Climb question.... URGENT. HOPING FOR ANSWER BY 1200 Zulu!
SIDESLIP
PostPosted: Wed Oct 02, 2013 5:59 pm    Post subject: Climb question.... URGENT. HOPING FOR ANSWER BY 1200 Zulu! Reply with quote
Hello all. Quick question....
I changed the pitch of my prop for a cruise setting, so I lost about 200-300' min doing so at 1100lbs. At 1100lbs, (1300 is gross) I saw 1200-1300'/min at 1100lbs. With the pitch change i see between 600-1100'/min depending on the day. What impact would adding 200lbs to bring it to gross do you think? My concern is whether it will climb or not. It's a ROTAX 912ULS.
IM flying gross tomorrow am from a 4000' runway. I'd LOVE some feedback on this. Hope I'm not getting myself in over my head at gross. Guess the only way to find out is try.
ALL COMMENTS APPRECIATED!!!!!
Thanks!
Chad Scriver
ZODIAC 601XL-B
Rotax 912ULS
WARPDDRIVE 3 blade
C-GYXQ. 912ULS. 601XL-B
SIDESLIP
PostPosted: Thu Oct 03, 2013 3:34 pm    Post subject: Re: Climb question.... URGENT. HOPING FOR ANSWER BY 1200 Zul Reply with quote
Update*******
Flew the plane 10lbs under gross. DA was 675'. 17 degrees Celsius.
Climbed at 700-850'/min. Even did some climbs from 3000' and saw almost 1000'/min up there at 18 degrees. So, all in all, seemed to climb fine at gross. I'm happy with it.
Chad
