tim2542(at)sbcglobal.net Guest
Posted: Sat Mar 22, 2014 6:11 am Post subject: Std density D sub pins. |
Bob, what is the current rating on the Std density D sub pins? This is re: your avionics ground bus and the 18 gauge com wires going into it. I have the oversize pins that accept 18 awg, but I'm thinking the ~8 amps intermittent load needs to be divided over two pins.
Posted: Sat Mar 22, 2014 8:39 am Post subject: Std density D sub pins. |
At 09:10 AM 3/22/2014, you wrote:
Splitting it onto 2 pins with 6", 22AWG
ballast pigtails is never wrong . . .
but the super-pin might be okay.
What accessory are you talking about?
Posted: Sat Mar 22, 2014 9:32 am Post subject: Std density D sub pins. |
This is for a GTN 650 GPS/NAV/COMM. All the grounds out of that box.
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Sent: Saturday, March 22, 2014 9:38 AM
Subject: Re: Std density D sub pins.
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | --> AeroElectric-List message posted by: Tim Andres <tim2542(at)sbcglobal.net (tim2542(at)sbcglobal.net)>
Bob . . . -Mat===============
Bill Allen
Posted: Sat Mar 22, 2014 9:51 am Post subject: Std density D sub pins. |
Hi Guys,
Good question Tim <<what is the current rating on the Std density D sub pins? >> I'm looking at something similar right now
Bob; I'm not sure I understand correctly what << with 6", 22AWG
ballast pigtails >> means? Can you clarify?
regards,
Bill Allen
On 22 March 2014 17:31, Tim Andres <tim2542(at)sbcglobal.net (tim2542(at)sbcglobal.net)> wrote:
[quote] This is for a GTN 650 GPS/NAV/COMM. All the grounds out of that box.
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Subject: Re: AeroElectric-List: Std density D sub pins.
> Thanks
tp://forums.matronics.com
donjohnston
Posted: Sat Mar 22, 2014 11:17 am Post subject: Re: Std density D sub pins. |
And what is a "super pin"?
donjohnston
Posted: Sat Mar 22, 2014 11:20 am Post subject: Re: Std density D sub pins. |
Posted: Sat Mar 22, 2014 1:33 pm Post subject: Std density D sub pins. |
At 12:31 PM 3/22/2014, you wrote:
| Quote: | This is for a GTN 650 GPS/NAV/COMM. All the grounds out of that box.
Okay, I'm seeing grounds on P1001, 1004 and 1003
that start out as multiple pins and splice down
to single conductors of 18 or 20AWG depending on
system voltage for a total of 7 wires.
Without conversation with the folks who set it
up, the rationale is not known to us. I've seen
this 'pin doubling' on a variety of radios over
the past 20 years.
One thing you could do is run individual 20AWG
wires from ALL 7 pins on the radio to independent
pins in the ground bus. This would cover a host
of rationals from quest for low impedance groung
path (shaky), redundancy (a little less shaky)
or load sharing in the pins (which is my best
guess).
I sold this philosophy onto the GQM163 super
sonic sea skimmer about 10 years ago.
http://tinyurl.com/7h9h76r
I think if it were my airplane, I'd go with
7 separate wires in bundle to the ground bus.
Posted: Sat Mar 22, 2014 1:37 pm Post subject: Std density D sub pins. |
At 02:17 PM 3/22/2014, you wrote:
Somebody, I think Garmin, spec'd a special
pin for d-sub connectors that would accept
larger than 20AWG wire. This is extra long
such that the crimp happens outside the connector
housing.
I'm mystified by this product . . . in no way
does it improve on the current rating of the
individual pin, only the ability to attach
wires rated for a lot more current than the
pin . . . wouldn't use one myself.
