h&jeuropa
Posted: Thu Apr 24, 2014 11:58 am Post subject: Blinking Charge Light |
Our electrical system has worked without a problem for 500 hours and 5 years. Recently the charge lite has begun to blink on and off while in flight. It is still on solid at low rpm or engine off and gets dimmer and finally goes off as the rpm is increased (around 3000 rpm). But during cruise at 5000 rpm, it blinks off and on. And this behavior seems a little intermittent. First noticed it 2 flights ago. The next flight was fine and today it was fine for the first half of the flight and then blinked the last half.
Yet the engine monitor shows the voltage constant at 13.2 volts and current into the battery varying between 2 and 4 amps. These are the same as have been for years.
Any ideas or suggestions?
Jim & Heather
Europa XS 914
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
klinefelter.kevin(at)gmai Guest
Posted: Thu Apr 24, 2014 5:18 pm Post subject: Blinking Charge Light |
Check the gound connection for corrosion.
Kevin
Quote: | On Apr 24, 2014, at 12:58 PM, "h&jeuropa" <butcher43(at)att.net> wrote:
Jim & Heather
Europa XS 914
http://forums.matronics.com/viewtopic.php?p=422329#422329
lyleapgmc
Posted: Thu Apr 24, 2014 6:47 pm Post subject: Blinking Charge Light |
The Charge Light is blinking. That only tells you that the indicator
light is blinking. Start there. The fault may only be the light. If
the light checks OK then move on to grounds, the wiring, etc.
Think of all the stories of the parts replacement technician at the
local auto dealer. His computer says the MAP sensor is bad. He
replaces it and one of two things happen. The problem goes away but
actually it is cured because the act of disconnecting it "cleaned" the
connection. Or, the computers says the oxygen sensor is bad. Replacing
it does one of the same two things.
The next day the guy's wife loses the gas cap. A new one is installed
and, voila, the problem goes away.
On 4/24/2014 8:17 PM, Kevin Klinefelter wrote:
Kevin
> Jim & Heather
> Europa XS 914
Sent from my Gateway E4610D
Lyle
h&jeuropa
Posted: Tue Apr 29, 2014 11:44 am Post subject: Re: Blinking Charge Light |
Problem solved! Pulled each fast-on terminal off the regulator and pushed it back on again, cleaning the contact. Also cleaned the ground connection. All is well. Thanks for the suggestions.
Jim & Heather
