Posted: Wed Mar 20, 2013 10:16 am Post subject: Cabin heat control knobs |
Regarding the cabin heat system, I have a couple of questions:
- Where did you put the control knobs of the cables which control the rear and front cabin heat?
Is it good to put the front heat control knob in the instrument panel, and the rear heat control knob behind the front seats, thus leaving this control (only) reachable by the rear passengers?
- Those of you who used the modified “T” (VA175), in order to have left / right control, where did you put the control knob for this feature?
Cheers
Carlos
Posted: Wed Mar 20, 2013 10:51 am Post subject: Cabin heat control knobs |
Both heat control knobs need to be accessible to the pilot. I find that 90% of the time when I have heat on I just have the rear on. I find no real need for a left/right control – but to each his/her own.
I have the oil cooler air butterfly valve (blank knob) control on the pilot only side of the panel, next to the alternate engine air (red knob) control. The heat knobs are next to each other on the co-pilot side (but reachable from the pilot seat). That way the co-pilot will not mistakenly touch the oil cooler or alt air controls. All controls are on the panel apron. When you pick the spots, make sure you do not create interference for full stick travel.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo
Sent: Wednesday, March 20, 2013 2:15 PM
Subject: Cabin heat control knobs
Cheers
Carlos | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Posted: Wed Mar 20, 2013 3:16 pm Post subject: Cabin heat control knobs |
I put these controls and the air filter bypass on a plate that attached to the rear of the panel with screws from the front. The knobs fit through an oval hole cut in the panel. Otherwise the controls will have to be removed if you want to take the panel out. Makes service much easier.
On Mar 20, 2013, at 2:14 PM, "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
- Those of you who used the modified “T� (VA175), in order to have left / right control, where did you put the control knob for this feature?
Cheers
Carlos
cs.com
matronics.com/contribution
Posted: Thu Mar 21, 2013 2:48 am Post subject: Cabin heat control knobs |
Jesse
Will you please send me a picture of your setup.
CarlosÂ
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: quarta-feira, 20 de Março de 2013 23:16
Subject: Re: Cabin heat control knobs
Cheers
Carlos | Quote: | | ===================================://www.matronics.com/Navigator?RV10-List===================================cs.com===================================matronics.com/contribution=================================== |
| 0123456789 | Quote: | | =================================== | 0 | Quote: | | =================================== | 1 | Quote: | | =================================== | 2 | Quote: | | =================================== | 3 | Quote: | | =================================== | 4 | Quote: | | =================================== | 5 | Quote: | | =================================== | 6
hotwheels
Posted: Thu Mar 21, 2013 11:43 am Post subject: Re: Cabin heat control knobs |
photo attached...
Jay
166.16 KB |
5881 Time(s) |
jpiper623(at)gmail.com Guest
Posted: Fri Mar 22, 2013 7:29 pm Post subject: Cabin heat control knobs |
Unrelated post but has anyone veiwed the new conforma tips for the RV-7,8,9, and RV-10 and F1 rocket from aveoengineering.com. They look really nice.
On Thu, Mar 21, 2013 at 6:47 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Jesse
Carlos
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Jesse Saint
Cheers
Carlos
| 01
2 3456 789 01234 56
7
Go to Blog and scroll down.
On Fri, Mar 22, 2013 at 11:28 PM, John Zazulka <jpiper623(at)gmail.com (jpiper623(at)gmail.com)> wrote:
[quote]Unrelated post but has anyone veiwed the new conforma tips for the RV-7,8,9, and RV-10 and F1 rocket from aveoengineering.com. They look really nice.
Jesse
Carlos
Cheers
Carlos
| 01
2 3456 789 01234 56
7
