oil change question
henryroden
PostPosted: Sun Apr 06, 2014 8:28 am    Post subject: oil change question Reply with quote
I just changed the oil at 19 hours from first start. I was going to change it at 20 hours but had the cowl off so went ahead. Drained the tank after burping the engine and replaced the filter. After putting 3.25 qts. back in the tank, which is just a little less than what I drained out, the oil level is above the dipstick hole. Pulled the prop. through 15-20 revolutions and ran the starter for 6-7 seconds, ignition off, no oil pressure and level did not go down. Pressurized the tank, via the oil blow by line, to about 7-8 # with no change. This did not happen when I first filled the tank with oil. What am I doing wrong? Is it safe to start and check the oil pressure within 30 seconds?
jnjrob(at)gmail.com
PostPosted: Sun Apr 06, 2014 8:46 am    Post subject: oil change question Reply with quote
If your start switch is also the master you have no power to the senders in
the start mode. Check for pressure just as you release the start mode but
the switch is still on.
Jim
rickofudall
PostPosted: Sun Apr 06, 2014 5:52 pm    Post subject: oil change question Reply with quote
Krazy, NO! If you truly believe you don't have oil pressure it is definitely NOT safe to start the engine. The 912 does not tolerate no or low oil pressure and long before that 30 seconds is up your engine will be toast. Suggest you pull the top spark plugs from all cylinders and spin the engine by hand until you hear the engine burp. If you cannot get the engine to burp and you still believe the engine has no oil pressure, pull the oil pressure sender and install a mechanical gauge like this: http://www.summitracing.com/parts/sww-82323/overview/ as a test unit. Yeah, it will double the price of your oil change but an extra $40 is cheaper by far than a new engine.
Rick Girard
On Sun, Apr 6, 2014 at 12:28 PM, <pjeffers(at)talktalk.net (pjeffers(at)talktalk.net)> wrote:
[quote] You are probably being a little impatient with your expectations of oil pressure in 6 or 7 seconds.
Are you sure that you did not turn the engine at all, forwards or backwards when your oil tank was empty?
If so you could have got air into the oil system. The oil pump will not pump air!!! If you did then you will need to bleed the oil system from scratch. See the Rotax manual for procedure.
I expect you just did not motor the engine long enough. Remove one plug from each cylinder and motor for 20 secs or until oil pressure rises. If you still don&rsquo;t get px then bleed the oil system.
Pete Jeffers
Sent: Sunday, 6 April 2014 17:44
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
--> RotaxEngines-List message posted by: "Jim Roberts" <jnjrob(at)gmail.com (jnjrob(at)gmail.com)>
Jim
BARRY CHECK 6
PostPosted: Mon Apr 07, 2014 11:46 am    Post subject: oil change question Reply with quote
You bought a RatTax
On Sun, Apr 6, 2014 at 12:28 PM, krazydoc33 <galaxyone(at)juno.com (galaxyone(at)juno.com)> wrote:
[quote]--> RotaxEngines-List message posted by: "krazydoc33" <galaxyone(at)juno.com (galaxyone(at)juno.com)>
http://forums.matronics.com/viewtopic.php?p=421612#421612
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
BARRY CHECK 6
PostPosted: Mon Apr 07, 2014 11:49 am    Post subject: oil change question Reply with quote
Sorry Doc,
But this is the biggest failure on Rotax's part, they did not eliminating a ridiculous problem.  All these engines and all these years and all they could do is offer a complicated solution.  Would deal with a car that had this issue?
Barry
le, List Admin.
henryroden
PostPosted: Mon Apr 07, 2014 5:57 pm    Post subject: Re: oil change question Reply with quote
Hi Jim, The panel is a Dynon skyView, when the master is on so are all the senders. As others have suggested the oil pump needed to be primed. I think what happened is that I left the oil filter off overnight to let it drain down and it also drained the oil pump down too. I purged the system per the Rotax manual and all is now well. I did remove all the top plugs to be able to spin the engine over easier. This engine has always run with a black sooty exhaust pipe. The front two plugs have a black sooty deposit on them but the two rear plugs look fine, a light brown color. Any suggestions?
Thanks.
Henry
jnjrob(at)gmail.com
PostPosted: Tue Apr 08, 2014 4:18 am    Post subject: oil change question Reply with quote
100LL or car gas?
Jim
Roger Lee
PostPosted: Tue Apr 08, 2014 6:23 am    Post subject: Re: oil change question Reply with quote
Hi Henry,
Some of the things you are talking about are normal and there are some tips I can give you. Black dry soot comes from idling and the different intake lengths on the cyl. That goes away during higher rpm running. it isn't a concern. Give me a call. I'll be able to put your mind at rest.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
henryroden
PostPosted: Wed Apr 09, 2014 5:54 am    Post subject: Re: oil change question Reply with quote
Hi Jim,
So far nothing but 91 octane automotive fuel, and all from the same gas station which is right across the road from the air park. Maybe time to try another one?
Roger, I will give you a call or maybe stop by there?
Henry
jnjrob(at)gmail.com
PostPosted: Wed Apr 09, 2014 4:42 pm    Post subject: oil change question Reply with quote
I have read auto fuel will cause the exhaust pipe to be black.
Jim
Roger Lee
PostPosted: Wed Apr 09, 2014 8:42 pm    Post subject: Re: oil change question Reply with quote
If your engine is operating properly neither fuel makes the exhaust black. too much idling and too low an idle rpm might.
Roger Lee
Tucson, Az.
Cell 520-349-7056
