Posted: Fri Feb 21, 2014 6:48 am Post subject: noise problem on radio |
URL Corrections. Seems my capture of image URLs out on
the web were flaky . . . I've posted the images to my
website and re-linked them in this repeat of my
earlier posting . . .
<nuckolls.bob(at)aeroelectric.com>
The noise is intermittent but seems to be strongly correlated to two things
- when the Autopilot (Trio Avionics ProPilot) is switched on I get much more
noise. This noise is present even when the engine is off. It's like the
squelch breaking.
The image (or sound) that pops to mind with the term
"squelch breaking" is the sort of white noise you
get from an receiver when no useful signal is present
but the volume is turned up. The noise is a combination
of atmospheric and internally generated noises. Is
this the kind of noise you're hearing?
For some reason I've noticed that it happens more when I
move the stick back and forth... I have no idea why this may be.
- engine RPM - when I increase the throttle the noise becomes more and seems
to increase in pitch and intensity.
But it's present even when the engine is not running?
I'm suspecting at least one faulty ground connection.
Not sure there is foundation for this supposition yet . . .
It's possible that it
could also be due to the fact that the magneto wires (well, I'm not sure
they are real magnetos, the engine is a Rotax 912UL) are not shielded as I
didn't know any better when I wired them the first time.
The 912 has a form of capacitor discharge ignition system.
See . . .
http://tinyurl.com/ouvxh42
The capacitors are charged via separate coils on
the PM alternator stator stack . . . the larger two
of ten coils visible here.
http://tinyurl.com/ohkdgc6
The Rotax manual calls for shielded wire on the ignition control
lines . . . which is fine . . . but it also calls for the shields
to be grounded at both ends which is not fine . . . at the
engine end only and use the shield as a ground for the
ignition switch. See:
http://tinyurl.com/n3oy37f
However, since you say the noise is present with the
engine not running . . . then the wiring of the ignition
switches is not a likely source of your difficulties.
(Most of the wires that come from the panel go through connectors; in this
way, I can remove the panel from the aircraft by detaching three connectors
and the wire harness to the Autopilot.).
My question is: how do I go about isolating what the fault might be? I'm
dreading having to take apart every single wire in the avionics
interconnections.
Study the chapter on noise and formulate a plan . . . it's
like playing Clue (Mr. Mustard with the Pipe in the Library).
This is an exercise in hypothesis development and elimination
which starts with identifying the antagonist. The antagonist's
nose signature is your first clue . . . so we first need to qualify
the "breaking squelch" term.
uuccio(at)gmail.com Guest
Posted: Sat Feb 22, 2014 1:47 pm Post subject: noise problem on radio |
Thank you Bob,
I went back and inspired by your comment about Mr. Clue, I carefully
observed the phenomenon without jumping to conclusions. It turns out the
interference only happens when the (Trio Avionics Pro Pilot) Autopilot is
ON, even if the engine is OFF. Attached is a link to a video with sound.
There is a lot of background noise (mostly the sound of the GNS430 fan) but
you can still here the interference and see that it completely disappears
when the AP is turned off.
The interference happens in the form of a RX signal on the radio. In other
words, whatever is happening is causing the COM radio to think it's
receiving a transmission, as is evidenced by the RX signal that's visible on
the GNS430 screen.
Anyone have any idea why this might be happening? I guess my next step is
to see if this also happens on, say, a handheld COM.
Sacha
https://dl.dropboxusercontent.com/u/56559644/Autopilot%20COM%20interference%
20email.mp4
Posted: Tue Feb 25, 2014 7:45 am Post subject: noise problem on radio |
At 03:46 PM 2/22/2014, you wrote:
Thank you Bob,
Good work!
| Quote: | Attached is a link to a video with sound
the GNS430 screen.
Okay, it's perceived as a radiated signal that
comes in through the antenna coax. Have you
checked SWR on the comm antenna? If your shield
ground is loose at the radio, it can open a
pathway for conducting otherwise insignificant
signals into the receiver.
Is there an installation/wiring manual for the
AP that can be downloaded from the 'net? Also,
you could 'sniff' around with a handheld. I'd
craft a couple of probes to put onto your hand-held's
antenna jack.
An e-field probe consisting of a dime-sized
disk supported on about an inch off the back
end of the BNC connector. Also an h-field probe
consisting of two turns of wire about 3/4" diam
connected across a BNC connection on 1" of twisted
leads.
Open the squelch on the hand held and move the
attached probes over components and wiring of the
a/p to see if you can identify the strongest
manifestation of the noise.
Posted: Tue Feb 25, 2014 9:23 am Post subject: noise problem on radio |
other words, whatever is happening is causing the COM radio to think
it's receiving a transmission, as is evidenced by the RX signal that's
visible on the GNS430 screen.
No, I haven't. Is it worth getting my hands on an SWR meter?
If your shield ground is loose at the radio, it can open a
You mean that the coax shield could not connected or improperly connected to
the appropriate BNC terminal? I actually have the coax connected to a
backplate connector to which the GNS430 connector slides into, so I guess
there is extra potential there for them not to properly connect (e.g. if the
radio is not properly slotted into the backplate connector).
http://www.trioavionics.com/Pro%20Pilot%20Manual%203.8.pdf
Also,
antenna jack.
I sniffed around yesterday with the handheld and its regular antenna. What
I noticed was that as soon as I switch on the Avionics and the handheld
antenna is close to them, I hear a bunch of noise, but I guess that's
normal. When I switch on the AP and move the handheld antenna close to the
servo cables (that are shielded), I can hear a stronger kind of buzzing
noise. I really have to be almost touching those shielded cables though in
order to pick anything up. I didn't try putting the antenna close to the
radio's COM coax connector though.
leads.
Do you have any pictures of how to build these? Is this
http://www.emcesd.com/tt120100.htm the right idea?
Bob
Thanks again for the suggestions!
Sacha
Posted: Thu Feb 27, 2014 6:16 am Post subject: noise problem on radio |
If you don't have ready access to one, hold off acquiring
it. But check the mechanical integrity of your coax
connections at the back of the radio. How well does the
comm transceiver work? Have you detected any shortfall
in performance?
Okay . . . that's a busy little box. Refresh my
memory, is this noise a new thing or has it always
been present. Also, when receiving a weak signal
(tune in an ATIS and fly away from airport until
signal starts to get noisy . . . then turn a/p
on/off and judge how much effect the a/p noise
has on reception of weak signals).
You wont see any noise coming OUT of this junction,
but it is a potential point of ingress for noises
that tend to pile up behind the panel.
Yes! good find. I got a little ahead of myself
in sifting the simple ideas. Don't run off and build
one (or e-field probe) yet.
It's not clear to me yet as to operational significance
of the noise. DO-160 ALLOWS certain levels of noise
while putting potential victims ON NOTICE that such
noises may be present but normally insignificant.
My sense of the situation from your narrative
so far is that while the A/P is a noteworthy
contributor . . . it's not the sole potential
antagonist . . . we may discover that it is
within practical limits and you just need to
tighten the squelch on the receiver a tad.
I think I've related my experiences with the
symphony of noises that are often heard in
various systems while sitting on the ground
with engines off and wearing headphones . . .
noises that are completely insignificant
while in flight.
Let's size the task before we get out hammers-
n-saws.
Posted: Sun Mar 02, 2014 2:11 pm Post subject: noise problem on radio |
I don't have enough experience with it yet. In Italy, ultralights can only
speak to other such a/c on 130 MHz. You need to acquire an "advanced"
ultralight license (which costs approx.. $2000) to be able to talk to
anybody else. It's all part of the ridiculous regulation we endure here.
Have you detected any shortfall in performance?
(In my limited experience), not so far.
been present.
I only noticed it in the last 10 hours or so, but the a/c only has 30 hours
or so since I rebuilt it, and I wasn't particularly concentrating on the use
of the radio initially since a) there's hardly any other traffic around and
b) I'm limited to the ultralight air-to-air frequency in any case.
Also, when receiving a weak signal (tune in an ATIS and fly away from
airport until
I will try that next time.
[...] My sense of the situation from your narrative
I'll try that next time too.
while in flight.
n-saws.
What you say makes sense. I'm going to be away from the hangar for a few
weeks (I'm actually going to New Mexico for a job interview and then to
Socal to see some friends), so I'll pick the thread up again when I get
back.
Sacha
