alderman.kevin0610(at)gma Guest
Posted: Thu May 02, 2013 2:05 am Post subject: KIS-List Digest: 4 Msgs - 05/01/13 |
Tracy Crook flies his 3 rotor RV6 behind a 3 blade Catto prop and recommended it to me for mine.
Kevin Alderman
On Thu, May 2, 2013 at 3:00 AM, KIS-List Digest Server <kis-list(at)matronics.com (kis-list(at)matronics.com)> wrote:
[quote]*
Today's complete KIS-List Digest can also be found in either of the
of the KIS-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2013-05-01&Archive=KIS
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2013-05-01&Archive=KIS
KIS-List Digest Archive
Total Messages Posted Wed 05/01/13: 4
Today's Message Index:
1. 03:32 AM - Re: KIS-List Digest: 5 Msgs - 04/30/13 (Kevin Alderman)
2. 04:11 AM - Re: Catto Propeller (Scott Stearns)
3. 11:01 PM - Official KIS-List FAQ (Frequently Asked Questions) (Matt Dralle)
4. 11:06 PM - Official KIS-List Usage Guidelines (Matt Dralle)
Time: 03:32:40 AM PST US
Subject: Re: KIS-List Digest: 5 Msgs - 04/30/13
From: Kevin Alderman <alderman.kevin0610(at)gmail.com (alderman.kevin0610(at)gmail.com)>
The gearbox is made by Tracy Crook at rotary aviation. There are many of
these flying around the world- really. The longest running one that I have
personally seen is Tracys RV4 with 2200 hours, and his RV6 3 rotor with
over 1000. There are also 2 lancairs in Texas, an RV4 with a turbo mazda
that raced last year at Reno etc.
The gearbox is really simple- a central drive shaft made from a truck axle
turned by a planetary set from a Ford E4OD truck transmission. If you count
the 6 planets in the gear set, we are up to 10 moving parts including the
turbo for the whole thing. A Lycoming IO360 has 1548 .
The pros include a new engine for less than 4K, few moving parts, no valves
and high power
The cons include you have to build it yourself or find someone that has
done it.
My old IO520D needed 2 cylinders. These cylinders cost more than a new
rotary. I developed a bad skip in flight with the 520D, and when I landed I
did a compression check and changed the oil. 0 compression on number 1, 30
lbs on 2. I owned a construction company for 22 years and as such know the
value of equipment, so as we normally would I set out to rebuild the 520.
This is where the issue came in- 2 ADs. The first said that I had the light
crankcase and if I took it apart I had to send it off. Continental told me
that less than 40% would come out as OK. AD number 2 said that I had a non
VAR crank, and couldnt re-use it. If I opened the crankcase, the crank had
to go.
So, to rebuild the engine I needed a new crank at over 8K, all new
cylinders, possibly a new crankcase, etc. OR- (now is the time to sit down)
if the engine had acceptable oil pressure I could stick 2 cylinders on it
and fly and be FAA legal. In spite of a handful of metal in the oil removed
from the engine, I had oil pressure in the green when it was tested. Who
knows how much bearing damage was done by the metal. But I couldn't open it
up and even check the bearings.
Unacceptable. And with the 2 ADs, Continental gave me a whole $3,000 credit
toward a new $54,000 engine. Again unacceptable.
There are many of these engines in airplanes- half of the Air Forces UAVs
are powered by jet fuel burning rotary engines- as well as lots of boats,
equipment, Lancairs, Cozys, RVs, etc. I have an engine in my plane, and a
spare pickled in the garage. So while the "airplane" engine guys spend
$2,000 on a cylinder, If I have a problem I just swap the whole engine and
fly with a brand new one.
I am also finished with the system but it works out like this- Mazda 13B
rotary, Rotary aviation gearbox at 2.85:1. EFI with mechanical backup.
The throttle will be computer controlled similar to cruise control in your
car. There will be 4 normal positions- takeoff- cruise- flight idle- ground
idle.
For takeoff push it to the T/O position, and the computer will control
boost, power, temps, etc. and keep it at 7500 RPM. After climb pull it to
flight cruise and the computer will keep it at 6000 RPM whether you are in
a climb or descent. When you want to go down, flight idle will reduce the
RPM to 4500, which will also be the taxi setting. Then ground idle for
waiting to go.
There will always be manual control, but shouldn't be needed with redundant
EFI computers and 8 hours of battery backup.
I could go on for days, but you should have a good picture of what is in my
head by now.
Kevin Alderman
Maybe I should add Obsessive Compulsive to what goes under my name!
On Wed, May 1, 2013 at 3:00 AM, KIS-List Digest Server <
> HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-04-30&Archive=KIS
> Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-04-30&Archive=KIS
> Total Messages Posted Tue 04/30/13: 5
> 1. 03:27 AM - Re: KIS-List Digest: 2 Msgs - 04/29/13 (Kevin Alderman)
> 2. 06:08 AM - Catto Propeller (Galin Hernandez)
> 3. 06:10 AM - Re: Re: KIS-List Digest: 2 Msgs - 04/29/13 (Graham
> Brighton)
> 4. 06:46 AM - Re: Catto Propeller (William Schertz)
> 5. 05:11 PM - Re: Catto Propeller (Galin Hernandez)
> Time: 03:27:12 AM PST US
> Subject: Re: KIS-List Digest: 2 Msgs - 04/29/13
> A turbine is a good engine, but not for our general use. The biggest factor
> is fuel burn There is a small helicopter that uses a 100 hp SOLAS turbine
> for power. It is small, light and responsive. It burns 9 GPH at idle on the
> ground, and making 100 HP it burns closer to 14 GPH. Turbines are great for
> high altitude high speed flight, for flight in our normal flight regime it
> will work but the fuel costs are multitudes higher.
> Also, turbines such as the SOLAS operate at high speeds around 50,000 RPM,
> and as such need a gearbox to reduce the engine speed to prop speed. The
> Helicopter supplier makes their own, you would have to find one somewhere.
> Turbines have a very very narrow power and engine speed range. The power is
> varied by a CS prop. Your gearbox will have to be able to support a CS prop
> and include a governor. The engine itself will (or should) have a
> controller that controls/ limits engine RPM, but you will still need a
> method of controlling the prop pitch.
> In a turboprop like a Pilatus, it goes like this: The engine is started at
> ground idle, which is a turbine speed of around 80% of flight speed, i.e.
> 40K RPM. After warm up and taxi, the engine is brought up to flight cruise
> power and the prop is cycled somewhat similar to our run-up with a piston
> recip. For takeoff, the throttle is pushed to takeoff and the prop full
> forward for maximum THRUST. At altitude, the throttle is pulled back to
> flight cruise, the prop placed in cruise and off we go.
> Turbine engines are only cost efficient at high altitudes and high speeds.
> Most jet operators will tell you that if they had to fly below 30K feet all
> the time they couldn't afford the fuel.
> Another added benefit of a turbine is pressurization- they take compressed
> high pressure air from the cold- compressor- section and send it into the
> cabin. The air is hot from compression, and doubles as cabin heat. If you
> aren't going to fly at the flight levels, this is another waste of power.
> I am building a Wheeler Express- after flights to Central America, the
> Bahamas, and other places that do not have Avgas, I thought about a 300HP
> turbine. My plane with a 300 HP gas engine will burn around 12 gph at 180
> kts at 14,500 ft. My 100 gal fuel capacity will give me more than a 1000
> mile range. The 300 HP turbine fuel burn is closer to 28 GPH in flight even
> at FL 180. Cuts my range in half, even though I gain 30 kts in speed.
> Kevin Alderman
> Avionics Tech/ Aircraft restoration
> Building a Wheeler Express with a Mazda Rotary 13B turbo- 300 HP- 3 moving
> parts.
> On Tue, Apr 30, 2013 at 3:00 AM, KIS-List Digest Server <
> > HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter13-04-29&Archive=KIS
> > Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter13-04-29&Archive=KIS
> > Total Messages Posted Mon 04/29/13: 2
> > 1. 04:59 AM - Re: Turbine (ALFRED ROSA)
> > 2. 06:45 AM - Re: Turbine (Galin Hernandez)
> > Time: 04:59:55 AM PST US
> > Subject: Re: Turbine
> > From: ALFRED ROSA <fredorosa(at)gmail.com (fredorosa(at)gmail.com)>
> > Just wondering what advantage you are hoping to achieve with a turbine?
> > Also, If you need a Cruiser without engine and avionics, I have one in
> my
> > garage.
> > Al
> > On Mon, Apr 29, 2013 at 12:55 AM, John Petrie <
> jpetrie(at)sonicfactory.co.za (jpetrie(at)sonicfactory.co.za)
> > >wrote:
> > > Hi all,
> > > It's been a while since I last posted on this group, largely due to the
> > > fact that I sold my KIS Cruiser.
> > > I am now looking for a new project and am considering buying my Cruiser
> > > back and fitting a turbine engine. I know absolutely nothing about
> > > turbines, and hence the reason for this post. If anyone can point me
> in
> > > the right direction or provide some other useful information, I'm all
> > ears.
> > > Thanks a mil.
> > > John Petrie
> > > Sonic Factory
> > > 082 574 6190
> > > Sent from my mobile
> > ________________________________ Message 2
> > Time: 06:45:52 AM PST US
> > From: Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)>
> > Now THAT sounds like a cool project. I think 100LL will eventually go
> away
> > and a Jet-A type alternative is a good idea. Besides, it sounds like fun
> to
> > do.
> > On Sun, Apr 28, 2013 at 11:55 PM, John Petrie <
> > >wrote:
> > > Hi all,
> in
> > ears.
> > > Thanks a mil.
> > > John Petrie
> > > Sonic Factory
> > > 082 574 6190
> > > Sent from my mobile
> Time: 06:08:01 AM PST US
> Subject: Catto Propeller
> Is anyone flying with a Catto propeller? I know Bob Reed has one but is not
> flying yet.
> ________________________________ Message 3
> Time: 06:10:21 AM PST US
> From: "Graham Brighton" <gbrighton(at)skymesh.com.au (gbrighton(at)skymesh.com.au)>
> Subject: Re: Re: KIS-List Digest: 2 Msgs - 04/29/13
> Great Reply Kevin ,
> But few more moving parts than 3 hey
> ..!! ... with the Turbo ... and gearbox too .. and what gearbox are u
> intending use/try .... ? not much available with proven hours and or
> tested TV analysis ..!!??
> Graham
> Sent: Tuesday, April 30, 2013 8:26 PM
> factor is fuel burn There is a small helicopter that uses a 100 hp SOLAS
> turbine for power. It is small, light and responsive. It burns 9 GPH at
> idle on the ground, and making 100 HP it burns closer to 14 GPH.
> Turbines are great for high altitude high speed flight, for flight in
> our normal flight regime it will work but the fuel costs are multitudes
> higher.
> RPM, and as such need a gearbox to reduce the engine speed to prop
> speed. The Helicopter supplier makes their own, you would have to find
> one somewhere.
> is varied by a CS prop. Your gearbox will have to be able to support a
> CS prop and include a governor. The engine itself will (or should) have
> a controller that controls/ limits engine RPM, but you will still need a
> at ground idle, which is a turbine speed of around 80% of flight speed,
> i.e. 40K RPM. After warm up and taxi, the engine is brought up to flight
> cruise power and the prop is cycled somewhat similar to our run-up with
> a piston recip. For takeoff, the throttle is pushed to takeoff and the
> prop full forward for maximum THRUST. At altitude, the throttle is
> pulled back to flight cruise, the prop placed in cruise and off we go.
> speeds. Most jet operators will tell you that if they had to fly below
> 30K feet all the time they couldn't afford the fuel.
> compressed high pressure air from the cold- compressor- section and send
> it into the cabin. The air is hot from compression, and doubles as cabin
> heat. If you aren't going to fly at the flight levels, this is another
> waste of power.
> 300HP turbine. My plane with a 300 HP gas engine will burn around 12 gph
> at 180 kts at 14,500 ft. My 100 gal fuel capacity will give me more than
> a 1000 mile range. The 300 HP turbine fuel burn is closer to 28 GPH in
> flight even at FL 180. Cuts my range in half, even though I gain 30 kts
> in speed.
> Kevin Alderman
> moving parts.
> formatted
> Indexes
> version
> HTML Version:
> Chapter 13-04-29&Archive=KIS
> Text Version:
> turbine?
> in my
> garage.
> Al
> <jpetrie(at)sonicfactory.co.za (jpetrie(at)sonicfactory.co.za)>wrote:
> > Hi all,
> the
> Cruiser
> me in
> all ears.
> > Thanks a mil.
> > John Petrie
> > Sonic Factory
> > 082 574 6190
> > Sent from my mobile
> away
> fun to
> do.
> > Hi all,
> the
> Cruiser
> me in
> all ears.
> > Thanks a mil.
> > John Petrie
> > Sonic Factory
> > 082 574 6190
> > Sent from my mobile
> rget="_blank">http://www.matronics.com/Navigator?KIS-List
> http://forums.matronics.com
> le, List Admin.
> ="_blank">http://www.matronics.com/contribution
> ________________________________ Message 4
> Time: 06:46:24 AM PST US
> From: "William Schertz" <wschertz(at)comcast.net (wschertz(at)comcast.net)>
> Subject: Re: Catto Propeller
> I am flying with a 76x76 Catto 2 blade prop on my Rotary powered KIS
> Bill Schertz
> Sent: Tuesday, April 30, 2013 8:07 AM
> not flying yet.
> ________________________________ Message 5
> Time: 05:11:36 PM PST US
> Bill, How do you like the propeller?
> On Tue, Apr 30, 2013 at 8:46 AM, William Schertz <wschertz(at)comcast.net (wschertz(at)comcast.net)
> > Bill Schertz
> > *From:* Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)>
> > *Sent:* Tuesday, April 30, 2013 8:07 AM
> > *To:* kis-list(at)matronics.com (kis-list(at)matronics.com)
> > *Subject:* Catto Propeller
> > not flying yet.
> > href="http://www.matronics.com/Navigator?KIS-List">
> > href="http://forums.matronics.com">http://forums.matronics.com
> > href="http://www.matronics.com/contribution">[url=http://www.matronics.com/c*]http://www.matronics.com/c*[/url]
Time: 04:11:00 AM PST US
From: Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)>
I have a 68x80 prince that I might be selling soon. I think I am going to g
et a whirlwind ground adjustable prop.
Scott
On Apr 30, 2013, at 2:07 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
t flying yet.
Time: 11:01:23 PM PST US
From: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
Subject: Official KIS-List FAQ (Frequently Asked Questions)
Dear Listers,
Please read over the KIS-List Frequently Asked Questions (FAQ) below. The
complete KIS-List FAQ including the Usage Guidelines can be found at the
following URL:
http://www.matronics.com/FAQs/KIS-List.FAQ.html
Thank you,
[ Note: This FAQ was designed to be displayed with a fixed width font such as
Courier. Proportional fonts will cause display formatting errors. ]
This FAQ can also be viewed in HTML online at the following address:
http://www.matronics.com/FAQ/KIS-List.htm
******* LIST POLICIES AND FREQUENTLY ASKED QUESTIONS *******
PLEASE READ. This document contains KIS-List policies and information
for new and old subscribers. Understanding the KIS-List policies will
minimize problems for the Administrator, and will help keep the KIS-List
running smoothly for all of us.
*** Quick Start Guide to List Features ***
There are many features available on the Matronics Email Lists and each
one is described in detailed below. However, using the List Navigator
you can quickly access the complete set of features available for this
List. The List Navigator can be found at the following URL:
*** How to Subscribe and Unsubscribe ***
Simply go to the Web Page shown below and enter your email address and
select the List(s) that you wish to subscribe or unsubscribed from. You
may also use the handy "Find" function to determine the exact syntax of
your email address as it is subscribed to the List. Please see the
complete instructions at the top of the Web Page for more information.
The Subscribe/Unsubscribe web page is:
http://www.matronics.com/subscribe
Note that you will receive TWO conformation emails regarding your subsciption
process. The first verifies that your subscription/unsubsciption request
was received, and the second confirms that the process has been completed.
You should receive the first email within a few minutes of your request.
The second conformation will arrive in less than 24 hours. You cannot post
until you receive the second conformation email message.
*** How to Post a Message ***
Send an email message to:
Your message will be redistributed to everyone currently subscribed
to the List.
*** SPAM Fighter - You Must be Subscribed to Post ***
When a new post is received by the system, the From: line of the message
is checked and compared against the current subscription list. If the
email address is found, the message is passed on to the List Processor.
If the email address isn't found in the current list of subscribers, it
is dumped. This serves to very effectively thwart 99% of the SPAM that
gets posted to the Lists.
Remember, however, that the syntax of your email address is very important
with regard to the configuration of your email application such as Outlook
or Eudora. For example, the following two email addresses may be
functionally equivalent, but only one would pass the Matronics Email SPAM
test depending on which was syntax was subscribed to the given List:
smith(at)machine.domain.com (smith(at)machine.domain.com)
smith(at)domain.com (smith(at)domain.com)
Either email address syntax is alright, just be sure that you configure
your email application to match *exactly* the address you've subscibed to
the List.
*** Enclosure Support on the Lists ***
Limited posting of enclosures such as pictures, documents, and spreadsheets
is supported on the Lists. There are a number of restrictions, and these
are detailed below. Please abide by the rules put forth regarding the
content of enclosures.
These are some of the features and limits of enclosures on the Matronics
Lists:
1) Enclosures will only be posted to the Real Time version of the Lists.
2) Enclosures will NOT be included in the Daily Digest version of the Lists.
3) Enclosures WILL BE forwarded on to the BBS Forum Web site.
4) Enclosures will NOT be appended to the Archives.
5) Enclosures will NOT be available in the List Browse feature.
6) Only the following file types and extensions will be allowed:
bmp doc dwg dxf gif jpg pdf png txt xls
All other enclosures types will be rejected and email returned to
sender. The enclosure types listed above are relatively safe from
a virus standpoint and don't pose a particularly large security risk.
7) !! All incoming enclosures will be scanned for viruses prior to posting
to the List. This is done in real time and will not slow down
the process of posting the message !!
Here are some rules for posting enclosures. Failure to abide by these rules
could result in the removal of a subscriber's email address from the Lists.
1) Pay attention to what you are posting!! Make sure that the files
you are enclosing aren't HUGE (greater that 1MB). Remember that there
are still people checking they're email via dial up modem. If you post
30MB worth of pictures, you are placing an unnecessary burden on these
folks and the rest of us, for that matter.
2) SCALE YOUR PICTURES DOWN!!! I don't want to see huge 3000 x 2000
pictures getting posted that are 3 or 4MB each. This is just
unacceptable. Use a program such as Photoshop to scale the picture
down to something on the order of 800 x 600 and try to keep the
file size to less-than 200KB, preferably much less.
Microsoft has a really awesome utility available for free that allows
you to Right-Click on a picture in Explorer and automatically
scale it down and resave it. This is a great utility - get it, use it!
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
Look for the link "Image Resizer"
3) !! This would seem to go without saying, but I'll say it anyway. Do not
post anything that would be considered offensive by your grandmother.
And you know what I'm saying; I don't want to see anything even
questionable. !!
4) REMEMBER THIS: If you post a 1MB enclosure to a List with 1000 members
subscribed, your 1MB enclosure must be resent 1000 times amounting
to 1MB X 1000 = 1 Gigabyte of network traffic!! BE CAREFUL and
BE COURTEOUS!
Also see the section below on the Matronics Photo and File Share where
you can have your files and photos posted on the Matronics web server
for long time viewing and availability.
*** Digest Mode ***
Each day, starting at 12 midnight PST US, a new 'digest' will be started.
This digest will contain the same information that is currently appended
to the archive file. It has all of the headers except for the "From:"
and "Subject:" lines removed, and includes a message separator consisting
of a line of underscores.
Each day at 23:55 PST US, the day's messages as described above will be
combined and sent as a single message to everyone on the digest email list.
To subscribe to the digest list, use the same subscription web form
described above, and just select the Digest version of the List.
Note that you *can* be subscribed to both the realtime and digest versions
of the List at the same time. This is perfectly acceptable.
Now some caveats:
* Messages sent to "kis-list-digest" will be forwarded to the standard
email list. In other words, you cannot post messages only to the
digest List.
* If you are subscribed to both the regular List and the digest List, you
will receive the realtime postings as well as the digest at the end of
the day.
* If you reply to the digest email, your message will be forwarded to the
normal list associated with the digest. Important Note: Please change
the subject line to reflect the topic of your response! Also, please
*do not include all or most of the digest in your reply*.
*** List Digest Browser ***
An archive of all the List Digests can be found online in either plain text
or HTML format. These archives contain the exact Digest that was posted to
the Digest email list on the given day. The Digest Archives can be found
at the following location:
*** The "DO NOT ARCHIVE" Message Flag ***
At times, your message may concern something that is revelent only to a very
small number of persons or to a limited area, and you may not wish to archive
it. In such a case, simply put the following phrase anywhere in the
message:
Your message will not be appended to the archive, but will be sent to List
email distribution as normal.
***** READ THIS - Automatic Unsubscribes *****
Note that if your email address begins to cause problems such as bounced
email, mailbox is filled, or any other errors, your address will be promptly
removed from the List. If you discover that you are no longer receiving
messages from the KIS-List, go to the following Web page, and look
for your email address and a possible reason for your removal.
The Matronics Email List uses utility called the "Email Weasel" that
automatically looks though the day's bounced email for addresses that
caused problems due to common things like "user is unknown", "mailbox
full", etc. If the Email Weasel removes your email address from the
Lists you will find record of it at the following URL:
http://www.matronics.com/unsubscribed
If the problem listed on the web site above has been resolved, please feel
free to resubscribe to the Lists of your choice.
*** List Member Information ***
If you have not done so already, please email me your phone numbers and
paper mail address in the following format:
smith(at)somehost.com (smith(at)somehost.com)
Joe Smith
123 Airport Lane
Tower, CA 91234-1234
098-765-1234 w
123-456-7890 h
Please forward this information to the following email address:
requests(at)matronics.com (requests(at)matronics.com)
I have a file of such things, that I typically use to contact you when
there are problems with your email address. The information will NOT
be used for any other commercial purpose.
*** Realtime Web Email List Browsing ***
Recent messages posted to the KIS-List are also made available on
the Web for realtime browsing. Seven days worth of back postings are
available with this feature. The messages can be sorted by Subject,
Author, Date, or Message Thread. The Realtime List Browser indexes are
updated twice per hour at xx:15 and xx:45. You can also reply to a message
or start a new message directly from the List Browser Interface (coming soon).
You do not have to be subscribed to the given list to use the List
Browser Interface in view-mode.
http://www.matronics.com/browselist/kis-list
*** Web Forums Bulletin Board Interface ***
A phpBB BBS web Forums front end is available for all KIS-List content.
content. The Forums contain all of the same content available via the email
distribution and found on the various archive viewing formats such as the
List Browse, etc. Any posts on the web Forums will be cross posted to the
respective email List, and posts to the Email List will be cross posted to
the web Forums.
You may view all List content on the Forums without any special login.
If you wish to post a message via the Web Forum interface, however, you
will need to Register. This is a simple process that takes only a few
minutes. A link to the Registration page can be found at the top of the
main web Forums page. Note that registering on the Forum web site also
enables you to send email posts to the Lists as well. You will also need to
Subscribe to the respective Email List as described above to receive the
Email Distribution of the List, however.
The Matroincs Email List Web BBS Forums can be found at the following URL:
*** Matronics Email List Wiki ***
In an attempt to make it easy to store and find structured and often accessed
information, Matronics has installed a Wiki at:
http://wiki.matronics.com
The Wiki allows individuals to create web pages to contain useful information
for other users of the mailing lists and web site. Unlike an ordinary web page
where the content needs to be submitted to Matronics for inclusion, the Wiki
permits the users to construct their own pages and have them visible immediately.
While constructing pages for the Wiki is not difficult, some may not be
comfortable building pages. In that case, simply prepare the text and any
images and email it to:
wiki-support(at)matronics.com (wiki-support(at)matronics.com)
One of the volunteers on that list will take your submission and construct
a Wiki page for you.
Often someone produces a particularly useful posting in email one one of the
Lists that would be of general interest. In that case Matronics may take that
post and convert it into a Wiki page.
*** List Archives ***
A file containing of all of the previous postings to the KIS-List is
available on line. The archive file information is available via the
Web and FTP in a number of forms. Each are briefly described below:
* KIS-List.FAQ
- Latest version of the KIS-List Frequently Asked Question
page (this document).
* KIS-Archive.digest.complete
- Complete file with most of the email header info removed and
page breaks inserted between messages.
* KIS-Archive.digest.vol-??
- Same as the file above, but broken up into small sections that
can more easily handled.
* KIS-Archive.digest.complete.zip
- Same as the KIS-Archive.digest.complete file above, but
in PKZIP format. Use "binary" data transfer methods.
* KIS-Archive.digest.complete.Z
- Same as the KIS-Archive.digest.complete file above, but in
UNIX compress format. Use "binary" data transfer methods.
Download Via FTP
The archive file is available via anonymous FTP from ftp.matronics.com
in the "/pub/Archives" directory. It is updated daily and can be found in
a number of formats as described above. (All filenames are case sensitive.)
ftp://ftp.matronics.com/pub/Archives
Download Via Web
The archives are also available via a web listing. These can be found
toward the bottom of the following web page:
http://www.matronics.com/archives
*** Complete List Web Archive Browsing ***
All messages posted to the KIS-List are also available using the
Email List Archive Browsing feature. With this utility, all messages
in the List are indexed, and individual sub-archives can be browsed.
http://www.matronics.com/archive/archive-index.cgi?KIS
**** High-Speed Archive Search Engine ***
You can use the custom, high-performance Matronics Email List Search Engine
to quickly locate and browse any messages that have been posted to the
List. The Engine allows the user to easily search any of the currently
available List archives.
http://www.matronics.com/search
*** File and Photo Share ***
With the Matronics Email List File and Photo Share you can share pictures
and other data with members of the List without having to forward a
copy of it to everyone. To share your Files and Photos, simply email
them to:
pictures(at)matronics.com (pictures(at)matronics.com)
!! ==> Please including the following information with each submission:
1) Email Lists that they are related to.
2) Your Full Name.
3) Your Email Address.
4) One line Subject description.
5) Multi-line, multi-paragraph description of topic.
6-x) One-line Description of each photo or file
Prior to public availability of the files and photos, each will be scanned
for viruses. Please also note that the process of making the files and
photos available on the web site is a pseudo-manual process, and I try to
process them every few days.
Following the availability of the new Photoshare, an email message will be
sent to the Email Lists enumerated in 1) above indicating that the new
Share is available and what the direct URL to it is.
For a current list of available Photoshares, have a look at the Main
Index Page:
*** List Archive CDROM ***
A complete Matronics Email List Archive CD is available that contains
all of the archives since the beginning of each of the Lists. The archives
for all of the Lists are included on the CD along with a freeware search
engine written by a list member. The CD is burned the day you order it
and will contain archive received up to the last minute. They make
great gifts!
http://www.matronics.com/ArchiveCDROM
*** List Support Contributions ***
The Matronics Lists are run *completely* through the support of it members.
You won't find any PopUpAds, flashing Banner ads, or any other form of
annoying commercialism on either the Email Messages or the List web pages
associated with the Matronics Email Lists. Every year during November
I run a low-key, low-pressure "Fund Raiser" where, throughout the month,
I ask List members to make a Contribution in any amount with which they
are comfortable.
I will often offer free gifts with certain contribution levels during the
Fund Raiser to increase the participation. The gifts are usually donated
by companies that are themselves List members.
Your Contributions go directly to supporting the operation of the Lists
including the high-speed, business-class Internet connection, server
system hardware and software upgrades, and to partially offset the many
many hours I spend running, maintaining, upgrading, and developing the
variety of services found here.
Generally Contributions range from $20 to $100 and are completely voluntary
and non-compulsory. I ask only that if person enjoys the Lists and obtains
value from them, that they make a Contribution of equal magnitude.
Contributions are accepted throughout the year, and if you've just
subscribed, feel free to make a Contribution when you've settled in.
The website for making SSL Secure Contributions is listed below. There are
a variety of payment methods including Visa and MasterCard, PayPal, and
sending a personal check.
If you enjoy and value the List, won't you make a Contribution today to
support its continued operation?
http://www.matronics.com/contributions
Thank you!
Email List Administrator
The following details the official Usage Guidelines for the KIS-List.
You are encouraged to read it carefully, and to abide by the rules therein.
Failure to use the KIS-List in the manner described below may result
in the removal of the subscribers from the List.
KIS-List Policy Statement
The purpose of the KIS-List is to provide a forum of discussion for
things related to this particular discussion group. The List's goals
are to serve as an information resource to its members; to deliver
high-quality content; to provide moral support; to foster camaraderie
among its members; and to support safe operation. Reaching these goals
requires the participation and cooperation of each and every member of
the List. To this end, the following guidelines have been established:
- Please keep all posts related to the List at some level. Do not submit
posts concerning computer viruses, urban legends, random humor, long
lost buddies' phone numbers, etc. etc.
- THINK carefully before you write. Ask yourself if your post will be
relevant to everyone. If you have to wonder about that, DON'T send it.
- Remember that your post will be included for posterity in an archive
that is growing in size at an extraordinary rate. Try to be concise and
terse in your posts. Avoid overly wordy and lengthy posts and
responses.
- Keep your signature brief. Please include your name, email address,
aircraft type/tail number, and geographic location. A short line
about where you are in the building process is also nice. Avoid
bulky signatures with character graphics; they consume unnecessary
space in the archive.
- DON'T post requests to the List for information when that info is
easily obtainable from other widely available sources. Consult the
web page or FAQ first.
- If you want to respond to a post, DO keep the "Subject:" line of
your response the same as that of the original post. This makes it
easy to find threads in the archive.
- When responding, NEVER quote the *entire* original post in your
response. DO use lines from the original post to help "tune in" the
reader to the topic at hand, but be selective. The impact that
quoting the entire original post has on the size of the archive
can not be overstated!
- When the poster asks you to respond to him/her personally, DO NOT
then go ahead and reply to the List. Be aware that clicking the
"reply" button on your mail package does not necessarily send your
response to the original poster. You might have to actively address
your response with the original poster's email address.
- DO NOT use the List to respond to a post unless you have something
to add that is relevant and has a broad appeal. "Way to go!", "I
agree", and "Congratulations" are all responses that are better sent
to the original poster directly, rather than to the List at large.
- When responding to others' posts, avoid the feeling that you need to
comment on every last point in their posts, unless you can truly
contribute something valuable.
- Feel free to disagree with other viewpoints, BUT keep your tone
polite and respectful. Don't make snide comments, personally attack
other listers, or take the moral high ground on an obviously
controversial issue. This will only cause a pointless debate that
will hurt feelings, waste bandwidth and resolve nothing.
- Occasional posts by vendors or individuals who are regularly
subscribed to a given List are considered acceptable. Posts by
List members promoting their respective products or items for sale
should be of a friendly, informal nature, and should not resemble
a typical SPAM message. The List isn't about commercialism, but
is about sharing information and knowledge. This applies to
everyone, including those who provide products to the entire
community. Informal presentation and moderation should be the
operatives with respect to advertising on the Lists.
[This is an automated posting.]
________________________________ Message 4 _____________________________________
Time: 11:06:03 PM PST US
Subject: Official KIS-List Usage Guidelines
Dear Listers,
Please read over the KIS-List Usage Guidelines below. The complete
KIS-List FAQ including these Usage Guidelines can be found at the
following URL:
Thank you,
responses.
le, List Admin.
sstearns2(at)yahoo.com Guest
Posted: Thu May 02, 2013 12:49 pm Post subject: KIS-List Digest: 4 Msgs - 05/01/13 |
Check out the whirlwind ground adjustable before you buy. I am not sure how much the catto is but the whirlwind is about the same price as a prince carbon.
Scott
On May 2, 2013, at 11:05 AM, Kevin Alderman <alderman.kevin0610(at)gmail.com> wrote:
[quote] Tracy Crook flies his 3 rotor RV6 behind a 3 blade Catto prop and recommended it to me for mine.
Kevin Alderman
On Thu, May 2, 2013 at 3:00 AM, KIS-List Digest Server <kis-list(at)matronics.com> wrote:
HTML Version:
Text Version:
From: Kevin Alderman <alderman.kevin0610(at)gmail.com>
and high power
done it.
to go.
idle.
waiting to go.
head by now.
Kevin Alderman
> HTML Version:
> Text Version:
> Brighton)
