather hard to find.  Thanks for your help.
nes-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
MS -
e -
         -Matt Dralle, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
  - Groucho Marx
