Window sizeWindow size
david steade
PostPosted: Tue Oct 01, 2013 9:38 am    Post subject: Window sizeWindow size Reply with quote
Hi All
Thanks for all the info on the windows. I am trying as far as possible to reproduce the windows to the original Mk4 size so if anyone does have the dimensions handy then that would be useful.
David
David Steade
lcfitt(at)sbcglobal.net
PostPosted: Tue Oct 01, 2013 12:58 pm    Post subject: Window sizeWindow size Reply with quote
David,
David,
Sorry to take your question in other directions. I wonder if you will be able to find what you are looking for. When I was building my 93 kit, the side windows had an option that consisted of a triangular piece of fabric with the window sewn in. It was then glued to the area between the tubing. I had seen it and didn't like the looks. I glued my window to the fabric using a piece of lexan that came with the kit. I think what you would need is someone to come forward with the original sewn in window and measure that. Otherwise, I don't think there was a standard size as my feeling is that most builders pretty much just eyeballed it as to size.
Then after writing the preceding, I thought to look at the original construction manual pages. I will send them to you direct - to avid copyright issues - as a PDF file. There is one photograph that you could use to create ratios for a rough dimension.
Lowell
Sent: Tuesday, October 01, 2013 10:37 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: Re: Window sizeWindow size
Hi All
David
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
PostPosted: Tue Oct 01, 2013 1:04 pm    Post subject: Window sizeWindow size Reply with quote
David,
Attached are the two pages of instructions for the side window installation.
Lowell
Hi All
David
Scan0035.pdf
 Filename:  Scan0035.pdf
 Filesize:  728.28 KB
 Downloaded:  565 Time(s)
