Zoodiac 601 HDS flying info
gpjann1(at)netzero.net
PostPosted: Thu Apr 04, 2013 7:45 am    Post subject: Zoodiac 601 HDS flying info Reply with quote
Just some info on how my plane flyies which may be helpful.
Using the rudder for coordinating turns is different than any other plane I've flown.
Since the rudder is a flying rudder it takes very little pressure to turn when my airspeed is 80+ knts.
But at 80 knts and below the rudder takes very little pressure to use, and rudder comes in quickly, too quiickly.
When using the rudder you have to be aware of your airspeed or you could get yourself into a spin.
This causes concern when needing to land, turning in the pattern, slowing down, and decending.
You may have to change rudder presure quickly, at the right time.
Other then that the plane is closely coupled, light on the ailerons, and has control even at high decent ratesand slowing down.
Fly safe..
Greg Jannakos
N4399 TG/Corvair
How to Sleep Like a Rock
Obey this one natural trick to fall asleep and stay asleep all night.
http://thirdpartyoffers.netzero.net/TGL3241/515d9fdd483dd1fdd0d5est03vuc
