Problem on 912ULS
max8992
PostPosted: Sun Apr 27, 2014 1:49 am    Post subject: Problem on 912ULS Reply with quote
Hi There all,
Cold start ok, run smooth (at)2500 rpm, when temp ok can run till 5800 rpm but
test (at)3850 rpm fails on EACH (same on one or the other) circuit alone :
loose 700 RPM and runs rough and not equilibrated. Back to a quasi smooth
run when on both circuits!
Any Idea?
Max Cointe
mcointe(at)free.fr
F-PMLH Europa XS_TriGear
Kit #560-2003 912ULS/AirmasterAP332 490 hours
F-PLDJ Dyn’Aéro MCR 4S
Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures
-----Message d'origine-----
De : owner-rotaxengines-list-server(at)matronics.com
[mailto:owner-rotaxengines-list-server(at)matronics.com] De la part de
rparigoris
Envoyé : mercredi 4 juillet 2012 00:36
À : rotaxengines-list(at)matronics.com
Objet : I wish there was a Rotax 9XX video like this.
--> <rparigor(at)suffolk.lib.ny.us>
I wish there was a 9XX video like this:
http://jalopnik.com/5922349/watch-an-engine-rebuild-itself-in-this-3000+phot
o-stop+motion-video
Ron Parigoris
http://forums.matronics.com/viewtopic.php?p=377182#377182
Max8992
Europa XS #560 F-PMLH
Roger Lee
PostPosted: Sun Apr 27, 2014 5:48 am    Post subject: Re: Problem on 912ULS Reply with quote
You need to check the ignition grounds at the switch and at the ignition modules and check all other wires at the modules plugs. If you loose 700 rpm it can't be running smooth as you think.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
williamtsullivan(at)att.n
PostPosted: Sun Apr 27, 2014 7:01 am    Post subject: Problem on 912ULS Reply with quote
Max- Are you talking about a magneto test? If so, you may have a dirty plug or bad wire on each circuit.
      Bill Sullivan
Sent: Sunday, April 27, 2014 5:48 AM
Subject: RotaxEngines-List: Problem on 912ULS
--> RotaxEngines-List message posted by: "Max Cointe (Free)" <mcointe(at)free.fr (mcointe(at)free.fr)>
Hi There all,
Any ref="http://www.matronics.com/Navigator?RotaxEngines-List" target="_bla//forums.matronics.com/" = --> [quote][b]
max8992
PostPosted: Sun Apr 27, 2014 9:12 am    Post subject: Problem on 912ULS Reply with quote
Hi Bill and Roger Lee,
Thks both for your answers. As a matter of fact I just mixed and matched the plugs on cylinders 2 and 4 on the lower sparks. So on one mag whichever it was the cylinders 2 and 4 weren’t lighted. So I have asked someone to kick my a.. after having  reconnected everything right!
Have good flights, rgds
Max  Cointe
De : owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] De la part de william sullivan
Envoyé : dimanche 27 avril 2014 17:01
Objet : Re: Problem on 912ULS
        Bill Sullivan
From: Max Cointe (Free) <mcointe(at)free.fr (mcointe(at)free.fr)>
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
Subject: Problem on 912ULS
Hi There all,
<![if !supportLineBreakNewLine]><![endif]>
          - The RotaxEngines-List Email Forum ---> http://www.matronics.com/Navigator?RotaxEngines-List               - MATRONICS WEB FORUMS -
Max8992
Roger Lee
PostPosted: Mon Apr 28, 2014 6:55 am    Post subject: Re: Problem on 912ULS Reply with quote
yep, that would do it.
Roger Lee
Tucson, Az.
Cell 520-349-7056
capedavis(at)yahoo.com
PostPosted: Thu May 08, 2014 5:24 am    Post subject: Problem on 912ULS Reply with quote
is there anyone here
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly?
On Sunday, April 27, 2014 1:21 PM, Max Cointe (Free) <mcointe(at)free.fr> wrote:
[quote] Hi Bill and Roger Lee,
Thks both for your answers. As a matter of fact I just mixed and matched the plugs on cylinders 2 and 4 on the lower sparks. So on one mag whichever it was the cylinders 2 and 4 weren’t lighted. So I have asked someone to kick my a. after having reconnected everything right!
Max Cointe
    Bill Sullivan
Hi There all,
rlborger(at)mac.com
PostPosted: Thu May 08, 2014 5:41 am    Post subject: Problem on 912ULS Reply with quote
Chris,
Yes, we're out here. I remember that you posted a question a while back. And I remember that I didn't have an answer for you at that time. Perhaps there were no other answers as well. Try posting the question again and see if it helps.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914 w/ Intercooler & Airmaster C/S Prop
Little Toot Sport Biplane, Lycoming AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
H: 940-497-2123
C: 817-992-1117
Chris Davis
KXP 503 492 hrs
Glider Pilot
[/quote]
.msg-quote #yiv8656237889 _filtered #yiv8656237889 {font-family: Helvetica;} .msg-quote _filtered #yiv8656237889 {font-family: 'Cambria Math';} .msg-quote _filtered #yiv8656237889 {font-family: Calibri;} .msg-quote _filtered #yiv8656237889 {font-family: Tahoma;} .msg-quote _filtered #yiv8656237889 {font-family: Consolas;} .msg-quote #yiv8656237889 #yiv8656237889 p.yiv8656237889msonormal, #yiv8656237889 li.yiv8656237889msonormal, #yiv8656237889 div.yiv8656237889msonormal {margin: 0cm 0cm 0.0001pt; font-size: 12pt; font-family: 'Times New Roman', serif;} .msg-quote #yiv8656237889 a:link, #yiv8656237889 span.yiv8656237889msohyperlink {color: blue; text-decoration: underline;} .msg-quote #yiv8656237889 a:visited, #yiv8656237889 span.yiv8656237889msohyperlinkfollowed {color: purple; text-decoration: underline;} .msg-quote #yiv8656237889 pre {margin: 0cm 0cm 0.0001pt; font-size: 10pt; font-family: 'Courier New';} .msg-quote #yiv8656237889 p.yiv8656237889msoacetate, #yiv8656237889 li.yiv8656237889msoacetate, #yiv8656237889 div.yiv8656237889msoacetate {margin: 0cm 0cm 0.0001pt; font-size: 8pt; font-family: Tahoma, sans-serif;} .msg-quote #yiv8656237889 span.yiv8656237889prformathtmlcar {font-family: Consolas;} .msg-quote #yiv8656237889 span.yiv8656237889emailstyle19 {font-family: Calibri, sans-serif; color: rgb(31, 73, 125);} .msg-quote #yiv8656237889 span.yiv8656237889textedebullescar {font-family: Tahoma, sans-serif;} .msg-quote #yiv8656237889 span.yiv8656237889spelle {} .msg-quote #yiv8656237889 .yiv8656237889msochpdefault {font-size: 10pt;} .msg-quote _filtered #yiv8656237889 {margin: 70.85pt;} .msg-quote #yiv8656237889 div.yiv8656237889wordsection1 {}
